Sun Mar 27, 2022 8:18 am
MP3 500Ie LT sport 2013
Sun Mar 27, 2022 8:18 am linkquote
I was trying to replace variator weights.
I had seen videos of jamming something in rear wheel to loosen rear bolt.
Applying torque to loosen bolt the casting cracked where it holds the brake assembly.
Not good.
Any idea what part I need to replace and how to do it. Suspect I've made a big tedious expensive job out of a small fun one.
Bummer.
Rear casting near handbrake
Front bolt casting cracked also
Sun Mar 27, 2022 9:13 am
Sun Mar 27, 2022 9:13 am linkquote
Looks like the brakes attach to final drive cover, not a common part to find spare.
Sun Mar 27, 2022 9:14 am
Sun Mar 27, 2022 9:14 am linkquote
The engine block and transmission/rear diff are one single casting.
You will need to seek a donor block.
There is no EZ workaround such as patching/welding.
As far as loosening the rear nut, I always put the bike on the ground with tilt lock enable, parking brake set and apply the rear brake lever with a helper loosening the nut.
Sun Mar 27, 2022 9:38 am
Sun Mar 27, 2022 9:38 am linkquote
Replace your final drive cover (OEM code: 8320525) and you'll be fine…
Mon Mar 28, 2022 2:40 am
Mon Mar 28, 2022 2:40 am linkquote
Thanks.
That's what it looked like from what I could see. From manual (2011, bike is 2013) it looked like whole crankcase needs replacement as previous post said.
Wed Apr 06, 2022 12:10 pm
Wed Apr 06, 2022 12:10 pm linkquote
Ordered a new cover for £200, arriving soon, then found an arm casing on eBay which I bought for £50.
I swapped the variator weights, can't wait to try, a simple job taking minutes if using an impact wrench to loosen nuts instead of cracking casing with a normal wrench.
I would strongly recommend resisting the temptation to run the engine out of idle curiosity before torquing the variator nut, particularly in a crowded yard as it gets dark - the outer variator half can travel a long way when it departs.
Just need to swap cover in the light. Meanwhile here's the bit of aluminum casting that takes all the stress when you use the rear brakes.
Wed Apr 06, 2022 2:28 pm
Wed Apr 06, 2022 2:28 pm linkquote
In the future, use a piece of velcro or a bungy cord wrapped around the rear brake lever to hold the rear wheel.
Wed Apr 06, 2022 9:09 pm
Wed Apr 06, 2022 9:09 pm linkquote
zip tie
Thu Apr 07, 2022 4:36 pm
Thu Apr 07, 2022 4:36 pm linkquote
In fact you don't even need to do that if you use an impact wrench. I was going to but some post said don't, use a breaker bar. Garage I spoke to said he always used one. Even not having a rear brake the clutch nut came off with impact wrench as inertia of rear drive was enough in itself.
Thu Apr 07, 2022 4:37 pm
2019 Supertech (EURO3/APAC)
Thu Apr 07, 2022 4:37 pm linkquote
yeah but when doing it up again and you want to torque it correctly ...
Thu Apr 07, 2022 11:37 pm
Thu Apr 07, 2022 11:37 pm linkquote
Yup, will do just that (still waiting for part to finish). You prompted me to re-check the torques. Thanks. Had mis-recalled and done big nut to 80 rather than 160 and was going to do rear to 60 rather than 95 so saved me possible embarrassment!
Fri Apr 08, 2022 11:55 am
2008 fuoco
2008 fuoco
Fri Apr 08, 2022 11:55 am linkquote
And don't get mixed up with ft-lbs and nm's easy done sometimes.
Fri Apr 08, 2022 2:30 pm
Fri Apr 08, 2022 2:30 pm linkquote
this is why I wish Robot would stop saying ftlbs in his videos.
Fri Apr 08, 2022 11:13 pm
2008 fuoco
2008 fuoco
Fri Apr 08, 2022 11:13 pm linkquote
It dosen't help when your torque wrench has dual readings and your more used to ftlbs.i'll get used to newton metres just like i have got used to,well almost to the metric system . It's a bit easier than using BSF,whitworth,cycle in all it's different tpi's,BA, unc,unf bsp&t,ME and lots of odd ball specials that turn up sometimes.
Sat Apr 09, 2022 7:35 am
Sat Apr 09, 2022 7:35 am linkquote
You should always consult the shop manual and not take somebody word in a video. Robot has made mistakes multiple times, and corrected later in the video. If youu don't watch the whole video you may not catch the correction, always check the shop manual unless you know what the torque is supposed to be.
Sun Apr 17, 2022 2:05 am
Sun Apr 17, 2022 2:05 am linkquote
So, almost feeling quite pleased with myself, replaced transmission cover, replaced badly scored brake disc, put on new tyre, torqued correctly, loctite, and then discovered this…
Bonus component. Think it goes between brake hub and transmission cover.
Sun Apr 17, 2022 2:12 am
Sun Apr 17, 2022 2:12 am linkquote
For those interested, here is inside of transmission. And how badly scored a disc can get.
Old v new discs
New transmission cover
Cracked brake mountings
Inside final drive
Sun Apr 17, 2022 2:19 am
Sun Apr 17, 2022 2:19 am linkquote
Looks like it goes between wheel and swing arm, that's a lot less hassle, apart from that bloody split pin.
Sun Apr 17, 2022 6:48 am
Sun Apr 17, 2022 6:48 am linkquote
LOCKTITE why ? where? NO locktite, no locktite.
Sun Apr 17, 2022 9:16 am
Sun Apr 17, 2022 9:16 am linkquote
On the little bolts holding the brake disc on.
Sun Apr 17, 2022 2:36 pm
2012 Genuine Stella 150 4T "Penultimate"
Sun Apr 17, 2022 2:36 pm linkquote
Many of us have been where you are. Nothing like finishing a job with parts left over.
At least you caught it before you tried to ride it.
Good luck.
Thu Apr 21, 2022 7:53 pm
50cc Beo, BigBeo 2003
Thu Apr 21, 2022 7:53 pm linkquote
Ah, no problem, you do not need to dismount it from the wheel.
Fri Apr 22, 2022 3:44 pm
Fri Apr 22, 2022 3:44 pm linkquote
ok ok I imagined you locktighting all the bolts on the cover and everything
[ Time: 0.0314s ][ Queries: 7 (0.0097s) ][ Debug on ][ 211 ][ Thing One ]
