Sun Oct 17, 2021 10:52 am
MP3 - 500
MP3 - 500
Sun Oct 17, 2021 10:52 am linkquote
MP3 500 sat in a temp. controlled garage for about 1 year. The emergency brake is loose - never used anyway, and the rear wheel is super tough to turn.
The brake lever is very stiff and hardly moves.
Greatly appreciate your suggestions, please.
Mon Oct 18, 2021 2:29 am
Mon Oct 18, 2021 2:29 am linkquote
The regular handlebar brake and the parking braked are separate systems. They each have a separate caliper on the back. Which one is stuck?
Mon Oct 18, 2021 9:09 am
MP3 - 500
MP3 - 500
Mon Oct 18, 2021 9:09 am linkquote
Hi thanks for responding, and the issue is with the regular brake lever on the handlebar.
The lever is tight against the hydraulic housing which seems strange.
Tue Oct 19, 2021 1:56 pm
Tue Oct 19, 2021 1:56 pm linkquote
Well, I'd start with the pivot pin for the lever to see if that is free. Then you'll have to check if the piston in the master cylinder is moving. Would be a very rare occurrence for it to be stuck, but you never know.
Tue Oct 19, 2021 5:11 pm
Tue Oct 19, 2021 5:11 pm linkquote
Spread the brake pads with a screw driver to see if the piston is stuck in the caliper
Wed Oct 20, 2021 6:04 am
MP3 - 500
MP3 - 500
Wed Oct 20, 2021 6:04 am linkquote
Good ideas, thanks.
BTW Where is the master cylinder located ?
Wed Oct 20, 2021 8:14 am
Wed Oct 20, 2021 8:14 am linkquote
The mastercylinder is on the handlebar, the lever pushes the piston directly
Sun Oct 24, 2021 6:02 am
MP3 - 500
MP3 - 500
Sun Oct 24, 2021 6:02 am linkquote
Ah!
Gotcha...Thanks
[ Time: 0.0250s ][ Queries: 5 (0.0060s) ][ Debug on ][ 211 ][ Thing One ]
