Fri Aug 14, 2020 10:19 pm
Fri Aug 14, 2020 10:19 pm linkquote
Greetings:
Sat Aug 15, 2020 3:25 am
Sat Aug 15, 2020 3:25 am linkquote
Sat Aug 15, 2020 8:25 am
Sat Aug 15, 2020 8:25 am linkquote
Spark Plug Change Censored
Greetings:
Mon Aug 31, 2020 9:30 am
2003 Vespa ET2
2003 Vespa ET2
Mon Aug 31, 2020 9:30 am linkquote
Mon Aug 31, 2020 11:30 am
Mon Aug 31, 2020 11:30 am linkquote
Greetings:
Tue Sep 01, 2020 5:42 am
2003 Vespa ET2
2003 Vespa ET2
Tue Sep 01, 2020 5:42 am linkquote
Tue Sep 01, 2020 5:49 am
Tue Sep 01, 2020 5:49 am linkquote
Ned Flanders
Greetings;
Wheelman's ET4 2003 "ISO"
Sat Sep 05, 2020 6:33 am
Sat Sep 05, 2020 6:33 am linkquote
Sat Sep 05, 2020 1:57 pm
LXS 150
LXS 150
Sat Sep 05, 2020 1:57 pm linkquote
This small:
Sat Sep 05, 2020 2:50 pm
Sat Sep 05, 2020 2:50 pm linkquote
Tiny Plug
Greetings:
Wow!!
Nice RC!
Sat Dec 04, 2021 4:51 pm
Sat Dec 04, 2021 4:51 pm linkquote
Greetings:
I'd been hearing a metallic "Clank" lately riding over bumps. Then my horn stopped working. Uh-oh. Checked the battery connection, and inline fuse before listening behind the horn cover for the relay click when horn button depressed. No problems so far.
With great trepidation I undertook to remove the glove-box cover. Other posts describe the cussing involved with getting this thing back on and the door working. Sure enough the + lead from the relay had broken off right at the connection to the horn.
It appears my Spring Steel mounting tab was growing fatigued, and letting the mass of the horn bang against the steering stem outer and/or the front legshield. I managed the fix with junk on-hand, no trip to the hardware store. Ms. Wheel-person has been buying lamps lately - something about things needing to "match" - don't ask. But side benefit of abundant scraps of packing styrofoam to nestle the horn into. Cut and notched to shape with Henkels Kitchen knife (Don't tell her), and a horn "bed" was carved. Giant Zip-ties purchased in an ill-fated attempt to mount tires onto rims without force. (Didn't work...)
First photo from the left side behind the leg shield. Second from the right side.
Glove box went on amazingly easily, and I modified the latch mechanism to increase the percentage of time the box opens when the keyswitch is pressed. All in all 3 relaxing Garage Therapy hours.
Cinched in to foam block to prevent oscillation from the tired Spring Steel mounting tab.
[ Time: 0.1790s ][ Queries: 7 (0.1337s) ][ Debug on ][ 211 ][ Thing One ]
