NOTE: This topic has a wiki article associated with it. You may view it
here.
Sun Jan 03, 2010 10:23 am
Joined: 12 Nov 2005 Posts: 5145 Location: Pittsburgh, Pa.
Created article Replacing the clock battery GT200
TB graciously gave permission to add his write up to the Wiki.
I'm still editing it at this point, but I wanted to get started working on it and still run downstairs from time to time to catch the Steelers game.
Sun Jan 03, 2010 11:20 am
OK, Done.
I have added the link to it under the DYI heading.
Unfortunately, the link looks out of place reading...
Replacing the Clock Battery GT200
instead of
GT200: Replacing the Clock Battery
which would be more in keeping with the format already established there. My bad. I should have checked first.
In any case, I tried to edit the title and/or the slug to change it with no luck. It wants to revert back. If anyone can fix this or let me know how to fix it myself, It would be appreciated. Thanks.
Sun Jan 03, 2010 4:47 pm
Joined: 11 Oct 2005 Posts: 32715 Location: Bay Area, California
Excellent! Nice work.
That top photo seems eerily familiar...
⬆️ About 2 years elapsed between posts ⬇️
Thu Aug 04, 2011 11:21 pm
2004 GT200
2004 GT200
Pics aren't loading
Please help! The links for the pics must be dead or something, as they're not loading. Looking forward to changing the battery to my newly acquired GT200.
Fri Aug 05, 2011 7:03 am
Looking into a solution....
Wed Aug 10, 2011 1:03 am
2004 GT200
2004 GT200
Thanks very much, just getting started with my GT200, really enjoying it so far, hoping start doing some work on it, taking it apart/ getting to know the scooter.
Looks like the battery is pretty deep within the headset. Is it the same procedure as other models like the LX150, etc.?
⬆️ About 8 months elapsed between posts ⬇️
Thu Apr 19, 2012 4:12 pm
GTS250 - GT200 - XJR1300
Joined: 04 May 2009 Posts: 1424 Location: SW London, UK
The pictures seem to have all disappeared again. Is there a chance of reloading them? Or perhaps attaching them to the post? And is this pretty much the same procedure on a GTS250?
⬆️ About 1 year elapsed between posts ⬇️
Mon May 06, 2013 5:53 am
Uploading pictures, courtesy of TB.
Mon May 06, 2013 7:34 am
Uploading more pics, these ones cover the removal of the headset.
Mon May 06, 2013 8:02 am
Unfortunately, there are still some missing pictures in this narrative. Not sure what to do about that.
Tue May 07, 2013 1:59 am
2007 GT 200L
2007 GT 200L
now I know where the battery is
thanks for the heads up on the battery. it would've been nice if they would've put the battery in an easier spot to get to like outside the instrument cluster for easy access.
Sun Oct 05, 2014 10:03 am
LX150
LX150
External battery / power supply to clock
Getting to the small watch battery in the instrument cluster was a time consuming chore. The second replacement opportunity on my LX150 begged for a more reasonable solution. After the disassembly to access the clock and it's removal from the cluster, I separated the halves of the clock case to expose the circuit board. The wires that I silver soldered to the battery terminals go to a AA battery holder epoxy bonded to the inside of the horn cover on the front of the scooter. This battery will supply power longer and replacement is now a matter of removing the badge and the one screw retaining the cover. If there is another project for the clock, I might add an LED lamp in the cluster to improve night viewing of the clock.
⬆️ About 7 years elapsed between posts ⬇️
Mon Aug 23, 2021 5:30 am
Uploading some photos to fix long-standing missing images.
Mon Aug 23, 2021 5:39 am
This article now has all of the images fixed, finally.
here.
[ Time: 0.0253s ][ Queries: 5 (0.0061s) ][ Debug on ][ 211 ][ Thing One ]
