thanks in advance
i just bought this model and cosindering some small upgrades. my biggest questioning is what type or what exhausts can be fitted on this scooter with no modifications on the frame. i would be gratefull if there are some pictures also with the exhausts fitted.
thanks in advance ![]() |
![]() Faro basso 53, Motovespa 58, V50 71
Posts: 40 Location: Netherlands |
Congrats, great looking scoot!
Not sure on the US models but in Europe this is a v50 not a special, the specials in Europe have a plastic nosecone and square headlight and are a lot less popular than the v50's (nobody wants a plastic nose). On my v50 i fitted a banana exhaust (model from the et3) without any mods and it runs great. Every scootershop I know sells them. |
Sjoerdo wrote: Congrats, great looking scoot! Not sure on the US models but in Europe this is a v50 not a special, the specials in Europe have a plastic nosecone and square headlight and are a lot less popular than the v50's (nobody wants a plastic nose). On my v50 i fitted a banana exhaust (model from the et3) without any mods and it runs great. Every scootershop I know sells them. |
JOHNTEE wrote: Nice original condition . I fitted a Sito+ on mine with no other mods and it certainly improved the performance . |
108 wrote: I would swap my px200 for a plastic nose 50 special in a heart beat… even a non starting one… Its such a great scooter |
![]() '74 50s x3 '78 P200 E '84 Cosa '91 PK50XL2 '58 AllState '68 Sprint '80 50special and a '66(?) Super125
Posts: 8614 Location: seattle/athens |
kourabies wrote: i just bought this model and cosindering some small upgrades. my biggest questioning is what type or what exhausts can be fitted on this scooter with no modifications on the frame. i would be gratefull if there are some pictures also with the exhausts fitted. thanks in advance But I sure hope you can come on your USA 50Special and I can tell you what you like if I know. It's a fairly rare early one w/ the old style steel horncast and round headlite. ![]() The 50S we are working on now as recieved ![]() Lovely one kick motor needed little, mostly just clean up and now ready to drop in. Yes drop in, we will invert the frame! ![]() ~8 hours after arrival ![]() My USA 50 Special |
V oodoo wrote: Hooray! Looks like our paths will just cross before I leave here, and we'll get a chance meet up tomorrow. Lotsa small frame action here including one old PK50 from Hell and a sweet all original 50S from Heaven we are amateur restoring, including many new parts and a PRO paint job, no rattle cans here except fork and rims, a few motor parts etc. But I sure hope you can come on your USA 50Special and I can tell you what you like if I know. It's a fairly rare early one w/ the old style steel horncast and round headlite. |
![]() Parmakit Primavera -74, Polini Primavera -68, Stock GL 150 -59, VMC 177 Bajaj Chetak 125 -95
Posts: 52 Location: Finland |
Thanks. This is how it originally was? Also does anyone know where i can buy a front headlight with rim?
Yes, the switch here is wired in parallel with the foot switch and should light up your brake light as is, but with that screw/post screwed in your lever, the switch is off when lever is not pulled. The other swirth on your motor is your neutral lite indicator switch, the footbrake switch is hidden in your foot pedal assembly.
![]() This is not right, only the brake cable should pass thru the tube windows, those wires should run along the side. Also can see it's not the original lever that had the screw post as it doesn't quite fit into that notch. You could drill and tap your lever and add a screw to make it work after you verify your brake lite is ON now after you connect its wires and pushing switch turns it OFF. You can see the switch adjustment to make it work at the right time. Good luck! I'm still hunting for a headlight rim, can you verify the casting diameter? |
1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
Posts: 595 Location: Atlanta |
American market headlight assembly.
https://www.scootermercato.com/Scooter-Parts/Headlight-Assemblies/114435 |
Mattgyver wrote: American market headlight assembly. https://www.scootermercato.com/Scooter-Parts/Headlight-Assemblies/114435 |
