Mon May 03, 2021 8:43 am
VSX, Stella 177, VNX1T, V9B1T
Mon May 03, 2021 8:43 am linkquote
Mon May 03, 2021 8:53 am
Mon May 03, 2021 8:53 am linkquote
Just an FYI, that thing is a little difficult with the 10” narrow rims.
Wider 10’s are fine
Personally, I just use good spoons and rim protectors.
Much like a hot Saturday night. Lube, pressure, angle of attack and a soft touch.
Mon May 03, 2021 9:49 am
Mon May 03, 2021 9:49 am linkquote
Wider 10’s are fine
Sorry to sidetrack thread further. I've tried that with these tires and nothing I did would get them onto or off the rims! So I must just suck at doing it. They were gonna tear up the beads if I tried any harder. But I guess thats what the guy I paid to install them did!
Mon May 03, 2021 1:38 pm
Mon May 03, 2021 1:38 pm linkquote
Wider 10’s are fine
It's about time someone brings to light the problem with the SIP rims. They are NOT user friendy to install (or remove)! I do have 3 sets (total of 6) SIP rims, but i use them on my track bikes (and my pink PK 200). I still don't see them as a replacement for a standard OEM split rim. That being said, if you do plan to use the SIP rims, make sure the tire is good and hot. Put it out in the sun for it to warm up a bunch. Also use a tire paste when installing. Pro tip...aluminum tire spoons won't gouge the rims like steel tire irons will. If you do happen to nick or gouge the sealing surface on the rim, it can cause an air leak. Make sure to sand out any gouges. Also it's not too difficult to damage the tire's bead by over streaching it . Once that happens, throw away the tire! FYI, I still use the OEM split rims on all my road going scooters.
Mon May 03, 2021 1:39 pm
Mon May 03, 2021 1:39 pm linkquote
Well, no tutorial on this. It's just a two men job. One's working the machine and the other one pushes the tire bead in the small channel on the rim. Small steps at a time. The 2.10s are a pain in the ass. The 2.50s are easier. One thing that is crucial is that we spent the extra 180€ for the "special" motorcycle mount / unmount head, when we bought the tire changer 10+ years ago. The one that comes with the machine is destined for cars and if used, it will f@ck up any motorcycle / scooter tire. Other extras are the plastic protections on the head and on the clamps (red arrows). I also use painter's tape on the rim, extra rugs on the clamps along with the plastic protections and lots of tire paste. Photos following, size comparison between the heads and a "nerve wrecking" mounting on freshly painted rims we did last year...
@Greasy: I actually found the Pirellis to be harder than any Michelins I worked with. Heidenaus were the worst though...
Mon May 03, 2021 1:53 pm
Mon May 03, 2021 1:53 pm linkquote
Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps..
Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy!
Mon May 03, 2021 2:16 pm
Mon May 03, 2021 2:16 pm linkquote
I never fought a tire like I fought getting Heidenau K-80’s on the regular 10” split rims of the GL. Not looking forward to changing them. Anybody else running K-80’s?
Mon May 03, 2021 7:08 pm
Mon May 03, 2021 7:08 pm linkquote
Cycle Gear makes a Motion Pro knock off aluminum tire spoon that works really well. The trick is to buy them when they're having a 50% off sale...and then buy a second set so that you have an additional spoon. Look VERY close at the picture in the link. The only spoon that's useful is the one that has a little lip at the end of it!
https://www.cyclegear.com/accessories/stockton-aluminum-off-road-tire-combo-lever-set?sku_id=1124055
And i will say that mounting any tire on a SIP rim is child's play compared to mounting a knobby tire and bib mousse combo onto a dirt bike rim with double rim locks.
Tue May 04, 2021 4:39 am
Tue May 04, 2021 4:39 am linkquote
Is this the same lever?
https://www.cyclegear.com/accessories/motion-pro-t6-tire-levers?gclid=EAIaIQobChMIvaLBnIWw8AIVCo3ICh1fyQLcEAQYBCABEgK1sPD_BwE
Tue May 04, 2021 5:29 am
Tue May 04, 2021 5:29 am linkquote
I need a bigger garage
Got a help from the kids around the blocks
Tue May 04, 2021 6:19 am
Tue May 04, 2021 6:19 am linkquote
Only some of those levers are the same. The levers that have a 10/12mm or 12/13mm ends on them are the ONLY ones that have the special little lip on the ends of them. The levers with the large ends (22,24,27,32mm) are just normal shaped spoon levers!
Thu May 06, 2021 2:50 pm
Thu May 06, 2021 2:50 pm linkquote
Fri May 07, 2021 3:37 am
Fri May 07, 2021 3:37 am linkquote
https://www.cyclegear.com/accessories/motion-pro-rimshield-ii
I'm getting a Harbor Freight version, of a tire changer. Last time I had to get a tire off a split rim I got annoyed and had a workout. Bead refused to let go. The built in bead breaker would have been great.
Going to try Mojo bars and blocks to protect the rims.
https://www.mojotiretools.com/mojoweb.htm
Mojo blocks
https://www.mojotiretools.com/mojoblocks.htm
Fri May 07, 2021 6:41 am
1958 Allstate Super Cruisaire 2005 70cc Yamaha Vino
Fri May 07, 2021 6:41 am linkquote
I added lock washers and nylock nuts just to be safe with mine but the tire install took all of 5 mins with only one curse word...
Unless you're into S&Ming your wheels? I dunno what you dudes/dudettes do in your own time!
Fri May 07, 2021 7:05 am
Fri May 07, 2021 7:05 am linkquote
I thought that only Pinasco was doing the tubeless split rims. They're good (I have a couple sets), but pricy and heavier than the non-split versions if you're into weight shaving. Also, can only run 3.5x10 on them.
Do you have links for SIP of FA Italia's versions?
Fri May 07, 2021 7:46 am
Fri May 07, 2021 7:46 am linkquote
here's the ones I have, the picture shows a machined lip but mine are all black...
http://www.scootermercato.com/Scooter-Parts/Rims/5581
They didn't seem much heavier than the original 8" rims honestly. I didn't weigh them though.
Coulda sworn SIP made them too but I can't find them now. I may have fever dreamed that?
Fri May 07, 2021 7:54 am
Fri May 07, 2021 7:54 am linkquote
Those are FAs. SIP never did split tubeless..
Fri May 07, 2021 8:05 am
Fri May 07, 2021 8:05 am linkquote
must have been a wild dream I had then!
and yes the ones I have are the FA Italia ones.
No complaints yet. Set up was lightening quick.
Fri May 07, 2021 8:18 am
Fri May 07, 2021 8:18 am linkquote
I can't seem to find a wider split rim in tubeless, going with a 2.50 x 11 tubeless. Supposed to fit with no modifications. I want the wider tubeless as I've been told they feel more planted or stable at 60 mph.
Fri May 07, 2021 11:22 am
Fri May 07, 2021 11:22 am linkquote
As discussed in my other thread, the 120x70-11's feel a LOT more stable at high speeds. Less nimble at lower speeds as a result, but not enough it feels weird when you switch between them and 3.5x10's.
If I had it to do over, I'd go with 110's, but I'm certainly not feeling any need to switch them out before they're worn out.
Fri May 07, 2021 12:27 pm
P125x (4KW Hub Motor)
Fri May 07, 2021 12:27 pm linkquote
That is the tire changer I use for motorcycles.
Thu May 13, 2021 1:11 pm
Thu May 13, 2021 1:11 pm linkquote
Fri May 14, 2021 10:10 am
Fri May 14, 2021 10:10 am linkquote
Fri May 14, 2021 11:49 am
Fri May 14, 2021 11:49 am linkquote
I have a set of Pinasco sitting on the shelf unused. the studs on the rally are not long enough to mount them, or any of the other aluminum rims.
I should try them on my small frame.
Sat May 15, 2021 6:27 am
Sat May 15, 2021 6:27 am linkquote
Out of curiosity, can you remove the studs for longer screws? My rear wheel was ridden with loose nuts by the PO. I was able to remove the damaged studs and replaced them with a longer socket head cap screw that I could use a nylock nut on. I liked the nylock nut because it had more actual threads, the nylon locking portion and a built in washer.
Last edited by Christopher_55934 on Sat May 15, 2021 10:51 am; edited 1 time in total
Sat May 15, 2021 6:42 am
Sat May 15, 2021 6:42 am linkquote
Sat May 15, 2021 8:37 am
Sat May 15, 2021 8:37 am linkquote
A friend brought me this PX200 today, saved from the junkyard. He was going to keep it, but since it's a no e-start motor, he passed it on to me. For only 200€ it was a no-brainer. Although engine is frozen, I don't believe it's going to be terrible inside. Whatever the outcome, 200€ don't buy you new engine cases plus I get a complete front end. I'm going to strip it tomorrow and report...
Sat May 15, 2021 10:52 am
Sat May 15, 2021 10:52 am linkquote
If the cases are good everything else is a bonus.
Sat May 15, 2021 11:02 am
Sat May 15, 2021 11:02 am linkquote
Nice Chris! Another P saved from the boneyard. Looks like that one’s got plenty of life left in it.
Sat May 15, 2021 11:25 am
Sat May 15, 2021 11:25 am linkquote
Mojo blocks
I changed over 300 sets of motorcycle tires with that set-up, and one set of Vespa tires. Works well.
Sun May 16, 2021 11:00 am
Sun May 16, 2021 11:00 am linkquote
A few photos of the motor...
  DoubleGood Vespa T-Shirts
[ Time: 1.0745s ][ Queries: 26 (1.0521s) ][ Debug on ][ 152 ][ Thing Two ]
