Sat Jun 12, 2021 1:30 pm
2021 Vespa GTS 300 Racing Sixties
Joined: 20 May 2021 Posts: 58 Location: Fountain Hills, AZ
This just may be a quirk of Piaggio engineering, but after I refuel my 2021 GTS 300 HPE the bars on the fuel gauge are. very. slow. to. show. a. full. tank. It takes about 20 minutes of riding before all the bars fill in to show a full tank.
I'm new to scootering but I would have thought the fuel gauge would show a full tank right after refueling, just like a car does. I know that I have a full tank so there's no problem with waiting to see the bars slowly fill in (it's the simple pleasures in life that are best!) But I was wondering if other's Vespa fuel gauges act like this.
I'm going in for my 600 mi service next week and I thought I'd check the forum experts to see if this is normal or not. Thanks!
Sat Jun 12, 2021 5:00 pm
Xevo 250 ie
Joined: 12 Jun 2008 Posts: 1545 Location: Sunshine Coast, Australia
Xevo 250 ie
Not normal. Your fuel level sender float is sticking. It needs more up and down action !
You need to fill and then empty the tank repeatedly to free it up a little.
Lots of riding for you then!
Sat Jun 12, 2021 5:12 pm
Joined: 29 Dec 2007 Posts: 12586 Location: Oregon City, OR
I don't believe the newer bikes use a mechanical float valve. I believe they use an electronic sensor. Mine reacts fairly slowly as well (though not 20 minutes).
Sat Jun 12, 2021 6:53 pm
I agree about needing more riding!!!
I'll mention it to the mechanic when I go in for service. Not a big deal but a little bit odd. Other than that, the scooter has been great.
Sat Jun 12, 2021 6:58 pm
Xevo 250 ie
Xevo 250 ie
My float is stuck on my GTS. I've been using the trip meter for a fuel gauge since I got the bike 4 years ago.
Wed Jun 16, 2021 5:42 pm
FYI, I asked the service techs at my 600 mile service about the slow rise of the bars on the fuel gauge after a fill-up. They said it's normal and designed that way so that the bars don't change if you ride uphill or downhill. The bars thereby reflect your fuel level more accurately.
Wed Jun 16, 2021 6:17 pm
2020 GTS 300 hpe Touring
Mine shows full immediately. I think they fed you a line.
Wed Jun 16, 2021 6:45 pm
2020 GTS 300 HPE
Joined: 24 Mar 2018 Posts: 1133 Location: south Texas
2020 GTS 300 HPE
grouper wrote: Mine shows full immediately. I think they fed you a line.
Yep. My 2020 HPE shows full as soon as I start it up after fueling. I need to get some more miles on this one - it is about 15 to 20 mpg less than my 2009 GTS (which opened up nicely after about 3,000 miles).
Wed Jun 16, 2021 9:53 pm
2020 GTS 300 Super Tech
Turn the ignition off and then back on. Happens with mine also and that's what gets the correct reading, if not I have to ride it a few miles for it to catch up. Weird but not a real problem
Wed Jun 16, 2021 11:25 pm
2020 GTS 300 HPE
Joined: 27 Sep 2019 Posts: 851 Location: San Francisco
2020 GTS 300 HPE
Mine is sometimes down by a bar after a fillup, but it usually rights itself by the time I get home.
Thu Jun 17, 2021 7:41 am
2020 GTS300 HPE "Whiskers"
Mine reads full right away.
Thu Jun 17, 2021 8:04 am
GT 2.4
GT 2.4
Who knows if they have more than one supplier for the level sensor, etc...
It sounds like the level sensor is working, just not like you think it should. When they are broken, they do a lot more interesting things. The problem with trying to compare what you have to other owner's experiences is that most of the responses are going to come from people who do not have your model and don't know if it's normal or not. Some people hit the kill switch and fill up, others turn the ignition off, then fill up. Some jump back on, start it up and take off, others leisurely put their gloves and helmet back on, wander around for ten minutes, get on the bike, check everything they possibly can, take their gloves back off and post their mileage and fuel purchase on their smartphones, then start it up and leave at a measured pace. Lots of variables.
At the dealership, they see enough of these bikes to know when one works or doesn't work. One of my cars takes what I swear is about half an hour, though I've never timed it, and if I did, it might be all of five minutes, but it sure seems like half an hour or even longer, for the fuel level to show after I fill it. I don't know why.
Thu Jun 17, 2021 11:23 am
I usually just hit the kill switch when I fill up, I don't turn off the ignition key. I may try turning off the key next time to see if the gauge reads full immediately. I have a 2021 GTS and maybe the fuel gauge hardware is different from the 2020s. Funny how these little things are different from scooter to scooter.
If this is the worst "problem" I have with the scooter, I'll be living a charmed life.
Thu Jun 17, 2021 11:30 am
[/quote]
Amen to that
Thu Jun 17, 2021 11:46 am
Joined: 21 Jul 2007 Posts: 8291 Location: Latina (Italy)
To see what kind of level detection system your Vespa uses, simply look at the exploded drawing in a spare parts list.
Thu Jun 17, 2021 12:09 pm
2020 Vespa GTS HPE 300 Touring, Verde Bosco, Akrapovic, Uprgaded Whistler Wheel, Vespa 36L Top Case, Euro turn indicators. Stock 1962 VBB1.
Mine has the same behavior as the OP (2020 HPE). After I ride a little it normalizes.
Fri Jun 18, 2021 3:15 am
2021 GTS 300 Racing Sixties
Joined: 05 Jun 2021 Posts: 5 Location: Northeast Ohio
I have a 2021 GTS 300 HPE and my fuel gauge reads full instantly after fill up.
Fri Jun 18, 2021 3:25 am
GTS 250, Sprint 150 & HPE Tech
Joined: 29 Jul 2008 Posts: 625 Location: Lehigh Valley, PA
FWIW, my 2020 HPE Tech takes 5-10 mins to reflect refueling when doing a full refuel. I've not paid attention on a top off though.
Fri Jul 02, 2021 5:53 pm
I thought I'd post a followup.
If I leave the ignition key on when fueling up, the bars are very slow to increase to show a full tank (10+ minutes of riding).
But if I turn the ignition key to off, then fuel up, when I turn the key back on, the bars show full gas immediately.
Fri Jul 02, 2021 6:45 pm
2010 GTS 300 Super
Joined: 29 Jun 2021 Posts: 16 Location: San Diego, CA
2010 GTS 300 Super
haha my 2010 will show a full tank and if i go full throttle it will dip down to half a tank until the fuel stops sloshing haha
Sat Aug 14, 2021 6:15 pm
2012 GTV 300 & 2021 GTS 75th Anni.
I have 900 miles on my 2021 GTS 300 75th and the fuel gauge is not reading accurately. I have a full tank and the indicator says "Refill Fuel" and blinks. Had been working accurately til now. The local dealer says they've had 3 customers this month report similar malfuntion but I'm not certain if they were 300's too. Hoping it's just the sensor.. Warranty will fix it.
Sun Aug 15, 2021 10:04 am
I hope it is just the sensor, should be an easy fix for the dealer (if they have the parts).
BTW, I lived in Irvine for 30 years before moving to Arizona. Happy riding!
Sun Aug 15, 2021 10:10 am
Seal, Huntington, Laguna, Balboa, … all the beaches within. 30 minutes of lane splitting from Irvine. Didn’t even realize that before I moved here a few months ago. But maui living, riding a Vespa to work along the coast, that’s where it’s at. But Beware of the tourist whale-spotters driving you off the road.🤣
Mon Aug 16, 2021 3:59 am
Vespa Elettrica, GTS 300 HPE
Joined: 20 Oct 2020 Posts: 97 Location: Austin, TX USA
StartMeUp wrote: I have 900 miles on my 2021 GTS 300 75th and the fuel gauge is not reading accurately. I have a full tank and the indicator says "Refill Fuel" and blinks. Had been working accurately til now. The local dealer says they've had 3 customers this month report similar malfuntion but I'm not certain if they were 300's too. Hoping it's just the sensor.. Warranty will fix it.
Mine is doing the same. Going in for warranty service soon.
Mon Aug 16, 2021 6:21 am
StartMeUp wrote: Seal, Huntington, Laguna, Balboa, … all the beaches within. 30 minutes of lane splitting from Irvine. Didn't even realize that before I moved here a few months ago. But maui living, riding a Vespa to work along the coast, that's where it's at. But Beware of the tourist whale-spotters driving you off the road.🤣
I wish I could have ridden the Vespa to these areas when I lived in Irvine. I used to ride a bicycle to them, but riding a Vespa is doing it in style! There are lots of rides in greater Phoenix and a great scooter club to hang out with.
Mon Aug 16, 2021 6:33 am
Primavera 150
Joined: 14 Jul 2021 Posts: 102 Location: Monument, Colorado
Primavera 150
SPRider wrote: I wish I could have ridden the Vespa to these areas when I lived in Irvine. I used to ride a bicycle to them, but riding a Vespa is doing it in style! There are lots of rides in greater Phoenix and a great scooter club to hang out with.
I used to ride my 1969, 250 Triumph, through the orange groves on Irvine Ranch. When it was rumming, which was not often.
Mon Aug 16, 2021 10:03 am
rottekatz wrote: I used to ride my 1969, 250 Triumph, through the orange groves on Irvine Ranch. When it was rumming, which was not often.
Not many orange groves in Irvine anymore!
Sun Aug 22, 2021 7:38 pm
Ok, the fuel gauge thing may have fixed itself. 40 miles, no problems. Fingers crossed!
Tue Oct 19, 2021 4:29 am
2021 Vespa GTS 300
Joined: 14 Oct 2021 Posts: 1 Location: Rhode Island USA
2021 Vespa GTS 300
Don't feel too bad. The fuel gauge on my 2021 GTS worked for about a day then stopped working at all.
