Sun Nov 14, 2021 2:30 pm
Piaggio mp3 500
Piaggio mp3 500
Sun Nov 14, 2021 2:30 pm linkquote
turn signal mounts have broken> How to repair them? All four are hanging down!
Sun Nov 14, 2021 7:06 pm
2016 MP3 500 Sport
2016 MP3 500 Sport
Sun Nov 14, 2021 7:06 pm linkquote
Are you sure they are broken? Sometimes, the nut that holds them on comes loose and falls off.
Sun Nov 14, 2021 10:40 pm
Sun Nov 14, 2021 10:40 pm linkquote
IF they are truly broken, then the only solution is to get new ones.
Mon Nov 15, 2021 9:44 am
Mon Nov 15, 2021 9:44 am linkquote
Buy new turnsignals, in the mean time
Cut a small piece of garden hose, slit long ways, slip over broken turnsignal stalk, secure with hose clamps, tire wraps or black tape
Mon Nov 15, 2021 10:49 am
Mon Nov 15, 2021 10:49 am linkquote
I've never seen one actually break. Come apart, needing re-assembly, yes, often.
Mon Nov 15, 2021 12:41 pm
Piaggio mp3 500
Piaggio mp3 500
Mon Nov 15, 2021 12:41 pm linkquote
I do not know how to attach a photo or I would! all four rubber mounts have broken!
Mon Nov 15, 2021 1:06 pm
Mon Nov 15, 2021 1:06 pm linkquote
Actually damaged and split apart or just unattached?
Mon Nov 15, 2021 1:07 pm
Piaggio mp3 500
Piaggio mp3 500
Mon Nov 15, 2021 1:07 pm linkquote
Split apart and dangling!
Mon Nov 15, 2021 1:33 pm
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Mon Nov 15, 2021 1:33 pm linkquote
That happened to mine from sitting out in the Florida sun for a few years. The rubber crumbled. I don't remember the brand but I found suitable replacements at a local Yamaha shop. I think I had to do a little modification though.
Mon Nov 15, 2021 2:32 pm
Piaggio mp3 500
Piaggio mp3 500
Mon Nov 15, 2021 2:32 pm linkquote
what is the process to replace them on the bike?
Mon Nov 15, 2021 3:06 pm
Mon Nov 15, 2021 3:06 pm linkquote
Remove the nut and washer on the inside of the fairing.
Beware: You will need a very skinny wrench (17mm IIRC) which can be gotten at bicycle shops.
If you are using aftermarket replacement units, be sure to solder the connectors of the broken lights onto the new ones and use heatshrink tubing to keep the connections from getting green death (corrossion)
Mon Nov 15, 2021 7:01 pm
Piaggio mp3 500
Piaggio mp3 500
Mon Nov 15, 2021 7:01 pm linkquote
tail light problem
Mon Nov 15, 2021 7:05 pm
Piaggio mp3 500
Piaggio mp3 500
Mon Nov 15, 2021 7:05 pm linkquote
All 4 turn signals!
Mon Nov 15, 2021 11:11 pm
Mon Nov 15, 2021 11:11 pm linkquote
Needs 4 new signals. Perfect time to upgrade to Piaggio's Euro spec LED blinkers and relay.
100% plug and play, and no more water ingress into the bulb housing or bulbs to deal with.
Tue Nov 16, 2021 5:13 am
Moderatus Rana
Moderatus Rana
Tue Nov 16, 2021 5:13 am linkquote
tail light problem
Yep that is what mine looked like. Replaced all four with leds.
Tue Nov 16, 2021 6:37 am
mp3 500 2018 (USA-version)
Tue Nov 16, 2021 6:37 am linkquote
I would try to rebuild the direction indicators. For example, using hot melt glue. Of course, if the new ones are not very expensive, it is better to buy new ones.
Tue Nov 16, 2021 7:45 am
Moderatus Rana
Moderatus Rana
Tue Nov 16, 2021 7:45 am linkquote
I thought of that when the same thing happened to mine but all of the rubber was crumbling and the cost of replacements was worth it to me instead of trying to fix.
Tue Nov 16, 2021 8:51 am
2016 Mp3 500ie Sport
Tue Nov 16, 2021 8:51 am linkquote
Credit to sbaert for the following information.
Information on the Euro Spec turn signal relay to enable LED signals can be found on this thread. Turn signal relay
"STAR Blinker device with Hazard Control Unit 12V part 1D002536R" which can be purchased from https://www.easyparts.nl/Blinker-Device-With-Hazard-p33684637
I installed it on my 2016 Mp3 500ie Sport NAFTA and it works fine with the existing incandescent marker bulbs but will also work on future LED upgrades.
Fri Nov 19, 2021 3:33 pm
Granturismo 218
Granturismo 218
Fri Nov 19, 2021 3:33 pm linkquote
The indicator stalks are pretty pricey. We have them and a set of four will set you back about $120. But you might be able to find another manufacturer that uses them. My Moto Guzzi indicators were about $45 each, and if I had ordered them when I needed them, in 2006, I might have them by now. Turns out Buell used the same indicators, they were in stock, and they were about $10 each.
6402455 is the Piaggio part number for the Left Rear, Right Front, and the other one is 6402455.
[ Time: 0.0302s ][ Queries: 7 (0.0086s) ][ Debug on ][ 211 ][ Thing One ]
