Upcoming Server Maintenance
Sat, 17 Apr 2021 23:47:03 +0000
Sat, 17 Apr 2021 23:47:03 +0000 linkquote
both bikes look amazing
Wed, 19 May 2021 06:31:01 +0000
300 gts
300 gts
Wed, 19 May 2021 06:31:01 +0000 linkquote
end result.
I took the scooter for its Ministry of transport safety test on Monday. it passed with flying colours and no advisories, so well pleased with that. Initial road tests found that the exhaust was catching the side panel, but quickly sorted by turning the exhaust round 180 deg. it is a triangular shape, so with the wider end to the bottom the problem was solved.
⬆️    About 37w elapsed between posts    ⬇️
Fri, 04 Feb 2022 10:18:07 +0000
300 gts
300 gts
Fri, 04 Feb 2022 10:18:07 +0000 linkquote
Scomadi x9 500 is now registered with the DVLA as a 500cc scooter, it has been at Junction 33 developments for a remap, It took a while as the mapper did not have the protocols to map the ecu, he has since purchased the required equipment and done a mild remap which i requested, personally i think its fast enough as it is, so he has improved the fuel mixture made it richer as it was lean low end and very lean high end, its now has a very smooth power delivery.
Very pleased with the end results, It will be going up for sale shortly so i can find a new project.
Tue, 08 Feb 2022 05:43:15 +0000
2009 S 125
2009 S 125
Tue, 08 Feb 2022 05:43:15 +0000 linkquote
Lovely work
Tue, 08 Feb 2022 06:27:09 +0000
300 gts
300 gts
Tue, 08 Feb 2022 06:27:09 +0000 linkquote
Thanks.
Tue, 01 Mar 2022 13:18:06 +0000
300 gts
300 gts
Tue, 01 Mar 2022 13:18:06 +0000 linkquote
Photo shoot by scootering magazine in march, will post some shoot pics.
⬆️    About 39w elapsed between posts    ⬇️
Sat, 26 Nov 2022 09:49:04 +0000
300 gts
300 gts
Sat, 26 Nov 2022 09:49:04 +0000 linkquote
scootering magazine. https://www.scootering.com/five-hundred-ccs-of-fun/
Sat, 26 Nov 2022 09:59:54 +0000
300 gts
300 gts
Sat, 26 Nov 2022 09:59:54 +0000 linkquote
one of the scootering pics from the photoshoot
Elvaston castle photo shoot
Sat, 26 Nov 2022 10:00:40 +0000
300 gts
300 gts
Sat, 26 Nov 2022 10:00:40 +0000 linkquote
Another shot from the photoshoot.
pic2
[ Time: 0.0408s ][ Queries: 6 (0.0181s) ][ Debug on ][ 237 ][ Thing Two ]
