Mon, 11 Apr 2022 22:23:24 +0000
Piaggio mp3 300 youban
Mon, 11 Apr 2022 22:23:24 +0000 quote
Hi I have a 2013 piaggio mp3 300 youban. Today whilst riding it cut out & the red warning light came on. It would not fire up. I found it had blown the fuse for the stabiliser lock.
Any idea why this happened? Thanks
Tue, 12 Apr 2022 02:23:30 +0000
Tue, 12 Apr 2022 02:23:30 +0000 quote
Post a pic. Which red light???
Tue, 12 Apr 2022 21:57:44 +0000
Tue, 12 Apr 2022 21:57:44 +0000 quote
The tilt lock light on the right side of the dash panel.
Once it has cut out the bike does nothing until the fuse is changed. As soon as its changed it starts up again but doesn't run for long before it blows the fuse again & cuts out??
Wed, 13 Apr 2022 02:32:22 +0000
Wed, 13 Apr 2022 02:32:22 +0000 quote
Sounds like you have a short to ground causing the fuse to blow.
Wed, 13 Apr 2022 17:40:02 +0000
Wed, 13 Apr 2022 17:40:02 +0000 quote
Yes would seem so but cannot find the problem. Have taken all the panels off to look but no joy so far 😕
Fri, 29 Apr 2022 22:36:02 +0000
Fri, 29 Apr 2022 22:36:02 +0000 quote
Found that the header tank had a couple of tiny leaks. Replaced the tank & so far its running OK...
Other than still won't rev with tilt lock on. It has to be double clicked to make it work 🤦‍♀️
Sat, 30 Apr 2022 00:38:47 +0000
Sat, 30 Apr 2022 00:38:47 +0000 quote
that is correct and how it is suppose to be, its a safety feature.
Sat, 07 May 2022 16:15:39 +0000
Sat, 07 May 2022 16:15:39 +0000 quote
OK thank you but I thought it should come on automatically when you pull up at a junction I didn't realise you had to switch it on manually. Should it go off automatically when you set off? I have to click mine off. Is this correct?
Thank you
Sat, 07 May 2022 22:29:53 +0000
Sat, 07 May 2022 22:29:53 +0000 quote
Not quite smart enough to turn on automatically. Too many variables.
Should turn off when you pull away. Sounds like there is a problem with your seat switch.
Sun, 08 May 2022 07:48:23 +0000
Sun, 08 May 2022 07:48:23 +0000 quote
Do you remember which fuse(s) blown?
Sun, 08 May 2022 21:24:48 +0000
Sun, 08 May 2022 21:24:48 +0000 quote
Thank you
I've tried disconnecting and bypassing the seat switch but neither made any difference.
The fuse problem was solved by changing the leaking header tank. The spraying water onto the electrics seemed to be causing the problem
Sun, 08 May 2022 21:37:31 +0000
Sun, 08 May 2022 21:37:31 +0000 quote
Royh wrote:
Thank you
How did you bypass the switch? You can't just jumper across it - that won't work. It has to be jumpered by a 3kohm resistor (3.3K will do).
Wed, 08 Jun 2022 22:00:07 +0000
Wed, 08 Jun 2022 22:00:07 +0000 quote
OK thank you. I didn't realise that. I did just jump across it.
Where can I get a new sensor from?
Thu, 09 Jun 2022 00:16:58 +0000
Thu, 09 Jun 2022 00:16:58 +0000 quote
Which part of the world are you in?
[ Time: 0.0374s ][ Queries: 6 (0.0165s) ][ Debug on ][ 281 ][ Thing Two ]
