Sat Apr 09, 2022 6:03 am
125 TS VNL3
125 TS VNL3
Sat Apr 09, 2022 6:03 am linkquote
i just bought this model and cosindering some small upgrades. my biggest questioning is what type or what exhausts can be fitted on this scooter with no modifications on the frame. i would be gratefull if there are some pictures also with the exhausts fitted.
thanks in advance
Mon Apr 11, 2022 12:15 am
Faro basso 53, Motovespa 58, V50 71
Mon Apr 11, 2022 12:15 am linkquote
Congrats, great looking scoot!
Not sure on the US models but in Europe this is a v50 not a special, the specials in Europe have a plastic nosecone and square headlight and are a lot less popular than the v50's (nobody wants a plastic nose).
On my v50 i fitted a banana exhaust (model from the et3) without any mods and it runs great. Every scootershop I know sells them.
Mon Apr 11, 2022 12:45 am
Vespa ET4
Vespa ET4
Mon Apr 11, 2022 12:45 am linkquote
Nice original condition . I fitted a Sito+ on mine with no other mods and it certainly improved the performance .
Mon Apr 11, 2022 5:40 am
125 TS VNL3
125 TS VNL3
Mon Apr 11, 2022 5:40 am linkquote
its not familiar model if you live in EU. in US its like V50 here in EU. also special 50 is very familiar in Italy. i would like to have a Special with square headlight. i really love em. also this Special cause it has a left battery tray under the side panel unfortunatelly there are not so many options for exhausts!
Mon Apr 11, 2022 5:42 am
125 TS VNL3
125 TS VNL3
Mon Apr 11, 2022 5:42 am linkquote
unfortunately i might even go for a pk engine fitted on cause i already have some parts to tune it a little bit such as malossi 136 with reed valve. full circle crankshaft etc etc
Tue Apr 12, 2022 3:33 am
PX 200
PX 200
Tue Apr 12, 2022 3:33 am linkquote
I would swap my px200 for a plastic nose 50 special in a heart beat… even a non starting one…
Its such a great scooter
Tue Apr 12, 2022 11:45 pm
Tue Apr 12, 2022 11:45 pm linkquote
I've sold these in the Netherlands after complete paint and revision for barely a 1000 euros gone up a little in the past, but still way below the v50's in price.
Wed Apr 13, 2022 3:17 am
PX 200
PX 200
Wed Apr 13, 2022 3:17 am linkquote
I'll buy one from you, even a non starter
Wed Apr 13, 2022 7:34 am
125 TS VNL3
125 TS VNL3
Wed Apr 13, 2022 7:34 am linkquote
i am also interested
Wed Apr 13, 2022 10:54 pm
Wed Apr 13, 2022 10:54 pm linkquote
well then keep an eye on marktplaats.nl the dutch premier buying/selling website
i only have a motovespa for sale and a 50cc italjet dragster at the moment
Sat May 07, 2022 8:11 am
Sat May 07, 2022 8:11 am linkquote
thanks in advance
Hooray! Looks like our paths will just cross before I leave here, and we'll get a chance meet up tomorrow. Lotsa small frame action here including one old PK50 from Hell and a sweet all original 50S from Heaven we are amateur restoring, including many new parts and a PRO paint job, no rattle cans here except fork and rims, a few motor parts etc.
But I sure hope you can come on your USA 50Special and I can tell you what you like if I know. It's a fairly rare early one w/ the old style steel horncast and round headlite.
The 50S we are working on now as recieved
Lovely one kick motor needed little, mostly just clean up and now ready to drop in.
Yes drop in, we will invert the frame!
~8 hours after arrival
My USA 50 Special
Tue May 10, 2022 9:26 pm
125 TS VNL3
125 TS VNL3
Tue May 10, 2022 9:26 pm linkquote
It was a pleasure meeting u. I admire the endless thirst u have on learning new things. I really enjoyed the talk. You ve shown and told me lots of things. Just to know it was a big challenge to come there, drive about 15km with my us special cause my top speed is about 40km/h 😱. Insane right? Definitely worth the fuss 😁🥳. So now i am in a search for front headlight. If there is any one that selling one let me know. If i wont find an original i could buy a repro.
Sun Jun 26, 2022 10:29 am
125 TS VNL3
125 TS VNL3
Sun Jun 26, 2022 10:29 am linkquote
Small treasures found when looking better
Engine button
Are there any brake levers that press this button?
Sun Jun 26, 2022 10:37 am
Parmakit Primavera -74, Polini Primavera -68, Stock GL 150 -59, VMC 177 Bajaj Chetak 125 -95
Sun Jun 26, 2022 10:37 am linkquote
On my Bajaj there is only a flap of metal with a 90 degree bend attached to the lever with a screw. This tab presses the button when the lever is not pulled.
Sun Jun 26, 2022 10:53 am
125 TS VNL3
125 TS VNL3
Sun Jun 26, 2022 10:53 am linkquote
Thanks. This is how it originally was? Also does anyone know where i can buy a front headlight with rim?
Sun Jun 26, 2022 11:02 am
Sun Jun 26, 2022 11:02 am linkquote
To my knowledge this is how it rolled down the line in India 1995.
Sun Jun 26, 2022 12:13 pm
Sun Jun 26, 2022 12:13 pm linkquote
Yes, the switch here is wired in parallel with the foot switch and should light up your brake light as is, but with that screw/post screwed in your lever, the switch is off when lever is not pulled. The other swirth on your motor is your neutral lite indicator switch, the footbrake switch is hidden in your foot pedal assembly.
This is not right, only the brake cable should pass thru the tube windows, those wires should run along the side. Also can see it's not the original lever that had the screw post as it doesn't quite fit into that notch. You could drill and tap your lever and add a screw to make it work after you verify your brake lite is ON now after you connect its wires and pushing switch turns it OFF. You can see the switch adjustment to make it work at the right time.
Good luck! I'm still hunting for a headlight rim, can you verify the casting diameter?
Fri Jul 01, 2022 11:45 pm
Fri Jul 01, 2022 11:45 pm linkquote
I think I found you a headlight rim, also the proper reflector that needs a lens. There are some odd screws needed as well, one screws into the other.
Here's the rim, please confirm your diameter.
Sat Jul 02, 2022 4:02 am
1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
Sat Jul 02, 2022 4:02 am linkquote
American market headlight assembly.
https://www.scootermercato.com/Scooter-Parts/Headlight-Assemblies/114435
Sun Jul 03, 2022 8:44 am
125 TS VNL3
125 TS VNL3
Sun Jul 03, 2022 8:44 am linkquote
ur the man! thanks for what ur doin till now!
Sun Jul 03, 2022 8:46 am
125 TS VNL3
125 TS VNL3
Sun Jul 03, 2022 8:46 am linkquote
Mattgyver wrote:
i ve seen that but from the picture i dont thing that its the correct one. at least dont look like the one that Voodoo posted above. maybe pictures are not the right ones.
Sun Jul 03, 2022 10:40 am
Sun Jul 03, 2022 10:40 am linkquote
You NEED to get me the headset casting diameter to confirm, and a pic w/ that bodge trim ring removed would help. There should be screw holes at 3, 6 and 9 o'clock.
[ Time: 0.0472s ][ Queries: 7 (0.0238s) ][ Debug on ][ 211 ][ Thing One ]
