Created article What are all the Forum Awards & How do I get them?
![]() 2006 LX150 (carbed) | 2007 GT200
Posts: 1849 Location: Toronto |
Mon, 21 Jun 2021 16:32:09 +0000
quote
Positive
![]() 0:7 And counting
Posts: 35579 Location: Bay Area, California |
Mon, 26 Dec 2022 02:46:38 +0000
quote
Here are some reasonably-sized versions of the award artwork. I'll leave it up to berto as to whether to include it in the article or not.
Mon, 26 Dec 2022 02:51:25 +0000
quote
jess wrote: Here are some reasonably-sized versions of the award artwork. I'll leave it up to berto as to whether to include it in the article or not.
Positive
Tue, 27 Dec 2022 12:42:54 +0000
quote
Tue, 27 Dec 2022 15:59:29 +0000
quote
Hmmm. Might have broken something. When was the last time an article got successfully edited?
(There is no large artwork for the TP award. Plus, we don't talk about it).
Positive
Tue, 27 Dec 2022 18:03:32 +0000
quote
I was able to edit the existing article, and added the word "test" at the bottom. No issues. If you do have the text you tried to post, can you stick it in a post here on the discussion side? If it doesn't post here, there's definitely something wrong with it, though not sure what yet.
Tue, 27 Dec 2022 22:01:30 +0000
quote
jess wrote: I was able to edit the existing article, and added the word "test" at the bottom. No issues. If you do have the text you tried to post, can you stick it in a post here on the discussion side? If it doesn't post here, there's definitely something wrong with it, though not sure what yet. I've attached the html and SQL, if it helps. ![]() txt
522kb
txt
522kb
Tue, 27 Dec 2022 22:15:36 +0000
quote
Testing 6:
(Judy's) Red Toaster -- Posthumously awarded to our very own Judy Rossman in remembrance of her contributions here. An homage to her long-standing red toaster avatar. ![]() |
Tue, 27 Dec 2022 22:18:51 +0000
quote
Okay, the problem is with the name of the attachment that's already been uploaded. It gets converted to an attachment tag (instead of a url) along with the original filename, which included an apostrophe. The apostrophe isn't getting escaped properly, leading it to barf on the SQL.
So a temporary fix is that I've taken the apostrophe out of the name of the original file upload -- if you quote my post above, you'll see an attachment tag, along with the name of the file, sans an apostrophe. The correct fix is to figure out at what point that apostrophe needs escaping. It obviously made it into the attachment database with no problem -- my guess is that the conversion of an URL to an attachment tag needs some attention. |
Tue, 27 Dec 2022 22:19:19 +0000
quote
Oh, and you should be able to repost now. If you get another error, there's likely another apostrophe somewhere.
Tue, 27 Dec 2022 22:57:37 +0000
quote
Okay, the correct fix is now also in place. Apostrophes in the filenames of attachment tags are now correctly escaped, and shouldn't produce any more errors.
Thanks much for pointing out this problem!
Positive
Tue, 27 Dec 2022 23:40:11 +0000
quote
jess wrote: Okay, the correct fix is now also in place. Apostrophes in the filenames of attachment tags are now correctly escaped, and shouldn't produce any more errors. Thanks much for pointing out this problem! ![]() ![]()
Positive
Tue, 03 Jan 2023 02:14:58 +0000
quote
jess wrote: New award artwork. This is the "Broken Piston Award".
Positive
