Sat, 07 May 2022 00:12:21 +0000
Vespa 300 piaggio bv250
Sat, 07 May 2022 00:12:21 +0000 quote
I have a used bike I pick up a few months ago
2006 bv 250
The cvt seems to vibrate a lot more than any scooter I have had before . I have a had lot of them.
Is this normal? The whole bike at idle vibates the top case make nose?
I took it to a bike shop they do all brands.
They thought it was normal?
When I change the belt it seems to have a lot of play left to right is this normal?
I am at least the 3rd owner
I don't have much history on this machine
My 06 vespa gt was never like this?
HELP please
Sat, 07 May 2022 01:28:25 +0000
2020 BV350
2020 BV350
Sat, 07 May 2022 01:28:25 +0000 quote
My top case rattles like craze on my BV 350 with 260 miles on it. I took it off & made sure it was installed correctly; It was. I'd think as soon as you give it a little gas, everything would smooth out.
Sat, 07 May 2022 04:49:27 +0000
2019 GTS300 Supertech E3 47,000km
Sat, 07 May 2022 04:49:27 +0000 quote
a few rattles in different parts of the bike when idling is normal. most will go away when moving. if they don't then check them.
Sat, 07 May 2022 05:25:12 +0000
Sat, 07 May 2022 05:25:12 +0000 quote
Any vibrations are exaggerated with a top case fitted. If your belt wasn't seated correctly, you'd soon know about it when riding. What you describe sounds completely normal.
Sat, 07 May 2022 07:48:07 +0000
Sat, 07 May 2022 07:48:07 +0000 quote
Thanks so much
Thu, 12 May 2022 21:45:29 +0000
Thu, 12 May 2022 21:45:29 +0000 quote
It really vibates at city speeds is this normal?
The side mount was changed.
Could it be a engine mount
It's been like this since I got it
I never had a cvt vibates like this one does.
Fri, 13 May 2022 09:48:40 +0000
Fri, 13 May 2022 09:48:40 +0000 quote
Bump
[ Time: 0.0266s ][ Queries: 4 (0.0062s) ][ Debug on ][ 283 ][ Thing Two ]
