Mon Apr 11, 2022 2:23 pm
Piaggio mp3 300 youban
Mon Apr 11, 2022 2:23 pm linkquote
Hi I have a 2013 piaggio mp3 300 youban. Today whilst riding it cut out & the red warning light came on. It would not fire up. I found it had blown the fuse for the stabiliser lock.
Any idea why this happened? Thanks
Mon Apr 11, 2022 6:23 pm
Mon Apr 11, 2022 6:23 pm linkquote
Post a pic. Which red light???
Tue Apr 12, 2022 1:57 pm
Tue Apr 12, 2022 1:57 pm linkquote
The tilt lock light on the right side of the dash panel.
Once it has cut out the bike does nothing until the fuse is changed. As soon as its changed it starts up again but doesn't run for long before it blows the fuse again & cuts out??
Tue Apr 12, 2022 6:32 pm
Tue Apr 12, 2022 6:32 pm linkquote
Sounds like you have a short to ground causing the fuse to blow.
Wed Apr 13, 2022 9:40 am
Wed Apr 13, 2022 9:40 am linkquote
Yes would seem so but cannot find the problem. Have taken all the panels off to look but no joy so far 😕
Fri Apr 29, 2022 2:36 pm
Fri Apr 29, 2022 2:36 pm linkquote
Found that the header tank had a couple of tiny leaks. Replaced the tank & so far its running OK...
Other than still won't rev with tilt lock on. It has to be double clicked to make it work 🤦‍♀️
Fri Apr 29, 2022 4:38 pm
Fri Apr 29, 2022 4:38 pm linkquote
that is correct and how it is suppose to be, its a safety feature.
Sat May 07, 2022 8:15 am
Sat May 07, 2022 8:15 am linkquote
OK thank you but I thought it should come on automatically when you pull up at a junction I didn't realise you had to switch it on manually. Should it go off automatically when you set off? I have to click mine off. Is this correct?
Thank you
Sat May 07, 2022 2:29 pm
Sat May 07, 2022 2:29 pm linkquote
Not quite smart enough to turn on automatically. Too many variables.
Should turn off when you pull away. Sounds like there is a problem with your seat switch.
Sat May 07, 2022 11:48 pm
Sat May 07, 2022 11:48 pm linkquote
Do you remember which fuse(s) blown?
Sun May 08, 2022 1:24 pm
Sun May 08, 2022 1:24 pm linkquote
Thank you
I've tried disconnecting and bypassing the seat switch but neither made any difference.
The fuse problem was solved by changing the leaking header tank. The spraying water onto the electrics seemed to be causing the problem
Sun May 08, 2022 1:37 pm
Sun May 08, 2022 1:37 pm linkquote
Royh wrote:
Thank you
How did you bypass the switch? You can't just jumper across it - that won't work. It has to be jumpered by a 3kohm resistor (3.3K will do).
Wed Jun 08, 2022 2:00 pm
Wed Jun 08, 2022 2:00 pm linkquote
OK thank you. I didn't realise that. I did just jump across it.
Where can I get a new sensor from?
Wed Jun 08, 2022 4:16 pm
Wed Jun 08, 2022 4:16 pm linkquote
Which part of the world are you in?
[ Time: 0.0414s ][ Queries: 7 (0.0165s) ][ Debug on ][ 211 ][ Thing One ]
