Fri, 23 Jul 2021 16:09:03 +0000
1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
Fri, 23 Jul 2021 16:09:03 +0000 quote
jimc wrote:
Yup. Totally livable-with (is that a real phrase?).
I think it was a real phrase in XP, but was deprecated. Replaced by satisfactory.
Sat, 24 Jul 2021 12:53:42 +0000
2006 GTS 250
2006 GTS 250
Sat, 24 Jul 2021 12:53:42 +0000 quote
back to the incoming software update. This morning I see that the log off button has been replaced by my avatar picture. Nice!
Sat, 24 Jul 2021 13:03:18 +0000
0:7 And counting
0:7 And counting
Sat, 24 Jul 2021 13:03:18 +0000 quote
Yep. The menu bar is fairly crowded on smaller phones, and I’m trying to make room while not losing any functionality. If you click your profile picture, you’ll see the various user-specific options there (including logout).
Sat, 24 Jul 2021 13:05:07 +0000
2006 GTS 250
2006 GTS 250
Sat, 24 Jul 2021 13:05:07 +0000 quote
That's really cool. Thanks for sharing that.
Sat, 24 Jul 2021 13:18:50 +0000
2006 GTS 250
2006 GTS 250
Sat, 24 Jul 2021 13:18:50 +0000 quote
It works
Mon, 26 Jul 2021 15:39:33 +0000
Mon, 26 Jul 2021 15:39:33 +0000 quote
So, on a G4 iBook running Tiger and Firefox 3.6.28 things look a little wonky. I know ... it's an edge case, but I thought you'd want to know.
Mon, 26 Jul 2021 15:53:13 +0000
0:7 And counting
0:7 And counting
Mon, 26 Jul 2021 15:53:13 +0000 quote
Heh. Looks like it isn’t picking up the CSS file. Which is odd, actually -- out of all the things that might fail on something that old, CSS wouldn’t have been my first guess.
Mon, 26 Jul 2021 16:12:01 +0000
Mon, 26 Jul 2021 16:12:01 +0000 quote
I thought that info might be important like that.
Mon, 26 Jul 2021 17:29:10 +0000
Mon, 26 Jul 2021 17:29:10 +0000 quote
Testing. Do the url tags stop working on an edit? Trying to reproduce what looked like an error when reply on another thread.
working:
https://modernvespa.com/forum/post2483671
Added after selecting "edit" for my reply...
not working (no link):
Pirelli Angel Cannonball Report
Both working properly. False alarm, I guess. Must be operator error.
Tue, 27 Jul 2021 15:44:03 +0000
Tue, 27 Jul 2021 15:44:03 +0000 quote
ks7877 wrote:
emoji bug?
Was trying to end my last post, with multiple clap emojis -
one emoji was inserted at the end of my post (where the cursor was and where I wanted it to appear) and the other two were inserted in front of the quote
jess wrote:
Known issue that I am declining to fix. Every time I touch that code, it gets worse. It’s very browser-specific and I am apparently too stupid to understand it.
Seems to me the emojis insert correctly at the cursor position now. Did you get fed up of people reporting this over and over, and quietly fix it?
Tue, 27 Jul 2021 15:54:28 +0000
0:7 And counting
0:7 And counting
Tue, 27 Jul 2021 15:54:28 +0000 quote
Yes. But no promises as to whether it is really fixed in all circumstances on all browsers.
Tue, 27 Jul 2021 18:15:15 +0000
Tethys - 2012 GTS 300
Tue, 27 Jul 2021 18:15:15 +0000 quote
People log out?
Think of all you miss!
Tue, 27 Jul 2021 18:15:51 +0000
0:7 And counting
0:7 And counting
Tue, 27 Jul 2021 18:15:51 +0000 quote
KimPossible wrote:
People log out?
I know, right? It should be all Hotel California up in here.
Tue, 27 Jul 2021 23:25:49 +0000
Tue, 27 Jul 2021 23:25:49 +0000 quote
KimPossible wrote:
People log out?
I was going to comment on that too.
Internet cafes are still a thing anywhere?
Fri, 03 Sep 2021 08:59:06 +0000
Fri, 03 Sep 2021 08:59:06 +0000 quote
Log in seems to be broken today on my iOS devices or maybe it's just related to Safari. I log in and I get redirected to the main page as a guest. Tried with WiFi & 4G to see if it was maybe IP related but it's not...
Fri, 03 Sep 2021 10:50:25 +0000
0:7 And counting
0:7 And counting
Fri, 03 Sep 2021 10:50:25 +0000 quote
Well that sucks. As a test, could you go to Safari settings and clear all website data? That will clear out ore-existing cookies and start fresh.
Fri, 03 Sep 2021 13:07:19 +0000
Fri, 03 Sep 2021 13:07:19 +0000 quote
My login just worked in Chrome.
Fri, 03 Sep 2021 14:45:04 +0000
Fri, 03 Sep 2021 14:45:04 +0000 quote
I had already done that. Forgot to mention it. It's definitely a Safari thing though. I installed Edge on my iPad and it worked. And now Safari works again...
If you recall, I had mentioned a similar problem where I couldn't stay logged in and then the problem would suddenly go away by its own. I don't know if it's my side or something else...
Fri, 03 Sep 2021 14:47:15 +0000
0:7 And counting
0:7 And counting
Fri, 03 Sep 2021 14:47:15 +0000 quote
You don't block first-party cookies or anything, do you? There are definitely some sketchy bits of code that start getting used if the client doesn't accept cookies, and that code doesn't get tested very well.
Fri, 03 Sep 2021 14:48:02 +0000
'06 Vespa LX150, '07 Suzuki Burgman 400, '05 Honda Metropolitan
Fri, 03 Sep 2021 14:48:02 +0000 quote
Just for reference:
I had the same thing happen on my iPhone with the current OS and Safari a couple of days ago. I tried several times during the day, and it simply went back to the "guest" welcome page. No login error or anything.
I went to settings and cleared all data, and things worked as normal.
Fri, 03 Sep 2021 15:07:02 +0000
0:7 And counting
0:7 And counting
Fri, 03 Sep 2021 15:07:02 +0000 quote
Thanks to you both for the tip-off. I have been attempting to straighten out some of the legacy session-handling code, in particular to reinforce the defenses against the constant onslaught of attackers and malicious actors. Apparently I've screwed something up in the process, though I'm not sure what. Steve's error, in particular, might have been during a transitionary period where things definitely weren't working right, which was later fixed. Not sure about the errors SaFiS is seeing.
Fri, 03 Sep 2021 15:17:13 +0000
Fri, 03 Sep 2021 15:17:13 +0000 quote
No, cookies are accepted for known & trusted sites...
Fri, 03 Sep 2021 15:20:14 +0000
0:7 And counting
0:7 And counting
Fri, 03 Sep 2021 15:20:14 +0000 quote
Okay. Thanks for the info. I'll look some more at the code and see if I can figure out what's going on. It might be time for a wholesale rewrite of the session-handling code.
Sort-of related side-note: browsing anonymously (i.e. not logged in) no longer sets or requires cookies. We now track anonymous sessions solely via the IP address + user agent string, and that's really only to neutralize malicious actors.
Fri, 03 Sep 2021 15:22:18 +0000
Fri, 03 Sep 2021 15:22:18 +0000 quote
The only oddity I've seen, is that on iOS I occasionally get logged out. This has happened maybe four times since I started visiting here again. No problem, I simply log in again.
But when I do the forum options are limited to Started and Replied in portrait, and Watched, Started, and replied in horizontal. To get "New" to show up, I need to first go into any forum. Then, when clicking on "Forum", New shows up. Weird, but again, no problem, and certainly not worth chasing down.
I just tried again to capture screen shots.
Fri, 03 Sep 2021 15:30:00 +0000
Fri, 03 Sep 2021 15:30:00 +0000 quote
These are the exact problems I'm also experiencing...
Fri, 03 Sep 2021 15:43:53 +0000
Fri, 03 Sep 2021 15:43:53 +0000 quote
Possibly noteworthy, is that I also run all of AdGuard's content blockers, both on iOS and MacOS.
Fri, 03 Sep 2021 16:47:21 +0000
0:7 And counting
0:7 And counting
Fri, 03 Sep 2021 16:47:21 +0000 quote
There are a couple things going on here. The auto-login checkbox (under the field where you type your password) used to be off by default, until very recently. It is now on by default, which will set an auto-login key (via cookies) that will log you in even when your current session has expired (which happens after about an hour). So prior to a few weeks ago, being logged out after being away from the site for more than an hour would be the normal behavior, unless you habitually clicked the auto-login check box every time you logged in.
The "New" link isn't showing up because when you log in, your last login time gets reset, and the "New" category is specifically posts that are new since your last login.
Fri, 03 Sep 2021 16:48:47 +0000
0:7 And counting
0:7 And counting
Fri, 03 Sep 2021 16:48:47 +0000 quote
Probably not a factor, since we only run a single banner, and nothing depends on it. It's possible that AdGuard could be blocking something legitimate, but we're not doing anything particularly exotic here. So I wouldn't expect it to be a factor, anyway.
Sat, 04 Sep 2021 00:31:15 +0000
Sat, 04 Sep 2021 00:31:15 +0000 quote
I'm probably the only one, but figured I'd make the ask anyways...
I wonder if there's any support for adding an "are you sure?" window if user clicks "just walk away"?
Current behavior is immediate cancelation of whatever user was typing. It hasn't happened to me yet, but I always get a little nervous clicking on "preview" or "submit" with these little mobile phone buttons and after I've suffered through tapping out a long message.
Sat, 04 Sep 2021 01:17:12 +0000
0:7 And counting
0:7 And counting
Sat, 04 Sep 2021 01:17:12 +0000 quote
It does seem like sort of a mixed message. Giving the user a "just walk away" button but then second guessing them and saying "wait wait, are you sure?" seems kind of mean.
This is a fair point -- it's not difficult to hit the right button on the desktop view, but one could easily fat finger the buttons on mobile.
I've added it to my long list of projects -- I want to stew on it for a bit on the off chance that there's a better option that satisfies all the requirements.
[ Time: 0.1631s ][ Queries: 6 (0.1296s) ][ Debug on ][ 281 ][ Thing Two ]
