Good news and Bad news....
Let's discuss the good news. Y'all know I've been trying, and trying, and trying, to get rid of the 1/4~1/2 rough patch on the throttle. I've tried all kinds of jetting, talked with all kinds of people, took everyone's advice and tried it out. And all to no avail. This is with the 20/20 Spaco carb.
So finally - FINALLY - I decided to try the 24/24 Dellorto carb I have sitting on the shelf. 160/BE3/122. Holy Schnikeys - success! Let me say that again - SUCCESS!
I had a 45/140 Idle jet but it was too low so I went with a 50/120 - pretty rich, but still a slight bog at beginning throttle, so I put in a BE5 mixer tube - beautiful 2 turns out and it runs beautiful. I put in a E3 for grins and it's 1 3/4 turns out perfect.
So no more weird 1/4-1/2 throttle rough patch. Amazing. I decided to go see if the 122 MJ and take it for a WOT run. I ran it up and had to back off slightly because of traffic (68 mph) and the temp was rising. It hit 337F, which was too high for my liking.
So let me say this in it's own sentence:
I could not tune in the 20/20 with my setup (Pinasco 177 2 port kit with 57mm Pinasco performance crank). The 24/24 tuned almost without effort! No more weird 1/4 to 1/2 throttle rough patch...
Now for the bad....I'm doing a speed run and....the engine dies. I've got two fingers on the clutch so I immediately pull the clutch and coast, then realize I was almost out of fuel so I flip the lever to Reserve and wait until I'm barely coasting and pop the clutch. Starts right up. I'm stoked and all is well.
So I go back to the port, put a 125MJ in and do the same run. This time it got up to 313F and was holding, but bam, it died again. Pull in the clutch and coast almost to a stop, pop the clutch and it starts up, but I hear a tinging, like piston slap, or the flywheel hitting the shroud. No-no-no-no-no....Deep breath. I'm alive and not on the ground....
So I head home and take a look in the spark plug hole. Hmm, I think I see lines, so I pull the head. Yup, score marks. AAAARRRGGGGHHHHH
I took the cylinder and piston out and, yup, seize marks. Pinging must've been piston slapping. I've analyzed how I did this, and it's lasted longer than I could've had any right to last. Running without a CHT gauge, running way too lean for over 500 miles with the brass bushing, then letting it go to reserve, like, all-the-time, which is essentially starving the piston of lubrication briefly. But do this over time? Live and learn. And 68 on 8's? Not necessary
So my next course of action: I decided instead of dicking around with just putting rings in, I ordered a new piston, rings, and I have a new wrist pin bearing. Once I get the new setup, It's heat cycle mania for a while, then ride it with a fat main jet, or drop the AC to 140.
20/20 Spaco on the left, 24/24 Dellorto on the right. Yeah, I did a bit of flowing the carb to box...
Dangit, but not too bad looking....
OK, here is the issue. Bummer....
I honed out the cylinder scratches with one of those three legged stones hooked to a drill at slow speed and WD-40 for a lubricant
The score marks are pretty much gone...Now for a new piston and rings, and wrist pin bearing.
Proof of 68mph....The 23 tooth clutch gear makes a difference...
