Vespa gts300 not starting I checked it. It has Fuel, Spark, Compression and key detected. I removed evap system checked the fuel pump and fuel injectors it works, I checked piston still amazing new, I adjusted the valves, I did the timing at TDC, I replaced air filter and oil filter
Modern Vespa is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com All Content Copyright 2005-2023 by Modern Vespa. All Rights Reserved.
[ Time: 0.0288s ][ Queries: 4 (0.0079s) ][ Debug on ][ 277 ][ Thing Two ]
