Tue, 25 May 2021 04:06:10 +0000
Tue, 25 May 2021 04:06:10 +0000 quote
You can find a non p side stand or a Mrp main stand offset on SIP and order from Mercato to avoid crazy shipping cost.
http://www.scootermercato.com/Scooter-Parts/Vintage-Vespa-Parts/SIP-Part
Tue, 25 May 2021 05:13:13 +0000
1963 VBB2T
1963 VBB2T
Tue, 25 May 2021 05:13:13 +0000 quote
FNG wrote:
My SIP Road 2 fits nicely but I haven't gone 2up with it yet.
I also had my new rear shock at its highest setting as well. It's fine with just myself but I bet it's close when I go into the corners.
Tue, 25 May 2021 13:04:46 +0000
Thu, 27 May 2021 15:39:18 +0000
1960 Allstate VNA, 1962 VNB
Thu, 27 May 2021 15:39:18 +0000 quote
Thanks rowdyc.
I found the side stand in stock at Marcato. So that will get me going next week sometime.
Also I ordered the MRP main stand offset from ScooterSpeed. I think this is the option I will end up using but I'll decide after looking at both.
Thu, 03 Jun 2021 04:14:00 +0000
Thu, 03 Jun 2021 04:14:00 +0000 quote
I got home from work today and the side stand had arrived from Mercato.
After wrestling with it for a while I finally finished the install and it was time for a ride.
First ride with the sprint veloce cases, VMC 177 Stelvio, Pinasco 24 ER carb Pinasco ignition and Polini box exhaust.
I took it easy to break it in but boy does it feel fast. This thing is going to go.
I did suffer one setback. It blew the pilot light, headlight and tail light. I must have some wires connected to the regulator incorrectly.
It got dark so I had to stop playing with it. Time to order more 12v bulbs. Not sure why I didn't order more than 1 set in the first place.
Sun, 11 Sep 2022 19:33:33 +0000
Sun, 11 Sep 2022 19:33:33 +0000 quote
My shift housing on my VNB is touching on the exhaust and melting slightly.
Is my housing too long or did I route it incorrectly?
Thank for your help.
Sun, 11 Sep 2022 20:16:46 +0000
Sun, 11 Sep 2022 20:16:46 +0000 quote
pull the locating bracket up and out a little and that should give you the clearance you need.
Sun, 11 Sep 2022 21:12:31 +0000
Sun, 11 Sep 2022 21:12:31 +0000 quote
This thing?
Thank you Mr G
Sun, 11 Sep 2022 21:20:57 +0000
Sun, 11 Sep 2022 21:20:57 +0000 quote
That did the trick.
Thanks again.
Mon, 12 Sep 2022 06:14:31 +0000
Mon, 12 Sep 2022 06:14:31 +0000 quote
No, that ain't right. The cables go behind the pipe. It should be more or less a straight shot from the frame. No big wavy bends in the cables.
Mon, 12 Sep 2022 06:21:13 +0000
Mon, 12 Sep 2022 06:21:13 +0000 quote
oh duh! he said it was a small block! gah, I'll wake up here in a bit.
yeah, socal is right- behind the pipe on the small block.
Mon, 12 Sep 2022 14:01:30 +0000
Mon, 12 Sep 2022 14:01:30 +0000 quote
TIL I have the shift cables run wrong on every bike I own.
Tue, 13 Sep 2022 01:28:52 +0000
Tue, 13 Sep 2022 01:28:52 +0000 quote
Thanks SoCal.
It looks much better now.
⬆️    About 10w elapsed between posts    ⬇️
Sun, 20 Nov 2022 21:36:19 +0000
Sun, 20 Nov 2022 21:36:19 +0000 quote
On yesterday's SLO county ride someone told me that my fork is bent.
I thought it just looks wrong because of the repop mudguard.
What do you guys think?
Mon, 21 Nov 2022 03:03:03 +0000
Mon, 21 Nov 2022 03:03:03 +0000 quote
Is the mud guard rubbing against the leg shield?
Mon, 21 Nov 2022 03:40:11 +0000
Mon, 21 Nov 2022 03:40:11 +0000 quote
No. There is about 8mm of clearance.
Mon, 21 Nov 2022 16:22:53 +0000
Mon, 21 Nov 2022 16:22:53 +0000 quote
If it's bent, it's not bent much, or not bent in line front-to-back.
It's actually easier to tell in a picture like that if you can see the headset, too.
And for side-to-side bent (like when it gets bent with the wheel over while parked), take a picture from the front and you can see it that way.
Tue, 22 Nov 2022 05:39:33 +0000
Tue, 22 Nov 2022 05:39:33 +0000 quote
Thank you.
I'll get some better pictures on Wednesday.
[ Time: 0.0682s ][ Queries: 6 (0.0390s) ][ Debug on ][ 276 ][ Thing Two ]
