But oh no!! It seems like I am now going to have to completely remove my PM Tuning exhaust pipe in order to do this!!
Bummer!!!
![]() Sat, 03 Jul 2021 12:43:12 +0000
GTS 250
Posts: 13 Location: Sussex, England |
![]() GTS 250
quote
So I have bought my oil and my new red chilli Malossi filter for my GTS250. Today was going to be a simple oil drain/replace filter job.
But oh no!! It seems like I am now going to have to completely remove my PM Tuning exhaust pipe in order to do this!! Bummer!!! ![]() ![]() |
![]() BV350, Primavera 150, Yamaha Zuma 125
Posts: 3831 Location: Twin Cities, Minnesota |
Sat, 03 Jul 2021 12:52:18 +0000
quote
Remove the old filter with pliers. You don't care if you scratch or bend the old one. Replace with a filter with a hex nut on the end, like a HF-197.
![]() Sat, 03 Jul 2021 12:59:31 +0000
GTS 250
![]() GTS 250
quote
JKJ-FZ6 wrote: Remove the old filter with pliers. You don't care if you scratch or bend the old one. Replace with a filter with a hex nut on the end, like a HF-197. |
Sat, 03 Jul 2021 13:06:56 +0000
quote
I see. Maybe you can just loosen the exhaust enough to get the filter off. Good luck!
![]() 73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 90 V5N 50, 01 ET2, 2015 HD Road Glide Special
Posts: 4527 Location: Oceanside, CA |
![]() Sun, 04 Jul 2021 01:50:33 +0000
Posts: 1906 Location: Ohio |
![]() 2018 LIBERTY 150S, 2013 Kymco LIKE200iLX
quote
Isn't the proximity of that hot exhaust doing your engine oil (and engine) no good at all?!
O.S. |
![]() 2006 LX150 (carbed) | 2007 GT200
Posts: 1765 Location: Toronto |
Sun, 04 Jul 2021 03:38:28 +0000
quote
MJRally wrote: Lame design but you gotta remove the exhaust on the LXs too. I almost always leave the (OEM) exhaust in place when I change oil on my LX. It's tight, but there's enough room. |
Sun, 04 Jul 2021 04:19:21 +0000
quote
berto wrote: Do you mean if an aftermarket pipe is installed? I almost always leave the (OEM) exhaust in place when I change oil on my LX. It's tight, but there's enough room. O.S.- how could the exhaust piping cause harm to the engine oil/ engine? I'd seriously doubt any radiant heat from the piping could go through the air, into the oil filter and then break the oil down prematurely. How is the exhaust routed on your Liberty 150?
Positive
![]() Sun, 04 Jul 2021 12:04:29 +0000
quote
MJRally wrote: They're all tight. I got sick of fighting the exhaust so they all come off now. Gives me more access for the gear oil change too. O.S.- how could the exhaust piping cause harm to the engine oil/ engine? I'd seriously doubt any radiant heat from the piping could go through the air, into the oil filter and then break the oil down prematurely. How is the exhaust routed on your Liberty 150? O.S. |
