Sat, 03 Jul 2021 12:43:12 +0000
GTS 250
GTS 250
Sat, 03 Jul 2021 12:43:12 +0000 quote
So I have bought my oil and my new red chilli Malossi filter for my GTS250. Today was going to be a simple oil drain/replace filter job.
But oh no!! It seems like I am now going to have to completely remove my PM Tuning exhaust pipe in order to do this!!
Bummer!!!
Sat, 03 Jul 2021 12:52:18 +0000
Sat, 03 Jul 2021 12:52:18 +0000 quote
Remove the old filter with pliers. You don't care if you scratch or bend the old one. Replace with a filter with a hex nut on the end, like a HF-197.
Sat, 03 Jul 2021 12:59:31 +0000
GTS 250
GTS 250
Sat, 03 Jul 2021 12:59:31 +0000 quote
Hi - the picture doesn't really do the issue justice. The oil drain bolt is snug up against the tail pipe, so I can't remove either it or the oil screen tube properly. Grrr.
Sat, 03 Jul 2021 13:06:56 +0000
Sat, 03 Jul 2021 13:06:56 +0000 quote
I see. Maybe you can just loosen the exhaust enough to get the filter off. Good luck!
Sat, 03 Jul 2021 13:51:14 +0000
Sat, 03 Jul 2021 13:51:14 +0000 quote
Lame design but you gotta remove the exhaust on the LXs too.
Sun, 04 Jul 2021 01:50:33 +0000
Sun, 04 Jul 2021 01:50:33 +0000 quote
Isn't the proximity of that hot exhaust doing your engine oil (and engine) no good at all?!
Sun, 04 Jul 2021 03:38:28 +0000
Sun, 04 Jul 2021 03:38:28 +0000 quote
Do you mean if an aftermarket pipe is installed?
I almost always leave the (OEM) exhaust in place when I change oil on my LX. It's tight, but there's enough room.
Sun, 04 Jul 2021 04:19:21 +0000
Sun, 04 Jul 2021 04:19:21 +0000 quote
They're all tight. I got sick of fighting the exhaust so they all come off now. Gives me more access for the gear oil change too.
O.S.- how could the exhaust piping cause harm to the engine oil/ engine? I'd seriously doubt any radiant heat from the piping could go through the air, into the oil filter and then break the oil down prematurely. How is the exhaust routed on your Liberty 150?
Sun, 04 Jul 2021 12:04:29 +0000
Sun, 04 Jul 2021 12:04:29 +0000 quote
We Liberty owners do not have to remove the exhaust to change the oil or the filter.
[ Time: 0.0334s ][ Queries: 6 (0.0085s) ][ Debug on ][ 276 ][ Thing Two ]
