![]() P208 Stock Ported Stroker, Stella VMC Stelvio 187, Stella 150, VNX1T, V9A1T, V9B1T
Posts: 3920 Location: Staten Island, NY |
https://www.nomartirechanger.com/tc-ch100hd.html |
Posts: 11526 Location: The state of insanity, SoCal |
swiss1939 wrote: I've been eyeing this since that guy destroyed my tires. https://www.nomartirechanger.com/tc-ch100hd.html Wider 10's are fine Personally, I just use good spoons and rim protectors. Much like a hot Saturday night. Lube, pressure, angle of attack and a soft touch. |
greasy125 wrote: swiss1939 wrote: I've been eyeing this since that guy destroyed my tires. https://www.nomartirechanger.com/tc-ch100hd.html Wider 10's are fine Personally, I just use good spoons and rim protectors. Much like a hot Saturday night. Lube, pressure, angle of attack and a soft touch. |
swiss1939 wrote: greasy125 wrote: swiss1939 wrote: I've been eyeing this since that guy destroyed my tires. https://www.nomartirechanger.com/tc-ch100hd.html Wider 10's are fine Personally, I just use good spoons and rim protectors. Much like a hot Saturday night. Lube, pressure, angle of attack and a soft touch. |
Posts: 3106 Location: Veria, Greece |
@Greasy: I actually found the Pirellis to be harder than any Michelins I worked with. Heidenaus were the worst though... ![]() ![]() ![]() ![]() ![]() ![]() |
Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps.. Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy! |
Posts: 6500 Location: So Cal |
swiss1939 wrote: Safis, u use a machine so that must help along with second person. Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps.. Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy! https://www.cyclegear.com/accessories/stockton-aluminum-off-road-tire-combo-lever-set?sku_id=1124055 And i will say that mounting any tire on a SIP rim is child's play compared to mounting a knobby tire and bib mousse combo onto a dirt bike rim with double rim locks. |
![]() Tue May 04, 2021 4:39 am
Posts: 2933 Location: Rochester, Minnesota |
![]() 2007 Stella 225
whodatschrome wrote: swiss1939 wrote: Safis, u use a machine so that must help along with second person. Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps.. Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy! https://www.cyclegear.com/accessories/stockton-aluminum-off-road-tire-combo-lever-set?sku_id=1124055 And i will say that mounting any tire on a SIP rim is child's play compared to mounting a knobby tire and bib mousse combo onto a dirt bike rim with double rim locks. https://www.cyclegear.com/accessories/motion-pro-t6-tire-levers?gclid=EAIaIQobChMIvaLBnIWw8AIVCo3ICh1fyQLcEAQYBCABEgK1sPD_BwE |
![]() Tue May 04, 2021 5:29 am
Posts: 5786 Location: Indo |
![]() a not so normal vbb2 '64, a weirdo vbx '86, a not so normal pts100 '82 and a yellow sunshine '74 sprint
![]() I need a bigger garage ![]() Got a help from the kids around the blocks |
Christopher_55934 wrote: whodatschrome wrote: swiss1939 wrote: Safis, u use a machine so that must help along with second person. Like i said I'm considering the no Mar changer, or a used coats 220 tire changer off cl, but agreed they can't be used without the hard plastic grips instead of the standard metal clamps.. Whodats, thanks for tips, yeah this guy did bead damage to brand new heidenau tires, both the ones he removed and three ones he replaced them with. And the rims even though brand new look like they are 15 yrs old heavy usage after one swap of rubber with that guy! https://www.cyclegear.com/accessories/stockton-aluminum-off-road-tire-combo-lever-set?sku_id=1124055 And i will say that mounting any tire on a SIP rim is child's play compared to mounting a knobby tire and bib mousse combo onto a dirt bike rim with double rim locks. https://www.cyclegear.com/accessories/motion-pro-t6-tire-levers?gclid=EAIaIQobChMIvaLBnIWw8AIVCo3ICh1fyQLcEAQYBCABEgK1sPD_BwE |
![]() 1967 Granturismo 177, 1979 P200E, 1974 Primavera 125 Hooligans S/C Seattle/Austin
Posts: 712 Location: Austin, TX |
![]() Fri May 07, 2021 3:37 am
https://www.cyclegear.com/accessories/motion-pro-rimshield-ii I'm getting a Harbor Freight version, of a tire changer. Last time I had to get a tire off a split rim I got annoyed and had a workout. Bead refused to let go. The built in bead breaker would have been great. Going to try Mojo bars and blocks to protect the rims. https://www.mojotiretools.com/mojoweb.htm Mojo blocks https://www.mojotiretools.com/mojoblocks.htm |
![]() Fri May 07, 2021 6:41 am
Posts: 1023 Location: Philadelphia |
![]() 1958 Allstate 177VMC, 2005 70cc Yamaha Vino
I added lock washers and nylock nuts just to be safe with mine but the tire install took all of 5 mins with only one curse word... Unless you're into S&Ming your wheels? I dunno what you dudes/dudettes do in your own time! |
![]() Fri May 07, 2021 7:05 am
Posts: 6242 Location: Nashville |
FridayMatinee wrote: Any reason why no one is using SIP or FA Italia split rims? The 2 piece jawns? Do you have links for SIP of FA Italia's versions? |
![]() Fri May 07, 2021 7:46 am
chandlerman wrote: I thought that only Pinasco was doing the tubeless split rims. They're good (I have a couple sets), but pricy and heavier than the non-split versions if you're into weight shaving. Also, can only run 3.5x10 on them. Do you have links for SIP of FA Italia's versions? http://www.scootermercato.com/Scooter-Parts/Rims/5581 They didn't seem much heavier than the original 8" rims honestly. I didn't weigh them though. Coulda sworn SIP made them too but I can't find them now. I may have fever dreamed that? |
![]() Fri May 07, 2021 8:05 am
![]() Fri May 07, 2021 8:18 am
FridayMatinee wrote: Any reason why no one is using SIP or FA Italia split rims? The 2 piece jawns? I added lock washers and nylock nuts just to be safe with mine but the tire install took all of 5 mins with only one curse word... Unless you're into S&Ming your wheels? I dunno what you dudes/dudettes do in your own time! |
![]() Fri May 07, 2021 11:22 am
Christopher_55934 wrote: I can't seem to find a wider split rim in tubeless, going with a 2.50 x 11 tubeless. Supposed to fit with no modifications. I want the wider tubeless as I've been told they feel more planted or stable at 60 mph. If I had it to do over, I'd go with 110's, but I'm certainly not feeling any need to switch them out before they're worn out. |
![]() Fri May 07, 2021 12:27 pm
P125x (4KW Hub Motor)
Posts: 409 Location: Alexandria, VA |
swiss1939 wrote: I've been eyeing this since that guy destroyed my tires. https://www.nomartirechanger.com/tc-ch100hd.html ![]() |
![]() '74 50s x3 '78 P200 E '84 Cosa '91 PK50XL2 '58 AllState '68 Sprint '80 50special and a '66(?) Super125
Posts: 8704 Location: seattle/athens |
![]() Fri May 14, 2021 11:49 am
Posts: 8241 Location: San Francisco |
V oodoo wrote: What about the Pinasco split tubless rims and save all the hassle? Anybody here using? Seems like a well made setup, a good review can be found here : https://scooterlab.uk/pinasco-tubeless-vespa-wheel-rims-fitted-testedreview/ I should try them on my small frame. |
![]() Sat May 15, 2021 6:27 am
oopsclunkthud wrote: I have a set of Pinasco sitting on the shelf unused. the studs on the rally are not long enough to mount them, or any of the other aluminum rims. I should try them on my small frame. Last edited by Christopher_55934 on Sat May 15, 2021 10:51 am; edited 1 time in total |
![]() Sat May 15, 2021 6:42 am
![]() Sat May 15, 2021 10:52 am
SaFiS wrote: A friend brought me this PX200 today, saved from the junkyard. He was going to keep it, but since it's a no e-start motor, he passed it on to me. For only 200EUR it was a no-brainer. Although engine is frozen, I don't believe it's going to be terrible inside. Whatever the outcome, 200EUR don't buy you new engine cases plus I get a complete front end. I'm going to strip it tomorrow and report... ![]() ![]() ![]() ![]() |
![]() Sat May 15, 2021 11:25 am
Christopher_55934 wrote: These look interesting, when working by hand. https://www.cyclegear.com/accessories/motion-pro-rimshield-ii I'm getting a Harbor Freight version, of a tire changer. Last time I had to get a tire off a split rim I got annoyed and had a workout. Bead refused to let go. The built in bead breaker would have been great. Going to try Mojo bars and blocks to protect the rims. https://www.mojotiretools.com/mojoweb.htm Mojo blocks https://www.mojotiretools.com/mojoblocks.htm |
A few photos of the motor... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Mixed up another batch and shot a third coat of catalyzed clear over the first two, and crossed fingers. Success! The catalyst in the third coat set off the others, and finish is rock hard. ![]() ![]()
Positive
![]() Mon Jun 14, 2021 7:46 am
Posts: 3211 Location: california |
Safis - nice find. Gotta like the spare EFL gearbox alone. That motor looks like it got absolutely cooked - seat must be full of urine, just throw it away. 🙂 Love the offie chair idea. Yes! |
![]() VNB vsc o9c VMA vbc VSX
Posts: 6294 Location: Hustletown, TX |
![]() 73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 Elite 80,90 V5N 50, 01 ET2, 2015 HD Road Glide Special, 2011 Ural Tourist
Posts: 4416 Location: Oceanside, CA |
![]() Check the 11 o’clock position |
![]() Sat Jul 10, 2021 3:49 pm
![]() '15 GTS300, '86 PX125EFL, '66 VBB, '04 Ninja 250
Posts: 6262 Location: San Diego, CA |
![]() Sun Jul 11, 2021 3:23 am
