jimc wrote:
Yup. Totally livable-with (is that a real phrase?).
![]() 1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
Posts: 1516 Location: Grand Rapids, MI |
Max6200 wrote: back to the incoming software update. This morning I see that the log off button has been replaced by my avatar picture. Nice! ![]()
Positive
seamus26 wrote: So, on a G4 iBook running Tiger and Firefox 3.6.28 things look a little wonky. I know ... it's an edge case, but I thought you'd want to know. |
![]() 2006 LX150 (carbed) | 2007 GT200
Posts: 1700 Location: Toronto |
Testing. Do the url tags stop working on an edit? Trying to reproduce what looked like an error when reply on another thread.
working: https://modernvespa.com/forum/post2483671 Added after selecting "edit" for my reply... not working (no link): https://modernvespa.com/forum/post2483671 not working (no link) Pirelli Angel Cannonball Report Both working properly. False alarm, I guess. Must be operator error.
Positive
ks7877 wrote: emoji bug? Was trying to end my last post, with multiple clap emojis - one emoji was inserted at the end of my post (where the cursor was and where I wanted it to appear) and the other two were inserted in front of the quote jess wrote: Known issue that I am declining to fix. Every time I touch that code, it gets worse. It’s very browser-specific and I am apparently too stupid to understand it. ![]() |
![]() Tue Jul 27, 2021 10:15 am
Tethys - 2012 GTS 300
Posts: 746 Location: Bowie, MD |
![]() LX190 Friday afternoon special, Primavera, some pushbikes
Posts: 8209 Location: Hermit Kingdom |
Posts: 3098 Location: Veria, Greece |
SaFiS wrote: Log in seems to be broken today on my iOS devices or maybe it's just related to Safari. I log in and I get redirected to the main page as a guest. Tried with WiFi & 4G to see if it was maybe IP related but it's not... |
![]() Fri Sep 03, 2021 5:07 am
Posts: 7008 Location: Madison, Wisconsin |
![]() MP3 500, GTS 250 (both 2008 MY), 2013 Piaggio BV 350, 2014 Can Am Spyder RT
jess wrote: Well that sucks. As a test, could you go to Safari settings and clear all website data? That will clear out ore-existing cookies and start fresh. If you recall, I had mentioned a similar problem where I couldn't stay logged in and then the problem would suddenly go away by its own. I don't know if it's my side or something else... |
SaFiS wrote: If you recall, I had mentioned a similar problem where I couldn't stay logged in and then the problem would suddenly go away by its own. I don't know if it's my side or something else... |
![]() '06 Vespa LX150, '07 Suzuki Burgman 400, '05 Honda Metropolitan
Posts: 3149 Location: Avon, Ohio (25 miles west of Cleveland) |
Just for reference:
I had the same thing happen on my iPhone with the current OS and Safari a couple of days ago. I tried several times during the day, and it simply went back to the "guest" welcome page. No login error or anything. I went to settings and cleared all data, and things worked as normal. |
Steve wrote: I had the same thing happen on my iPhone with the current OS and Safari a couple of days ago. I tried several times during the day, and it simply went back to the "guest" welcome page. No login error or anything. I went to settings and cleared all data, and things worked as normal. |
jess wrote: You don't block first-party cookies or anything, do you? There are definitely some sketchy bits of code that start getting used if the client doesn't accept cookies, and that code doesn't get tested very well.
Positive
SaFiS wrote: No, cookies are accepted for known & trusted sites... Sort-of related side-note: browsing anonymously (i.e. not logged in) no longer sets or requires cookies. We now track anonymous sessions solely via the IP address + user agent string, and that's really only to neutralize malicious actors. |
The only oddity I've seen, is that on iOS I occasionally get logged out. This has happened maybe four times since I started visiting here again. No problem, I simply log in again.
But when I do the forum options are limited to Started and Replied in portrait, and Watched, Started, and replied in horizontal. To get "New" to show up, I need to first go into any forum. Then, when clicking on "Forum", New shows up. Weird, but again, no problem, and certainly not worth chasing down. I just tried again to capture screen shots. ![]() ![]() |
Steve wrote: The only oddity I've seen, is that on iOS I occasionally get logged out. This has happened maybe four times since I started visiting here again. No problem, I simply log in again. But when I do the forum options are limited to Started and Replied in portrait, and Watched, Started, and replied in horizontal. To get "New" to show up, I need to first go into any forum. Then, when clicking on "Forum", New shows up. Weird, but again, no problem, and certainly not worth chasing down. The "New" link isn't showing up because when you log in, your last login time gets reset, and the "New" category is specifically posts that are new since your last login. |
Steve wrote: Possibly noteworthy, is that I also run all of AdGuard's content blockers, both on iOS and MacOS. |
I'm probably the only one, but figured I'd make the ask anyways...
I wonder if there's any support for adding an "are you sure?" window if user clicks "just walk away"? Current behavior is immediate cancelation of whatever user was typing. It hasn't happened to me yet, but I always get a little nervous clicking on "preview" or "submit" with these little mobile phone buttons and after I've suffered through tapping out a long message. |
berto wrote: I wonder if there's any support for adding an "are you sure?" window if user clicks "just walk away"? berto wrote: Current behavior is immediate cancelation of whatever user was typing. It hasn't happened to me yet, but I always get a little nervous clicking on "preview" or "submit" with these little mobile phone buttons and after I've suffered through tapping out a long message. I've added it to my long list of projects -- I want to stew on it for a bit on the off chance that there's a better option that satisfies all the requirements.
Positive
