Sun, 03 Jan 2010 18:23:20 +0000
Sun, 03 Jan 2010 18:23:20 +0000 linkquote
Created article Replacing the clock battery GT200
TB graciously gave permission to add his write up to the Wiki.
I'm still editing it at this point, but I wanted to get started working on it and still run downstairs from time to time to catch the Steelers game.
Sun, 03 Jan 2010 19:20:18 +0000
Sun, 03 Jan 2010 19:20:18 +0000 linkquote
OK, Done.
I have added the link to it under the DYI heading.
Unfortunately, the link looks out of place reading...
Replacing the Clock Battery GT200
instead of
GT200: Replacing the Clock Battery
which would be more in keeping with the format already established there. My bad. I should have checked first.
In any case, I tried to edit the title and/or the slug to change it with no luck. It wants to revert back. If anyone can fix this or let me know how to fix it myself, It would be appreciated. Thanks.
Mon, 04 Jan 2010 00:47:26 +0000
0:7 And counting
0:7 And counting
Mon, 04 Jan 2010 00:47:26 +0000 linkquote
Excellent! Nice work.
That top photo seems eerily familiar...
Fri, 05 Aug 2011 07:21:58 +0000
2004 GT200
2004 GT200
Fri, 05 Aug 2011 07:21:58 +0000 linkquote
Pics aren't loading
Please help! The links for the pics must be dead or something, as they're not loading. Looking forward to changing the battery to my newly acquired GT200.
Fri, 05 Aug 2011 15:03:05 +0000
Fri, 05 Aug 2011 15:03:05 +0000 linkquote
Looking into a solution....
Wed, 10 Aug 2011 09:03:44 +0000
2004 GT200
2004 GT200
Wed, 10 Aug 2011 09:03:44 +0000 linkquote
Thanks very much, just getting started with my GT200, really enjoying it so far, hoping start doing some work on it, taking it apart/ getting to know the scooter.
Looks like the battery is pretty deep within the headset. Is it the same procedure as other models like the LX150, etc.?
⬆️    About 36w elapsed between posts    ⬇️
Fri, 20 Apr 2012 00:12:02 +0000
GTS250 - GT200 - XJR1300
Fri, 20 Apr 2012 00:12:02 +0000 linkquote
The pictures seem to have all disappeared again. Is there a chance of reloading them? Or perhaps attaching them to the post? And is this pretty much the same procedure on a GTS250?
Mon, 06 May 2013 13:53:01 +0000
0:7 And counting
0:7 And counting
Mon, 06 May 2013 13:53:01 +0000 linkquote
Uploading pictures, courtesy of TB.
Mon, 06 May 2013 15:34:40 +0000
0:7 And counting
0:7 And counting
Mon, 06 May 2013 15:34:40 +0000 linkquote
Uploading more pics, these ones cover the removal of the headset.
Mon, 06 May 2013 16:02:34 +0000
0:7 And counting
0:7 And counting
Mon, 06 May 2013 16:02:34 +0000 linkquote
Unfortunately, there are still some missing pictures in this narrative. Not sure what to do about that.
Tue, 07 May 2013 09:59:19 +0000
2007 GT 200L
2007 GT 200L
Tue, 07 May 2013 09:59:19 +0000 linkquote
now I know where the battery is
thanks for the heads up on the battery. it would've been nice if they would've put the battery in an easier spot to get to like outside the instrument cluster for easy access.
Sun, 05 Oct 2014 18:03:19 +0000
LX150
LX150
Sun, 05 Oct 2014 18:03:19 +0000 linkquote
External battery / power supply to clock
Getting to the small watch battery in the instrument cluster was a time consuming chore. The second replacement opportunity on my LX150 begged for a more reasonable solution. After the disassembly to access the clock and it's removal from the cluster, I separated the halves of the clock case to expose the circuit board. The wires that I silver soldered to the battery terminals go to a AA battery holder epoxy bonded to the inside of the horn cover on the front of the scooter. This battery will supply power longer and replacement is now a matter of removing the badge and the one screw retaining the cover. If there is another project for the clock, I might add an LED lamp in the cluster to improve night viewing of the clock.
⬆️    About 7y elapsed between posts    ⬇️
Mon, 23 Aug 2021 13:30:51 +0000
0:7 And counting
0:7 And counting
Mon, 23 Aug 2021 13:30:51 +0000 linkquote
Uploading some photos to fix long-standing missing images.
Mon, 23 Aug 2021 13:39:17 +0000
0:7 And counting
0:7 And counting
Mon, 23 Aug 2021 13:39:17 +0000 linkquote
This article now has all of the images fixed, finally.
[ Time: 0.0484s ][ Queries: 4 (0.0271s) ][ Debug on ][ 240 ][ Thing Two ]
