Tue, 13 Apr 2021 22:57:51 +0000
AmeriBodge
AmeriBodge
Tue, 13 Apr 2021 22:57:51 +0000 quote
so without revealing too much... I have the possibility of manufacturing (small batch) metal replacement battery-side doors for smallframes. likely 18ga or similar steel or stainless or aluminum.
I've connected with a local shop in NYC that does 3D scanning and I'm willing to invest in the tooling to stamp new pieces in the USA.
if these were priced at around $60 ea. would at least 10 people want one? that would cover my initial costs. I'm not asking for money up-front, just gauging if anyone would want one. when I looked into doing this a couple of years ago there wasn't much interest, but prices have since come down significantly and this is a lot less expensive to do.
I know there are some out there made of fiberglass but a lot of prep work has to go into making them look presentable. these would look basically identical to the originals and could be painted with minimal prep work (or chrome plated or whatever).
Tue, 13 Apr 2021 23:16:32 +0000
Tue, 13 Apr 2021 23:16:32 +0000 quote
Put me down for one, maybe two.
Wed, 14 Apr 2021 00:12:48 +0000
Wed, 14 Apr 2021 00:12:48 +0000 quote
I would be in for one, yes please.
Wed, 14 Apr 2021 00:17:31 +0000
66 bluebadge,primavera,2x 74 rally,79 p200e 64 gl 2x 64 vbb 2x ld 57 ld 125
Wed, 14 Apr 2021 00:17:31 +0000 quote
Put me in for one.Please
Wed, 14 Apr 2021 00:42:46 +0000
AmeriBodge
AmeriBodge
Wed, 14 Apr 2021 00:42:46 +0000 quote
Help me collect contact info for when this happens: fill out this form! https://forms.gle/sX428E7mk14VPRHr6
Need to source a good non-damaged panel first (waiting on responses from a few people).
Already have the manufacturing process lined up and ready to go...
Only thing these won't include is a latch (some may opt for a lock or pins or something).
Wed, 14 Apr 2021 05:00:05 +0000
1974 Primavera
1974 Primavera
Wed, 14 Apr 2021 05:00:05 +0000 quote
plsssss
id definitely buy one
Wed, 14 Apr 2021 05:11:25 +0000
Wed, 14 Apr 2021 05:11:25 +0000 quote
V oodoo wrote:
saturn wrote:
I'm having repros stamped. See my thread! metal smallframe / elestart "left" / battery door
Voodoo do you want to loan me yours to make the tooling?
Aw HELL yeah! It's about time and casting them looks like would likely be more dough anyway in small lots and minimal tooling.
Pm me your phone number, Ace!
Wed, 14 Apr 2021 08:06:04 +0000
The Dude
The Dude
Wed, 14 Apr 2021 08:06:04 +0000 quote
Count me in for one. I'd think $60 is more than reasonable for short run. If you need an NOS original to scan, I may be able to help. PM me.
Tue, 27 Apr 2021 19:40:53 +0000
AmeriBodge
AmeriBodge
Tue, 27 Apr 2021 19:40:53 +0000 quote
Update:
NOS panel is in the 3D scanner and I'll have a 3D model soon. Once I have a good model I can make molds and start stamping.
Tue, 27 Apr 2021 20:11:20 +0000
The Dude
The Dude
Tue, 27 Apr 2021 20:11:20 +0000 quote
Very exciting!
Tue, 04 May 2021 17:54:10 +0000
AmeriBodge
AmeriBodge
Tue, 04 May 2021 17:54:10 +0000 quote
it's happening!
Tue, 04 May 2021 20:34:53 +0000
The Dude
The Dude
Tue, 04 May 2021 20:34:53 +0000 quote
Now thats Progress!
Tue, 04 May 2021 21:25:51 +0000
Tue, 04 May 2021 21:25:51 +0000 quote
At long last
Nice one, Andrew!
American Smallieists rejoice!
Tue, 04 May 2021 22:25:31 +0000
AmeriBodge
AmeriBodge
Tue, 04 May 2021 22:25:31 +0000 quote
just waiting on some tooling to arrive (Thursday??) and need to build the mold and do some test stamps
what we'll end up doing is offering to do hinges for people (steel, brazed/spot welded in place) but do a center point dimple where the lock should ideally go (leaving the area blank for options of factory latches or mailbox latches, dzus fasteners, etc - different hole sizes)
will also be doing stamps in different gauges of steel and aluminum to see what works best, and my guess is a light gauge steel will be best
as you all know, many repop panels are thinner for cost saving - and the same applies here obviously - but thinner gauge is also easier to stamp!
I hope for the price point this is acceptable to everyone 8)
will update when I have more news/photos
Tue, 04 May 2021 22:59:14 +0000
AmeriBodge
AmeriBodge
Tue, 04 May 2021 22:59:14 +0000 quote
also (just for fun) here's a view of how detailed the 3D scanner can get: it was able to pick up the texture of the factory sticker on the NOS panel.
Wed, 05 May 2021 02:21:06 +0000
The Dude
The Dude
Wed, 05 May 2021 02:21:06 +0000 quote
Very cool! Thanks for sharing the scans, and plans. Nice detail!
I understand the necessity to use lighter gauge steel, for easier stamping. However, I would personally lean more toward a heavier gauge, even if it means a slightly higher price point. If I had the choice between a cheaper light panel, and a more expensive heavier (stockish gauge) panel, I'd gladly pay for the later. Although that is just me. There are limitations, so something better than nothin I dont think a lighter panel would be an issue, as long as it wont get dented by the wind blowing. Just my 1.5 cents.
Dimple for lock position is a great plan!
You obviously have thought this through, so keep up the good work!
Wed, 05 May 2021 02:56:26 +0000
AmeriBodge
AmeriBodge
Wed, 05 May 2021 02:56:26 +0000 quote
even 24ga steel (0.024" - probably thinner than I'll go) is going to be pretty good and sturdy once pressed - this panel has a very long arch and a curve at the end for rigidity
for comparison, most kitchen sinks are 18-22ga stainless and pretty much bulletproof
it just depends what the press can handle, which I'll know soon
Wed, 05 May 2021 03:17:26 +0000
The Dude
The Dude
Wed, 05 May 2021 03:17:26 +0000 quote
See, you have thought this through well Carry on!
Wed, 05 May 2021 04:06:48 +0000
Rally 180, TS 125, PX 150 and a lot of smallies
Wed, 05 May 2021 04:06:48 +0000 quote
Very excited. I can finish my small frame.
Wed, 05 May 2021 15:25:56 +0000
Wed, 05 May 2021 15:25:56 +0000 quote
Scan detail is impressive! Can you share more info on the scanner please?
Wed, 05 May 2021 16:03:47 +0000
AmeriBodge
AmeriBodge
Wed, 05 May 2021 16:03:47 +0000 quote
I'm not an expert on it (I don't do the scanning myself), but my understanding is it uses lasers as probes to translate basically a radar-type reading into a 3D image with incredible precision.
That raw image is then manually processed in a CAD program to create a more smooth surface.
In this case, we didn't make it perfectly smooth, as the original molded part was done by hand before computer design, so it wasn't "perfect" to begin with. Also, the mold's details will be "averaged" when the steel is pressed against it, so you won't see them anyway (these sorts of details would only be visible in a direct 3D print or CNC part).
Attached is the raw scan (latches and imperfections and all) vs. finished "smoothed" panel model.
More info: https://www.cubodesigns.com/3d-scanning
⬆️    About 29w elapsed between posts    ⬇️
Tue, 23 Nov 2021 03:19:28 +0000
1979 50 Specail
1979 50 Specail
Tue, 23 Nov 2021 03:19:28 +0000 quote
Have these gone into production yet? I'd like to put in an order for one.
Jon in Philadelphia
Tue, 23 Nov 2021 14:58:46 +0000
AmeriBodge
AmeriBodge
Tue, 23 Nov 2021 14:58:46 +0000 quote
not quite, we're still figuring out the tooling to ensure the copies are as good looking as the originals
looking at early 2022
Tue, 23 Nov 2021 15:18:26 +0000
1979 50 Specail
1979 50 Specail
Tue, 23 Nov 2021 15:18:26 +0000 quote
Thank you...
Tue, 23 Nov 2021 17:34:26 +0000
The Dude
The Dude
Tue, 23 Nov 2021 17:34:26 +0000 quote
Very good! Looking forward to this
Sat, 11 Dec 2021 01:01:22 +0000
Vespa 125 & Vespa ET3
Sat, 11 Dec 2021 01:01:22 +0000 quote
Im so down whit this reproduction 😁
Sat, 11 Dec 2021 16:00:00 +0000
AmeriBodge
AmeriBodge
Sat, 11 Dec 2021 16:00:00 +0000 quote
Still working on this. Finalizing the 3D printing and fabricating techniques to ensure the panels come out as close to the originals as possible.
Sun, 13 Feb 2022 03:15:23 +0000
Sport 100 Small Frame
Sun, 13 Feb 2022 03:15:23 +0000 quote
Hi,
I'm new to this forum. But will definitely buy a cover if when they get produced. Been looking for one for my Sport 100 for about 2 years!
Regards,
Ron
⬆️    About 28d elapsed between posts    ⬇️
Sun, 13 Mar 2022 02:11:12 +0000
1974 Primavera
1974 Primavera
Sun, 13 Mar 2022 02:11:12 +0000 quote
Hey! i was just thinking about this cover on my primavera and remembered this thread, any news at all?
Wed, 16 Mar 2022 05:25:13 +0000
AmeriBodge
AmeriBodge
Wed, 16 Mar 2022 05:25:13 +0000 quote
not yet! I'll post here when we have something.
Wed, 16 Mar 2022 05:30:19 +0000
The Dude
The Dude
Wed, 16 Mar 2022 05:30:19 +0000 quote
Waiting patiently
Wed, 16 Mar 2022 13:43:22 +0000
1974 Primavera
1974 Primavera
Wed, 16 Mar 2022 13:43:22 +0000 quote
Thank you, i'm excited
⬆️    About 31w elapsed between posts    ⬇️
Thu, 20 Oct 2022 02:42:46 +0000
'74 Primavera, '80 100 Sport
Thu, 20 Oct 2022 02:42:46 +0000 quote
Oooh! Just added my name to the list if it's not too late. Might take 2 if there are enough for everyone. What a great project. If they turn out well you could probably sell a bunch of them to the big online retailers <fingers> Thanks for doing this <3
Sat, 05 Nov 2022 19:58:37 +0000
AmeriBodge
AmeriBodge
Sat, 05 Nov 2022 19:58:37 +0000 quote
I finally have all of the tooling necessary to manufacture these. Will post an update this weekend on pricing etc.
Sat, 05 Nov 2022 20:03:42 +0000
AmeriBodge
AmeriBodge
Sat, 05 Nov 2022 20:03:42 +0000 quote
Also would people be comfortable paying up front assuming the panels would be delivered later? Having the funds for materials up front would make this easier for me. There are a few people here who know me in person and can vouch, but I also don't want to break any forum rules.
Sun, 06 Nov 2022 01:52:54 +0000
Sun, 06 Nov 2022 01:52:54 +0000 quote
Wonderful! What a journey for you. I'm glad I came into the story late enough for the suspense not to be long <grin> Yeah, if there's some way to not be just tossing money at a stranger I'd be up for paying ahead. Is there something like a GoFundMe type service that would at least have it be on a platform and with some kind of commitment or something? I am sure that you will find quite a market for these after the prototypes prove that they are cool. Maybe a wee biz loan would do? I would be up for a loan if you have anything to secure it against? Just thinking aloud. Totally want this project to work!
Sun, 06 Nov 2022 05:58:26 +0000
Sun, 06 Nov 2022 05:58:26 +0000 quote
I've dealt with a few different individuals on this forum. Some are American, Indonesian, British, and others. I've sent money to a guy in Italy to buy cool old original Vespa parts, not a corporate vendor but just a guy who sells stuff from his father's scrap yard. All were honest and stuck to their word, and I got the parts.
In fact, the ones who burn the hardest are the ones protected by eBay, credit card companies, and PayPal.
Just sayin'.
Mon, 07 Nov 2022 01:43:01 +0000
AmeriBodge
AmeriBodge
Mon, 07 Nov 2022 01:43:01 +0000 quote
the biggest thing for me is that I've already invested my own money on tooling and research, so I'm sort of at the end of what is "cool" to spend on a "hobby" (in the words of my fiancee).
so just having the money for metal up-front would make life at home easier - that's really all there is to it.
I will stamp out a few prototypes and upload photos and videos soon.
Mon, 07 Nov 2022 02:07:56 +0000
Mon, 07 Nov 2022 02:07:56 +0000 quote
while not against the rules, per-se I do have to make mention that any dealing here are personal and not under the purview of MV.
basically, don't come crying or blame MV in any way if you don't get any product after you paid this guy. we can't and won't help you.
*moderator cap off*
so, how much are we talking per door? and what's the lead time?
Mon, 07 Nov 2022 02:19:56 +0000
AmeriBodge
AmeriBodge
Mon, 07 Nov 2022 02:19:56 +0000 quote
they'll have to be made one at a time by hand so with that in mind and all of the post-pressing work (trimming, welding on the hinges, etc) it's going to be at least $100
I need to do a few final tests to solidify the costs of materials and time involved
if I can get the process simplified to one pressing and I can make a jig to weld on tabs (which I can somewhat mass produce) I could potentially bring the price down but I'm just assuming that it's going to take at least 30-60 minutes per panel total, so in my mind it's pretty fair
[ Time: 0.0343s ][ Queries: 6 (0.0037s) ][ Debug on ][ 276 ][ Thing Two ]
