Tue May 04, 2021 5:50 pm
LXV150ie
LXV150ie
Tue May 04, 2021 5:50 pm linkquote
I am a lazy mechanic, so this method might save someone else some time.
    -->I removed the entire glovebox panel, which requires removing the horn cover to get to the two body bolts underneath on the front (and the three bolts in the glovebox).
    -->Using a thin coat hanger, I snaked it inside the throttle side floorboard, coming out right around where the 02 sensor connects.
    -->I made a tiny loop on the end of the hanger and tied the tach lead to it.
    -->Then, I pulled it through, and wrapped it around the spark plug wire.
    -->I zip tied the tach lead to the 02 sensor wire to keep it away from the muffler.
The positioning of this works just fine for the usual diagnostics. I like this unit a lot. It gives you a lot of customization and a nice clock when the motor is off. You can even set a backlight trigger for RPM thresholds, so it turns red.
Wed May 05, 2021 5:53 am
Wed May 05, 2021 5:53 am linkquote
That looks good for diagnostics and setup. Easier than one that needs a power supply.
[ Time: 0.0359s ][ Queries: 7 (0.0104s) ][ Debug on ][ 209 ][ Thing One ]
