Mon, 18 Apr 2022 23:48:36 +0000
2008 MP3 250
2008 MP3 250
Mon, 18 Apr 2022 23:48:36 +0000 quote
My 08 MP3 250, will it run without the seat on? Did I read on here somewhere that the scoot won't rev over 1600 rpm without the seat on or at least closed. I've gotten somewhere in the past 4 months. Replaced fuel pump and injector and cleaned the throttle body best I could and she at least will start and run for 10 to 15 seconds without starting fluid but won't rev.. Most of the body work is still off along with the taillights. Anything there that would keep it from revving?
Tue, 19 Apr 2022 06:22:40 +0000
Tue, 19 Apr 2022 06:22:40 +0000 quote
MP3s have a seat sensor. Without some load on the saddle, the bike will not rev.
Tue, 19 Apr 2022 09:05:26 +0000
Tue, 19 Apr 2022 09:05:26 +0000 quote
yes it will simply unlock tilt lock but i should run longer then 10 to 15 secs
Tue, 19 Apr 2022 13:42:05 +0000
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Tue, 19 Apr 2022 13:42:05 +0000 quote
Yeah either put the seat on and connect the sensor then sit on it (safest method) or put a jumper across the seat sensor clip and put it on the center stand.
Sat, 23 Apr 2022 15:20:54 +0000
2008 MP3 250
2008 MP3 250
Sat, 23 Apr 2022 15:20:54 +0000 quote
Can only a vespa dealer do the flash of the ECU? After reading about other peoples experience with that being done sounds like it couldn't hurt mine. Not sure I can really trust my local Vespa dealer. It's a Honda shop here in Jacksonville Fla. I've read that it's expensive, not sure what that means but I know this shop charges $90.00 per half hour. I would think it would take less than a half hour but who knows. I'm just like everyone else, I don't want to get screwed. Thanks. Tom
Sat, 23 Apr 2022 15:36:12 +0000
Sat, 23 Apr 2022 15:36:12 +0000 quote
Only Vespa/Piaggio dealers have access to the (dealer only) PADS tool to access to the ECU.
[ Time: 0.0262s ][ Queries: 4 (0.0058s) ][ Debug on ][ 283 ][ Thing Two ]
