Fri Apr 08, 2011 11:47 am
LX150
LX150
Fri Apr 08, 2011 11:47 am linkquote
Cheers.
Fri Apr 08, 2011 1:34 pm
1979 Vespa P200E
1979 Vespa P200E
Fri Apr 08, 2011 1:34 pm linkquote
Fri Apr 08, 2011 1:40 pm
LX150
LX150
Fri Apr 08, 2011 1:40 pm linkquote
Fri Apr 08, 2011 3:44 pm
125GT-S
125GT-S
Fri Apr 08, 2011 3:44 pm linkquote
Fri Apr 08, 2011 3:55 pm
LX150
LX150
Fri Apr 08, 2011 3:55 pm linkquote
Fri Apr 08, 2011 7:20 pm
'09 BV250, '02 ET2 '07 LX150
Fri Apr 08, 2011 7:20 pm linkquote
Fri Apr 08, 2011 9:49 pm
GRAPHITE LX 150
GRAPHITE LX 150
Fri Apr 08, 2011 9:49 pm linkquote
Sat Apr 09, 2011 4:18 am
LX150
LX150
Sat Apr 09, 2011 4:18 am linkquote
Sat Apr 09, 2011 1:00 pm
Reprehensible Misinformant
Sat Apr 09, 2011 1:00 pm linkquote
Sat Apr 09, 2011 8:38 pm
'05 Vespa Granturismo
Sat Apr 09, 2011 8:38 pm linkquote
Just too heavy.
Sat Apr 23, 2011 7:45 am
GTV300 2011
GTV300 2011
Sat Apr 23, 2011 7:45 am linkquote
Sun Apr 24, 2011 4:33 am
Sun Apr 24, 2011 4:33 am linkquote
Sun Apr 24, 2011 10:40 am
T5s
T5s
Sun Apr 24, 2011 10:40 am linkquote
timber
⬆️    About 9 years elapsed between posts    ⬇️
Wed Jan 29, 2020 9:34 pm
2021 GTS 300 HPE +2013 GTS 300ie + 294 Polini
Wed Jan 29, 2020 9:34 pm linkquote
Thu Apr 29, 2021 9:19 am
Thu Apr 29, 2021 9:19 am linkquote
Yikes. Putting in wood screws at an angle because they are too long for the thickness of the plywood? Seems like a job for countersink nuts or T-nuts.
Thu Apr 29, 2021 6:45 pm
'08 Vespa LX80, '07 LX50
Thu Apr 29, 2021 6:45 pm linkquote
Those used to be called "Sex Bolts".
Oh thank goodness they still are!
https://www.mcmaster.com/sex-bolts/
[ Time: 0.0516s ][ Queries: 7 (0.0261s) ][ Debug on ][ 211 ][ Thing One ]
