![]() Sat May 29, 2021 10:26 pm
Vespa ET3 & Vespa PX150 & Vespa GTS 300
Posts: 1638 Location: Berlin |
![]() Vespa ET3 & Vespa PX150 & Vespa GTS 300
![]() GTS300 Super (Heinz) GTS250 Super (Bulger)
Posts: 4240 Location: Tempe, AZ |
Syd wrote: I like the new? login form - it looks nicely framed. Not so sure about the forums though. The framed look takes up over an inch of screen space. I'll get used to it, of course, it surprised me, is all. |
It's not that I'm framing the page, exactly. I am limiting the maximum width of the page so that it doesn't end up looking ridiculous on big monitors. I'm currently using a nice round 1000 pixels as the target, but that might be (as Jim has pointed out) a scoche on the small side. We're still experimenting.
This is what I'm trying to avoid: ![]() |
![]() VSX, Stella 177, Stella 150, VNX1T, V9A1T, V9B1T
Posts: 3846 Location: Staten Island, NY |
jess wrote: It's not that I'm framing the page, exactly. I am limiting the maximum width of the page so that it doesn't end up looking ridiculous on big monitors. I'm currently using a nice round 1000 pixels as the target, but that might be (as Jim has pointed out) a scoche on the small side. We're still experimenting. This is what I'm trying to avoid: Everything up through members is aligned left, everything after members aligns right, leaving a big ole empty gap between half the menu options. Chrome user here. ![]() |
swiss1939 wrote: I like the page outline as mentioned earlier, but it appears your page width restrictions are causing some strange column alignment issues in the menu. Everything up through members is aligned left, everything after members aligns right, leaving a big ole empty gap between half the menu options. Chrome user here. Coding as fast as I can here. |
I've bumped up the max width to 1280 pixels. This should end up with only a small adornment on the sides of all but the largest tablets in landscape mode. On desktops, the fill on the sides will be more apparent when the window gets larger than 1280.
I've adjusted some things as the page gets smaller, too -- I am working toward better mobile support, and the minimum width of the page is now a little better than it was. But still not there yet. There are a lot of elements that need to adjust to a narrow page size, and I'm still working through the list. |
jess wrote: No, that's on purpose. And still a work in progress. I've isolated all the user-specific things on the right, and all general navigation on the left. Some of those items on the right are going to collapse under a user menu on the far right-hand edge (where "log out" currently resides) much like many other websites. Coding as fast as I can here. |
![]() Mon May 31, 2021 3:00 am
Posts: 1594 Location: Lancaster, U.K. |
![]() GTS 300ie Touring 2013 - Signora D'argento & GTS 300ie HPE 2022 - Regina Arancione.
Feedback
jess wrote: I am working toward better mobile support, and the minimum width of the page is now a little better than it was. But still not there yet. There are a lot of elements that need to adjust to a narrow page size, and I'm still working through the list. ![]() ![]() |
![]() In garage: Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956
Posts: 8291 Location: Latina (Italy) |
jess wrote: Turn your tablet to portrait mode and you'll see that it's not framing, it's fill. Touring300 wrote: The width is fine for my laptop, but on my mobile phone the page goes from being too large to too narrow..... |
Re: Feedback
Touring300 wrote: The width is fine for my laptop, but on my mobile phone the page goes from being too large to too narrow..... I would argue that it's the browser that is at fault here, but that's ultimately a losing argument. One more thing in a long list of things that break on mobile that I need to figure out how to address. In any case, until I reformat topics to put the author information above the post instead of to the left, the experience on mobile in portrait mode is going to suck anyway. And I can't really do that until I address the menu width at the top of the page, which can only reduce to about 650 pixels wide before the two halves of the menu start running into each other. So basically, I need to change everything |
Re: Feedback
jess wrote: This effect is caused, on that particular page, by a long link pasted directly into a post. The link has no place to wrap, and so a single post becomes very wide. The browser then uses the width of that single (widest) post as the width for the entire page, and scales everything to that. I would argue that it's the browser that is at fault here, but that's ultimately a losing argument. One more thing in a long list of things that break on mobile that I need to figure out how to address. In any case, until I reformat topics to put the author information above the post instead of to the left, the experience on mobile in portrait mode is going to suck anyway. And I can't really do that until I address the menu width at the top of the page, which can only reduce to about 650 pixels wide before the two halves of the menu start running into each other. So basically, I need to change everything In twenty-five years of surfing the internet "I have seen things you humans could not imagine, fighting ships ablaze off the Orion ramparts. And I have seen B-rays flashing in the dark near the gates of Tannhäuser ..!" |
![]() Gigi, '13 GTS 300ie Touring
Posts: 2265 Location: Phoenix, AZ. |
Re: Feedback
jess wrote: This effect is caused, on that particular page, by a long link pasted directly into a post. The link has no place to wrap, and so a single post becomes very wide. The browser then uses the width of that single (widest) post as the width for the entire page, and scales everything to that. I would argue that it's the browser that is at fault here, but that's ultimately a losing argument. One more thing in a long list of things that break on mobile that I need to figure out how to address. In any case, until I reformat topics to put the author information above the post instead of to the left, the experience on mobile in portrait mode is going to suck anyway. And I can't really do that until I address the menu width at the top of the page, which can only reduce to about 650 pixels wide before the two halves of the menu start running into each other. So basically, I need to change everything |
![]() Mon May 31, 2021 7:13 am
Thanks for the virtual beverages, all!
I've just pushed a change that fixes one of those too-wide-everything-breaks issues, though it was most acute for iOS users. Android users might not notice. The issue was YouTube videos, which had a fixed width. Looked great on desktop, not so much on mobile. Apparently YouTube videos are one of the notorious problems for responsive liquid design, as the video embed requires fixed dimensions in order to maintain the aspect ratio. Fortunately, there are some tricks that we can play with HTML to force the videos to resize to fit the available space, instead of overflowing the edges. One more thing off the list. |
![]() 2009 GTV250 (Gone), 2003 Inder trailer, 2001 BMW R1100RT
Posts: 5442 Location: Santa Cruz California |
I've pushed another fix to force long lines inside posts to wrap, whether they want to or not. This includes long links pasted into a message.
That plus the YouTube change I pushed earlier should fix most of the places where a single post can get excessively wide, though there are undoubtedly others. |
portofino green GTV 300
Posts: 1363 Location: w.ma. Northampton |
![]() 2020 Honda NC750DCT ABS
Posts: 6887 Location: Maple Grove, MN |
I'm going some final testing on a new feature that's been in the works for a while now: Notifications!
That sounds boring, right? Actually, I'm pretty enthusiastic about this change. I think it's going to provide feedback to those who post in ways that we've never really had at MV before. Soon, soon. Still shaking out the last few bugs. |
My phone is an Android using Chrome (happy to give exact version details, if needed). The recent MV updates for mobile make it much easier to read!!
![]() ![]() I will say that it does look awkward though, as the left side with the posters' profiles take up about 2/3 of the width of the page. Would simply shrinking the profile pics a bit help solve that, or would you need to mess around with tables or something else equally annoying (my programming knowledge stopped after HTML 4)? Otherwise, what you changed seems to be working pretty well for most threads. YouTube doesn't break it, but extra wide images and long links still do.
Positive
Witch wrote: My phone is an Android using Chrome (happy to give exact version details, if needed). The recent MV updates for mobile make it much easier to read!! ![]() ![]() Witch wrote: I will say that it does look awkward though, as the left side with the posters' profiles take up about 2/3 of the width of the page. Would simply shrinking the profile pics a bit help solve that, or would you need to mess around with tables or something else equally annoying (my programming knowledge stopped after HTML 4)? Otherwise, what you changed seems to be working pretty well for most threads. YouTube doesn't break it, but extra wide images and long links still do. Ultimately, I am going to try to have one version of the website that serves desktop and mobile equally well, reducing the amount of "stuff" as the screen size gets smaller. It is, unfortunately, a slow and incremental process. For tall narrow layouts (e.g. a mobile phone) the author information will move above the post, instead of next to it. It's already like this on the stripped-down iPhone version of the website -- I just need to make the main website adapt itself automatically for any screen size. |
Eh, I figured it couldn't be something too terribly easy. I really haven't done much of anything programming-related since having to make both IE and Netscape happy, so I can imagine trying to acommodate multiple versions for different devices isn't even remotely as fun.
The first smartphone I ever got was an iPhone 3G, and for the few years I had it, I got spoiled being able to use MV so easily with that format, lol. It took me a few weeks to remember that you only had it set for iPhones as far as a special mobile layout when I got a different phone. ![]() |
Witch wrote: Eh, I figured it couldn't be something too terribly easy. I really haven't done much of anything programming-related since having to make both IE and Netscape happy, so I can imagine trying to acommodate multiple versions for different devices isn't even remotely as fun. It's much harder in that the expectations are now much higher. Mobile phones have become a dominant force, and sites must accommodate them or perish. Google punishes MV in search results because we don't have a mobile layout -- well, not one that Google cares about, anyway. The holy grail is called responsive design -- a site layout that can adapt to any screen size and still look good. I've only just begun that process, addressing the various things that screw up the layout on mobile. The current bane of my existence is Fuelly images in signatures, which make the page wider than it needs to be. After that it will be something else. Witch wrote: I still say that iPhone layout way back when I could actually use it was the most user-friendly forum I've ever encountered on mobile. Eventually, when the main site can adapt to any mobile phone, the iOS version will disappear. That's the goal, anyway. |
jess wrote: Scratch Fuelly images in signatures off the list. It was an easy fix. All images in signatures will now resize gracefully as the screen size gets smaller. Btw, im one of those fuelly signature users, but i chose to use the condensed version for that reason. |
