Sun, 27 Mar 2022 16:18:49 +0000
MP3 500Ie LT sport 2013
Sun, 27 Mar 2022 16:18:49 +0000 quote
I was trying to replace variator weights.
I had seen videos of jamming something in rear wheel to loosen rear bolt.
Applying torque to loosen bolt the casting cracked where it holds the brake assembly.
Not good.
Any idea what part I need to replace and how to do it. Suspect I've made a big tedious expensive job out of a small fun one.
Bummer.
Rear casting near handbrake
Front bolt casting cracked also
Sun, 27 Mar 2022 17:13:48 +0000
Sun, 27 Mar 2022 17:13:48 +0000 quote
Looks like the brakes attach to final drive cover, not a common part to find spare.
Sun, 27 Mar 2022 17:14:26 +0000
Sun, 27 Mar 2022 17:14:26 +0000 quote
The engine block and transmission/rear diff are one single casting.
You will need to seek a donor block.
There is no EZ workaround such as patching/welding.
As far as loosening the rear nut, I always put the bike on the ground with tilt lock enable, parking brake set and apply the rear brake lever with a helper loosening the nut.
Sun, 27 Mar 2022 17:38:54 +0000
Sun, 27 Mar 2022 17:38:54 +0000 quote
Replace your final drive cover (OEM code: 8320525) and you'll be fine…
Mon, 28 Mar 2022 10:40:43 +0000
Mon, 28 Mar 2022 10:40:43 +0000 quote
Thanks.
That's what it looked like from what I could see. From manual (2011, bike is 2013) it looked like whole crankcase needs replacement as previous post said.
Wed, 06 Apr 2022 20:10:35 +0000
Wed, 06 Apr 2022 20:10:35 +0000 quote
Ordered a new cover for £200, arriving soon, then found an arm casing on eBay which I bought for £50.
I swapped the variator weights, can't wait to try, a simple job taking minutes if using an impact wrench to loosen nuts instead of cracking casing with a normal wrench.
I would strongly recommend resisting the temptation to run the engine out of idle curiosity before torquing the variator nut, particularly in a crowded yard as it gets dark - the outer variator half can travel a long way when it departs.
Just need to swap cover in the light. Meanwhile here's the bit of aluminum casting that takes all the stress when you use the rear brakes.
Wed, 06 Apr 2022 22:28:17 +0000
Wed, 06 Apr 2022 22:28:17 +0000 quote
In the future, use a piece of velcro or a bungy cord wrapped around the rear brake lever to hold the rear wheel.
Thu, 07 Apr 2022 05:09:40 +0000
Thu, 07 Apr 2022 05:09:40 +0000 quote
zip tie
Fri, 08 Apr 2022 00:36:03 +0000
Fri, 08 Apr 2022 00:36:03 +0000 quote
In fact you don't even need to do that if you use an impact wrench. I was going to but some post said don't, use a breaker bar. Garage I spoke to said he always used one. Even not having a rear brake the clutch nut came off with impact wrench as inertia of rear drive was enough in itself.
Fri, 08 Apr 2022 00:37:05 +0000
2019 GTS300 Supertech E3 47,000km
Fri, 08 Apr 2022 00:37:05 +0000 quote
yeah but when doing it up again and you want to torque it correctly ...
Fri, 08 Apr 2022 07:37:43 +0000
Fri, 08 Apr 2022 07:37:43 +0000 quote
Yup, will do just that (still waiting for part to finish). You prompted me to re-check the torques. Thanks. Had mis-recalled and done big nut to 80 rather than 160 and was going to do rear to 60 rather than 95 so saved me possible embarrassment!
Fri, 08 Apr 2022 19:55:05 +0000
2008 fuoco
2008 fuoco
Fri, 08 Apr 2022 19:55:05 +0000 quote
And don't get mixed up with ft-lbs and nm's easy done sometimes.
Fri, 08 Apr 2022 22:30:58 +0000
Fri, 08 Apr 2022 22:30:58 +0000 quote
this is why I wish Robot would stop saying ftlbs in his videos.
Sat, 09 Apr 2022 07:13:38 +0000
2008 fuoco
2008 fuoco
Sat, 09 Apr 2022 07:13:38 +0000 quote
It dosen't help when your torque wrench has dual readings and your more used to ftlbs.i'll get used to newton metres just like i have got used to,well almost to the metric system . It's a bit easier than using BSF,whitworth,cycle in all it's different tpi's,BA, unc,unf bsp&t,ME and lots of odd ball specials that turn up sometimes.
Sat, 09 Apr 2022 15:35:40 +0000
Sat, 09 Apr 2022 15:35:40 +0000 quote
You should always consult the shop manual and not take somebody word in a video. Robot has made mistakes multiple times, and corrected later in the video. If youu don't watch the whole video you may not catch the correction, always check the shop manual unless you know what the torque is supposed to be.
Sun, 17 Apr 2022 10:05:49 +0000
Sun, 17 Apr 2022 10:05:49 +0000 quote
So, almost feeling quite pleased with myself, replaced transmission cover, replaced badly scored brake disc, put on new tyre, torqued correctly, loctite, and then discovered this…
Bonus component. Think it goes between brake hub and transmission cover.
Sun, 17 Apr 2022 10:12:05 +0000
Sun, 17 Apr 2022 10:12:05 +0000 quote
For those interested, here is inside of transmission. And how badly scored a disc can get.
Old v new discs
New transmission cover
Cracked brake mountings
Inside final drive
Sun, 17 Apr 2022 10:19:05 +0000
Sun, 17 Apr 2022 10:19:05 +0000 quote
Looks like it goes between wheel and swing arm, that's a lot less hassle, apart from that bloody split pin.
Sun, 17 Apr 2022 14:48:58 +0000
Sun, 17 Apr 2022 14:48:58 +0000 quote
LOCKTITE why ? where? NO locktite, no locktite.
Sun, 17 Apr 2022 17:16:19 +0000
Sun, 17 Apr 2022 17:16:19 +0000 quote
On the little bolts holding the brake disc on.
Sun, 17 Apr 2022 22:36:31 +0000
2022 Liberty 150S-"Meg"
Sun, 17 Apr 2022 22:36:31 +0000 quote
Many of us have been where you are. Nothing like finishing a job with parts left over.
At least you caught it before you tried to ride it.
Good luck.
Fri, 22 Apr 2022 03:53:41 +0000
Aprilia Mojito 125
Aprilia Mojito 125
Fri, 22 Apr 2022 03:53:41 +0000 quote
Ah, no problem, you do not need to dismount it from the wheel.
Fri, 22 Apr 2022 23:44:15 +0000
Fri, 22 Apr 2022 23:44:15 +0000 quote
ok ok I imagined you locktighting all the bolts on the cover and everything
[ Time: 0.0430s ][ Queries: 6 (0.0201s) ][ Debug on ][ 281 ][ Thing Two ]
