Fri, 26 Nov 2021 10:44:37 +0000
2020 GTS300 hpe
2020 GTS300 hpe
Fri, 26 Nov 2021 10:44:37 +0000 quote
I bought an air cushion from BadAss Moto for a solo ride from Philadelphia to Richmond, VA, as non-stop as my tank would allow. It absolutely worked and I was pretty comfortable the whole way.
The problem is that it raises the seat height by an inch and a half or so. I have short legs and my GTS height is about my limit. Hard to remain stable when I had to stop abruptly.
How do you stay comfortable on long, non-stop rides?
Fri, 26 Nov 2021 15:29:13 +0000
Gigi, '13 GTS 300ie Touring
Fri, 26 Nov 2021 15:29:13 +0000 quote
I would like to have my seats reworked to better cushion me bum and surrounding bits. However, I'm scooter rich and cash poor. I received this recommendation from the WildGuzzi forum and he's sent them all of his bike seats. http://www.meancitycycles.com
Fri, 26 Nov 2021 15:33:33 +0000
Fri, 26 Nov 2021 15:33:33 +0000 quote
Air Hawk seat cushions work best when they're barely inflated, so that your butt just touches the seat. You didn't say what kind of air cushion you have, but you might try adjusting the inflation if that's possible.
Fri, 26 Nov 2021 15:55:54 +0000
Fri, 26 Nov 2021 15:55:54 +0000 quote
I use a sheepskin pad on my GTS (Alaska Buttpad). Substantially improves comfort for longer distance riding and makes little difference in apparent seat height (less than 1/2" I'd say).
Fri, 26 Nov 2021 16:17:29 +0000
Fri, 26 Nov 2021 16:17:29 +0000 quote
I usually peel and reshape my seats with a kitchen knife and angle grinder. The vinyl cover adapts to subtle recontouring while restapling.. Local upholstery shops can do this in an hour or two. The shape is the main thing to consider, as it should fit your buns.
It's a common task for upholstery shops to lower seats. My friend Peter had his done for $90 by a shop that does hotrod interiors and boats.
Fri, 26 Nov 2021 19:26:11 +0000
2020 GTS300 hpe
2020 GTS300 hpe
Fri, 26 Nov 2021 19:26:11 +0000 quote
Thanks. Going to try that. I had it fully inflated. I mentioned that I had a BadAss Moto cushion.
Fri, 26 Nov 2021 19:29:50 +0000
2020 GTS300 hpe
2020 GTS300 hpe
Fri, 26 Nov 2021 19:29:50 +0000 quote
I'm sure that would work, but I'm reluctant to modify the OEM stuff.
Fri, 26 Nov 2021 19:42:22 +0000
Piaggio Beverly 300 ie - 2012
Fri, 26 Nov 2021 19:42:22 +0000 quote
Buy an extra seat, maybe second hand, and have that used for modification.
You could mount the original seat for every day short trips, and the modified one for the long journeys when comfort is more important than looks.
Fri, 26 Nov 2021 19:44:14 +0000
2020 GTS300 hpe
2020 GTS300 hpe
Fri, 26 Nov 2021 19:44:14 +0000 quote
That's a good idea for one I already have, From my '07 GTS.
Fri, 26 Nov 2021 19:51:18 +0000
Fri, 26 Nov 2021 19:51:18 +0000 quote
I understand that concern. Used seats might be an option or the custom makers like Sargent who make lowered seats. My mods are because I'm too dang tall.
Sat, 27 Nov 2021 18:42:00 +0000
Sat, 27 Nov 2021 18:42:00 +0000 quote
Do you ride by yourself rather than 2-up? I switched out my stock seat for the Vespa solo gel seat. It is a bit lower than the stock seat and the gel layer adds to riding comfort. It is not so expensive as custom seats from some aftermarket makers. I added a sheepskin pad to this and the combo has served me well on my GTS. (the stock seat is still in the garage and can be switched back in no more than 10 minutes, so i haven't really given up anything)
https://scooterpartsco.com/vespa/gts-300/gts-300-seats/low-profile-gel-solo-seat-for-vespa-gts-with-abs?zenid=bfd1a3d66c348a4b5bd45afca1dc9ea8
Mon, 29 Nov 2021 16:37:50 +0000
2007 250 GTS, 1980 P200E, 2010 ThunderFly 190 (SOLD) 2015 Yamaha SMax
Mon, 29 Nov 2021 16:37:50 +0000 quote
As mentioned above, the cushion should be inflated to allow you to almost bottom out. The air chambers are interconnected and it should feel squishy as you move around on it.
I had really good luck with a barely inflated Air Hawk under a quilted seat cover from Cheeky Seats. It was super plush and I could ride for 8+ hours pretty comfortably.
[ Time: 0.0256s ][ Queries: 4 (0.0049s) ][ Debug on ][ 286 ][ Thing Two ]
