Piaggio mp3 300
Piaggio mp3 300
Is it any possibility of chip tuning this bike? Or any other possibility to increase the power in any other way?
I have just bought a mp3 300 bike and want to get some more power from the bike.
Does anyone know if it is possible and if yes who do I contact?
It is possibly to chip tune them, BUT how much extra do you expect to get from such a little lump? Besides, chip tuning almost always causes extra engine wear and fuel consumption.
If you're only after 1 or 2 extra ponies, then you're better off getting a good exhaust like a Akrapovic.
a exhaust won't give more then 0.2 HP to get the promised 2 hp you need to do a lot more like flown the head other intake andd stuff like that
yes its possible you will gain a bit, about 28hp on the crankshaft 22 on the rear wheel better option is buying a wrecked Front demaged Beverly 350 or X10 swap the engine and other stuff then you will have 32hp on the crank
2013 MP3 300ie
2013 MP3 300ie
Best bet is to fix the CVT first.
With a small engine like the 300, you'll waste a very noticable amount of power whenever the CVT can't keep RPM between 7000 and 7500 at full throttle - which, in the OEM setup, happens quite often..
For my 300, installing dr. Pulley sliders instead of the OEM rollers made a big difference.
(If these sliders wouldn't be available anymore, some day, i'd have to upgrade to a larger bike, since the OEM setup just doesn't cut it for me )
Did you bought Dr.pulley for Hpe 300 Mp3 engine? 2019-2021 model? And if yes which dr pulley? what kind of roller and weight? What did you gain?Lost? Thanks
[ Time: 0.0234s ][ Queries: 4 (0.0032s) ][ Debug on ][ 233 ][ Thing One ]
