Sat Feb 12, 2022 11:01 pm
GT200
GT200
Sat Feb 12, 2022 11:01 pm linkquote
Need some help. Scoot started cutting out every now and then, but now won't restart at all once it cuts out for a few hours.
Symptoms:
1 - When on stand/parked... I start it and 30 seconds later it idles super high and rear wheel goes crazy fast
2 - I can start it now and then and ride it maybe 100ft and it cuts out and I cannot start it again. I have to push it home.
3 - terrible on gas and smells like gas
4 - gas leak/wet hoses coming from gas tap/petcock. I tightened hose clamps, but is still acting the same.
5 - I changed airfilter
I'm getting close to thinking it's a bad petcock. Any ideas?
Sun Feb 13, 2022 12:54 am
Vespa ET4 125cc , Baotian 70cc rat scooter
Sun Feb 13, 2022 12:54 am linkquote
I would replace the petcock and if the vacuum and fuel lines bit old change them as well.
Sun Feb 13, 2022 1:41 am
'07 GTS250ie "Mechanical Squirrel", '66 Honda Benly, '19 Suzuki 250 cafe "Mouse", '77 Jawa 350TS, '42 Henschel PzKw VI Tiger
Sun Feb 13, 2022 1:41 am linkquote
I'm not familiar with the carb on these things, but I had very similar problems on a bike a few years back and the issue was a defective float. I'd check the float for damage or deterioration as well as the valve.
Sun Feb 13, 2022 7:55 am
GT200
GT200
Sun Feb 13, 2022 7:55 am linkquote
I'll check the float, thanks. I hope it's nothing major. It was running great all this time
Sun Feb 13, 2022 8:42 am
Sun Feb 13, 2022 8:42 am linkquote
I'd start here, as this is definitely not right. The petcock is vacuum operated, and should block fuel when the engine is not running. It sounds to me like yours has failed and is flooding your bike.
p.s. you posted in wiki section, so your post is probably not getting as much attention as it normally would. Maybe ask a moderator to move it to "general"?
Sun Feb 13, 2022 1:36 pm
GT200
GT200
Sun Feb 13, 2022 1:36 pm linkquote
Perfect, thank you so much. I will order the petcock and hoses.
berto wrote:
I'd start here, as this is definitely not right. The petcock is vacuum operated, and should block fuel when the engine is not running. It sound yo me like yours is failed and flooding your bike.
p.s. you posted in wiki section, so post is maybe not getting much attention. Maybe ask a moderator to move it to "general"?
Sun Feb 20, 2022 7:31 pm
GT200
GT200
Sun Feb 20, 2022 7:31 pm linkquote
OK just did the following and my GT200 is back up and running like a champ.
1. Air filter - it was not too bad, but time for a change
2. Spark plug - the old one was completely burnt out
3. Fuel filter and fuel lines - not in bad shape, but lines were leaky at the petcock
4. Fuel pump - looked pretty warn, worth a change
I am however going to clean out the carburetor, to see if it gets better idle and performance, buy at least it's going steady again. Thank you all for your help!!!
Sun Feb 20, 2022 10:12 pm
Sun Feb 20, 2022 10:12 pm linkquote
Great to hear! Well done!
Mon Feb 21, 2022 2:55 pm
Mon Feb 21, 2022 2:55 pm linkquote
Awesome - great news.
[ Time: 0.0283s ][ Queries: 5 (0.0090s) ][ Debug on ][ 211 ][ Thing One ]
