Mon May 02, 2022 6:14 pm
Vespa GTS300 ie
Vespa GTS300 ie
Mon May 02, 2022 6:14 pm linkquote
Vespa gts300 not starting I checked it. It has Fuel, Spark, Compression and key detected. I removed evap system checked the fuel pump and fuel injectors it works, I checked piston still amazing new, I adjusted the valves, I did the timing at TDC, I replaced air filter and oil filter
Mon May 02, 2022 10:59 pm
Mon May 02, 2022 10:59 pm linkquote
Wrong forum section. You are in the MP3 section.
Tue May 03, 2022 2:13 am
Vespa GTS300 ie
Vespa GTS300 ie
Tue May 03, 2022 2:13 am linkquote
Sorry do you know which section I have to post that in?
Tue May 03, 2022 2:29 am
Tue May 03, 2022 2:29 am linkquote
Post in the General Discussion forum.
Tue May 03, 2022 2:30 am
Vespa GTS300 ie
Vespa GTS300 ie
Tue May 03, 2022 2:30 am linkquote
Thank you man appreciate it
[ Time: 0.0472s ][ Queries: 5 (0.0276s) ][ Debug on ][ 211 ][ Thing One ]
