Posts: 4067 Location: Staten Island, NY |
Mon, 03 May 2021 16:43:26 +0000
quote
https://www.nomartirechanger.com/tc-ch100hd.html |
Posts: 12533 Location: The state of insanity, SoCal |
Mon, 03 May 2021 16:53:09 +0000
quote
swiss1939 wrote: I've been eyeing this since that guy destroyed my tires. https://www.nomartirechanger.com/tc-ch100hd.html Wider 10's are fine Personally, I just use good spoons and rim protectors. Much like a hot Saturday night. Lube, pressure, angle of attack and a soft touch. |
Mon, 03 May 2021 17:49:41 +0000
quote
greasy125 wrote: swiss1939 wrote: I've been eyeing this since that guy destroyed my tires. https://www.nomartirechanger.com/tc-ch100hd.html Wider 10's are fine Personally, I just use good spoons and rim protectors. Much like a hot Saturday night. Lube, pressure, angle of attack and a soft touch. |
Mon, 03 May 2021 21:38:25 +0000
parallelogramerist
Posts: 4143 |
quote
swiss1939 wrote: greasy125 wrote: swiss1939 wrote: I've been eyeing this since that guy destroyed my tires. https://www.nomartirechanger.com/tc-ch100hd.html Wider 10's are fine Personally, I just use good spoons and rim protectors. Much like a hot Saturday night. Lube, pressure, angle of attack and a soft touch. |
Posts: 3443 Location: Veria, Greece |
Mon, 03 May 2021 21:39:41 +0000
quote
@Greasy: I actually found the Pirellis to be harder than any Michelins I worked with. Heidenaus were the worst though... ![]() ![]() ![]() ![]() ![]() ![]() |
Mon, 03 May 2021 21:53:22 +0000
quote
Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps.. Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy! |
Posts: 6626 Location: So Cal |
Mon, 03 May 2021 22:16:40 +0000
quote
Tue, 04 May 2021 03:08:43 +0000
parallelogramerist
Posts: 4143 |
quote
swiss1939 wrote: Safis, u use a machine so that must help along with second person. Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps.. Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy! https://www.cyclegear.com/accessories/stockton-aluminum-off-road-tire-combo-lever-set?sku_id=1124055 And i will say that mounting any tire on a SIP rim is child's play compared to mounting a knobby tire and bib mousse combo onto a dirt bike rim with double rim locks. |
![]() Tue, 04 May 2021 12:39:56 +0000
Posts: 3229 Location: Rochester, Minnesota |
![]() 2007 Stella 225
quote
whodatschrome wrote: swiss1939 wrote: Safis, u use a machine so that must help along with second person. Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps.. Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy! https://www.cyclegear.com/accessories/stockton-aluminum-off-road-tire-combo-lever-set?sku_id=1124055 And i will say that mounting any tire on a SIP rim is child's play compared to mounting a knobby tire and bib mousse combo onto a dirt bike rim with double rim locks. https://www.cyclegear.com/accessories/motion-pro-t6-tire-levers?gclid=EAIaIQobChMIvaLBnIWw8AIVCo3ICh1fyQLcEAQYBCABEgK1sPD_BwE |
![]() Tue, 04 May 2021 13:29:43 +0000
Posts: 5786 Location: Indo |
![]() a not so normal vbb2 '64, a weirdo vbx '86, a not so normal pts100 '82 and a yellow sunshine '74 sprint
quote
![]() I need a bigger garage ![]() Got a help from the kids around the blocks |
Tue, 04 May 2021 14:19:31 +0000
parallelogramerist
Posts: 4143 |
quote
Christopher_55934 wrote: whodatschrome wrote: swiss1939 wrote: Safis, u use a machine so that must help along with second person. Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps.. Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy! https://www.cyclegear.com/accessories/stockton-aluminum-off-road-tire-combo-lever-set?sku_id=1124055 And i will say that mounting any tire on a SIP rim is child's play compared to mounting a knobby tire and bib mousse combo onto a dirt bike rim with double rim locks. https://www.cyclegear.com/accessories/motion-pro-t6-tire-levers?gclid=EAIaIQobChMIvaLBnIWw8AIVCo3ICh1fyQLcEAQYBCABEgK1sPD_BwE |
![]() 1967 Granturismo 177, 1979 P200E, 1974 Primavera 125 Hooligans S/C Seattle/Austin
Posts: 720 Location: Austin, TX |
Thu, 06 May 2021 22:50:15 +0000
quote
![]() Fri, 07 May 2021 11:37:54 +0000
quote
https://www.cyclegear.com/accessories/motion-pro-rimshield-ii I'm getting a Harbor Freight version, of a tire changer. Last time I had to get a tire off a split rim I got annoyed and had a workout. Bead refused to let go. The built in bead breaker would have been great. Going to try Mojo bars and blocks to protect the rims. https://www.mojotiretools.com/mojoweb.htm Mojo blocks https://www.mojotiretools.com/mojoblocks.htm |
Fri, 07 May 2021 14:41:14 +0000
Posts: 1280 Location: Philadelphia |
quote
I added lock washers and nylock nuts just to be safe with mine but the tire install took all of 5 mins with only one curse word... Unless you're into S&Ming your wheels? I dunno what you dudes/dudettes do in your own time! |
![]() Fri, 07 May 2021 15:05:51 +0000
Posts: 7119 Location: Nashville |
quote
FridayMatinee wrote: Any reason why no one is using SIP or FA Italia split rims? The 2 piece jawns? Do you have links for SIP of FA Italia's versions? |
Fri, 07 May 2021 15:46:08 +0000
quote
chandlerman wrote: I thought that only Pinasco was doing the tubeless split rims. They're good (I have a couple sets), but pricy and heavier than the non-split versions if you're into weight shaving. Also, can only run 3.5x10 on them. Do you have links for SIP of FA Italia's versions? http://www.scootermercato.com/Scooter-Parts/Rims/5581 They didn't seem much heavier than the original 8" rims honestly. I didn't weigh them though. Coulda sworn SIP made them too but I can't find them now. I may have fever dreamed that? |
Fri, 07 May 2021 16:05:14 +0000
quote
SaFiS wrote: Those are FAs. SIP never did split tubeless.. and yes the ones I have are the FA Italia ones. No complaints yet. Set up was lightening quick. |
![]() Fri, 07 May 2021 16:18:34 +0000
quote
FridayMatinee wrote: Any reason why no one is using SIP or FA Italia split rims? The 2 piece jawns? I added lock washers and nylock nuts just to be safe with mine but the tire install took all of 5 mins with only one curse word... Unless you're into S&Ming your wheels? I dunno what you dudes/dudettes do in your own time! |
![]() Fri, 07 May 2021 19:22:18 +0000
quote
Christopher_55934 wrote: I can't seem to find a wider split rim in tubeless, going with a 2.50 x 11 tubeless. Supposed to fit with no modifications. I want the wider tubeless as I've been told they feel more planted or stable at 60 mph. If I had it to do over, I'd go with 110's, but I'm certainly not feeling any need to switch them out before they're worn out. |
![]() Fri, 07 May 2021 20:27:33 +0000
P125x (4KW Hub Motor)
Posts: 409 Location: Alexandria, VA |
![]() P125x (4KW Hub Motor)
quote
swiss1939 wrote: I've been eyeing this since that guy destroyed my tires. https://www.nomartirechanger.com/tc-ch100hd.html ![]() |
Thu, 13 May 2021 21:11:38 +0000
quote
![]() '74 50s x3 '78 P200 E '84 Cosa '91 PK50XL2 '58 AllState '68 Sprint '80 50special and a '66(?) Super125
Posts: 8864 Location: seattle/athens |
Fri, 14 May 2021 18:10:14 +0000
quote
![]() Fri, 14 May 2021 19:49:38 +0000
Posts: 8436 Location: San Francisco |
![]() 2:6
quote
V oodoo wrote: What about the Pinasco split tubless rims and save all the hassle? Anybody here using? Seems like a well made setup, a good review can be found here : https://scooterlab.uk/pinasco-tubeless-vespa-wheel-rims-fitted-testedreview/ I should try them on my small frame. |
![]() Sat, 15 May 2021 14:27:06 +0000
quote
oopsclunkthud wrote: I have a set of Pinasco sitting on the shelf unused. the studs on the rally are not long enough to mount them, or any of the other aluminum rims. I should try them on my small frame. Last edited by Christopher_55934 on Sat, 15 May 2021 18:51:27 +0000; edited 1 time |
![]() Sat, 15 May 2021 14:42:08 +0000
quote
Sat, 15 May 2021 16:37:44 +0000
quote
![]() Sat, 15 May 2021 18:52:51 +0000
quote
SaFiS wrote: A friend brought me this PX200 today, saved from the junkyard. He was going to keep it, but since it's a no e-start motor, he passed it on to me. For only 200EUR it was a no-brainer. Although engine is frozen, I don't believe it's going to be terrible inside. Whatever the outcome, 200EUR don't buy you new engine cases plus I get a complete front end. I'm going to strip it tomorrow and report... ![]() ![]() ![]() ![]() |
Sat, 15 May 2021 19:02:35 +0000
quote
![]() Sat, 15 May 2021 19:25:13 +0000
quote
Christopher_55934 wrote: These look interesting, when working by hand. https://www.cyclegear.com/accessories/motion-pro-rimshield-ii I'm getting a Harbor Freight version, of a tire changer. Last time I had to get a tire off a split rim I got annoyed and had a workout. Bead refused to let go. The built in bead breaker would have been great. Going to try Mojo bars and blocks to protect the rims. https://www.mojotiretools.com/mojoweb.htm Mojo blocks https://www.mojotiretools.com/mojoblocks.htm |
Sun, 16 May 2021 19:00:59 +0000
quote
A few photos of the motor... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Mon, 14 Jun 2021 14:42:49 +0000
quote
Mixed up another batch and shot a third coat of catalyzed clear over the first two, and crossed fingers. Success! The catalyst in the third coat set off the others, and finish is rock hard. ![]() ![]()
Positive
![]() Mon, 14 Jun 2021 15:46:16 +0000
Posts: 3429 Location: california |
quote
Safis - nice find. Gotta like the spare EFL gearbox alone. That motor looks like it got absolutely cooked - seat must be full of urine, just throw it away. 🙂 Love the offie chair idea. Yes! |
Fri, 18 Jun 2021 17:33:02 +0000
quote
My SLUK Driver screen finally arrived. Now to find some mirrors..... ![]()
Positive
Posts: 6769 Location: Hustletown, TX |
Fri, 18 Jun 2021 17:46:47 +0000
quote
Birdsnest wrote: Thing of beauty right there! |
![]() 73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 90 V5N 50, 01 ET2, 2015 HD Road Glide Special
Posts: 4522 Location: Oceanside, CA |
Sat, 10 Jul 2021 04:25:44 +0000
quote
![]() Check the 11 o’clock position |
![]() Sat, 10 Jul 2021 23:49:37 +0000
quote
![]() '15 GTS300, '86 PX125EFL, '66 VBB, '04 Ninja 250
Posts: 6836 Location: San Diego, CA |
![]() Sun, 11 Jul 2021 11:23:25 +0000
quote
![]() Change a senior friend piston ring and fix a carb as well |
