Rim Job Part Trois
Greetings:
The Next Day
Greetings:
Orange Paint Applied
Greetings:
Denouement
Greetings:
S 190. Custom VNB 150
Looking good!
Rim Job Complete
Greetings:
Excellent Results!!!
Greetings:
Leader Upgrades
Sun Apr 18, 2021 12:55 pm quote
Edition Quatre
Greetings:
ISO's turn for Fun with Rims. Found a front rim in really nice - better than the one I had - shape. Sadly it was subjected to Wheelman's painting "skills". The outcome appears below, with a recent pic of the stock rim preceding.
  DoubleGood Vespa T-Shirts
[ Time: 0.0512s ][ Queries: 27 (0.0314s) ][ Debug on ][ Thing Two ]
