rowdyc wrote:
From the sounds of that motor, if the carb was leaking, fuel will roll down the back onto the floor. Is that happening?
Can you provide some more history of the bike? Was the bike sounding like that before the carb build? What made you rebuild the carb? Will the bike rev high if you turn the idle screw all the way in? Did you remove the flywheel or anything else on the bike before, after, or during the carb rebuild.
Maybe a passage way in the carb is stuck somewhere. How detail was the carb rebuild? Did you remove everything from carb and blew carb cleaner and air through every hole? What are the air mixture and idle screws settings?
Fuel is not leaking.
I rebuild the carb because two week ago I received the vespa and it had a tank full of bad gas. So I cleaned the tank change the fuel
Tap and cleaned the carb.
The guy I got it from said it was running not to long ago.
I did not remove anything else on the bike.
I did completely take the carb apart and blew through all passages. The air fuel is seat at 1 and a half turned out from all the way in and the idle screw is set to were the slide is just barley open.
