Mon Dec 13, 2021 3:39 pm
vespa sprint
vespa sprint
Mon Dec 13, 2021 3:39 pm linkquote
Hello people,
just got a vespa sprint out of 2014 and having a issue.. It starts well and runs also well. But there are two things.
1 the rpms are not getting high. It stays at a certain rpm and it is not getting up. It also happens when i am not using the centre stand.
2 the rear wheel is not turning.
I have 2 video's that showcases the issue the vespa has.
I hope you guys can help me out with this issue.
Mon Dec 13, 2021 9:03 pm
GT 2.4
GT 2.4
Mon Dec 13, 2021 9:03 pm linkquote
Sounds like an immobilizer circuit. But it's a 50cc model. Did you recently do any work to it, like put in really heavy weights? Clutch and rear wheel look okay
Mon Dec 13, 2021 11:09 pm
GTS300 Super HPE, Primavera 125, S 50 4T
Mon Dec 13, 2021 11:09 pm linkquote
1. Variator not moving in when accelerating.
2. Clutch not engaging, stuck, or worn pads.
Disassemble the variator, check the rollers, clean the slide bus.
Remove the clutch bell and check the pads. Replace if needed.
Motor runs, belt looks alright at first sight. Should not be a problem to fix.
Tue Dec 14, 2021 12:54 am
vespa sprint
vespa sprint
Tue Dec 14, 2021 12:54 am linkquote
Thank you guys, ii will have a look on it. I havent done any work on it yet.
Tue Dec 14, 2021 12:59 am
Tue Dec 14, 2021 12:59 am linkquote
the immobilizer system because it sends a signal to the coil when to fire and also limits the spark (Rev Limiter).
https://modernvespa.com/forum/topic8606
Maybe this will help?
Edit:
Vespas in downtown environments tend to get knocked over and pour oil into their air box, so if you have a paper filter your bike might not fire up, but if you have a foam filter you should still be okay to get home/to the shop.
Tue Dec 14, 2021 4:35 am
vespa sprint
vespa sprint
Tue Dec 14, 2021 4:35 am linkquote
Cheked the clutch and rolls today. Has some wear but not that bad.
Tue Dec 14, 2021 5:42 am
Contributor
2007 LX 150 (memories)
Contributor
Tue Dec 14, 2021 5:42 am linkquote
Edit:
If it is a 50cc model, I don't think it has an immobilizer.
Tue Dec 14, 2021 5:48 am
Tue Dec 14, 2021 5:48 am linkquote
With the engine off and the scooter on the center stand, does the rear wheel spin freely? If not, is the rear brake dragging?
Tue Dec 14, 2021 10:56 am
2020 primavera 150
2020 primavera 150
Tue Dec 14, 2021 10:56 am linkquote
Did you check the exhaust?
Tue Dec 14, 2021 11:05 am
Piaggio Beverly 300 ie - 2012
Tue Dec 14, 2021 11:05 am linkquote
Something like in this post of collbain 2000 from Jan 30, 2007 seems very plausible. (in the link waspmike shared)
The engine starts up and idle is perfect but when you turn the throttle then at a certain rpm the engine sound changes and the engine clearly does not ignite at every compression stroke, it runs irregular and clearly misses several compression strokes in between ignitions.
If engine rpm is indeed limited to 2000, then that is probably too low to have the clutch engaged.
So I would start with checking the key and the immobiliser system of your scooter (or better: have it checked because if there is something wrong with it you probably cannot fix it yourself)
Tue Dec 14, 2021 11:19 am
Tue Dec 14, 2021 11:19 am linkquote
That sounds like a virgin immobiliser, before it's been programmed with any keys.
If you have the master (brown) key you can try re-programming it.
Tue Dec 14, 2021 11:50 am
vespa sprint
vespa sprint
Tue Dec 14, 2021 11:50 am linkquote
I got it! I changed the cdi with another one. Thank god the issue is solved. This model has no immobilizer. I am gonna clean everything up and put everything back. Clean it til it's shining and put another picture of it! Thank you all for the help and idea's.
edit: cdi is not shown in the picture (was curious what that is)
[ Time: 0.0374s ][ Queries: 7 (0.0162s) ][ Debug on ][ 211 ][ Thing One ]
