Fri Apr 08, 2022 7:18 am
gilera fuoco 500ie
gilera fuoco 500ie
Fri Apr 08, 2022 7:18 am linkquote
Hi bike broke down ..battery went flat..melted charging relay connecter and fuse dead...got daughter to bring car over to charge battery and think I attached + to - minus side DOH! Blown fuse number 4 or 5( yellow) checked with multimeter 11.7 v...bike starts but tilt lock light on and doesn't rev much ?
Fri Apr 08, 2022 11:50 am
2008 fuoco
2008 fuoco
Fri Apr 08, 2022 11:50 am linkquote
Have you ever checked for the hidden fuse /starter relay under the seat potty for melting as well. Lots of info on here just search for 'hidden fuse' .It's a wonder the bike starts with battery at 11.7v as it's as flat as a fart.
Fri Apr 08, 2022 11:59 am
gilera fuoco 500ie
gilera fuoco 500ie
Fri Apr 08, 2022 11:59 am linkquote
Yep the underseat one all melted for second time. Gonna see if it can be moved .when I figure out where the other short is
Fri Apr 08, 2022 11:00 pm
2008 fuoco
2008 fuoco
Fri Apr 08, 2022 11:00 pm linkquote
Do what i did and make a bigger flap out of rubber sheet to supplement the plastic sheild thats fixed to the underside of the seat potty and encase the relay in a plastic bag it's kept mine dirt free. Best of luck with finding short.
Wed Apr 20, 2022 1:45 pm
gilera fuoco 500ie
gilera fuoco 500ie
Wed Apr 20, 2022 1:45 pm linkquote
Can this bike be towed? Really expensive to be brought back in a van..it only about 5 miles away
Wed Apr 20, 2022 4:54 pm
Wed Apr 20, 2022 4:54 pm linkquote
In the UK, only another motorcycle can tow a motorcycle. I've done it several times (non-mechanical offspring) and it's fine if done smoothly with the towed rider applying just the teeniest bit of rear brake.
Thu Apr 21, 2022 7:57 am
MP3
MP3
Thu Apr 21, 2022 7:57 am linkquote
It's a trike, and a 3 wheel Reliant can be towed by a car, so maybe yes.
Thu Apr 21, 2022 11:25 pm
2008 fuoco
2008 fuoco
Thu Apr 21, 2022 11:25 pm linkquote
Would you realy want to argue that point if pc plod stopped you
Thu Apr 21, 2022 11:44 pm
2008 fuoco
2008 fuoco
Thu Apr 21, 2022 11:44 pm linkquote
Iv'e only been towed once before and that was down the E10 in Belgium ,got a tank slapper where there were road works and all traffic was going down one carriageway and dropped it right infront of two police officers .I think we were told off for towing but as the tower was german and i a brit it was all foreign to us. One wanted to arrest us i think the other dident so we were told to be on our way to ostend to catch the boat. So would i recommend a tow ,not realy especialy around northampton , i don't think with the amount of traffic and speeds i woulden't want to be towed in a car. Do you not have breakdown cover?
Fri Apr 22, 2022 1:00 am
gilera fuoco 500ie
gilera fuoco 500ie
Fri Apr 22, 2022 1:00 am linkquote
AXA breakdown recovery won't do it and refer me to a company in London who don't answer ..will stick with the main ones next time I renew insurance
Fri Apr 22, 2022 4:18 am
Piaggio MP3 300 HPE
Piaggio MP3 300 HPE
Fri Apr 22, 2022 4:18 am linkquote
I'd complain - this is really shoddy. You should get some money back.
Fri Apr 22, 2022 1:22 pm
2008 fuoco
2008 fuoco
Fri Apr 22, 2022 1:22 pm linkquote
Raise a complaint with AXA without delay as if your breakdown is with AXA then it's up to them to provide it and not to fob you off and making you do all the work. Compensation should be in the offering for the delay.
Sat Apr 23, 2022 3:32 am
gilera fuoco 500ie
gilera fuoco 500ie
Sat Apr 23, 2022 3:32 am linkquote
Got towed back ..bit scary..lucky not far
Sun May 08, 2022 3:40 am
gilera fuoco 500ie
gilera fuoco 500ie
Sun May 08, 2022 3:40 am linkquote
This issue I have..starts but no rev over 2k..got side panels off guess seat and centre panel next
MP3 issue
Sun May 08, 2022 7:10 am
Sun May 08, 2022 7:10 am linkquote
are you sitting on the seat while trying to rev it up?
Sun May 08, 2022 8:05 am
gilera fuoco 500ie
gilera fuoco 500ie
Sun May 08, 2022 8:05 am linkquote
Yes
Sun May 08, 2022 8:48 am
Sun May 08, 2022 8:48 am linkquote
oddjob1 wrote:
Yes
have you tried double clicking the tilt lock off?
Sun May 08, 2022 8:50 am
gilera fuoco 500ie
gilera fuoco 500ie
Sun May 08, 2022 8:50 am linkquote
Yes tilt switch not working
Sun May 08, 2022 8:51 am
Sun May 08, 2022 8:51 am linkquote
till you get the tilt lock to turn off you won't be able to rev the engine over 2000 rpm
Sun May 08, 2022 9:31 am
gilera fuoco 500ie
gilera fuoco 500ie
Sun May 08, 2022 9:31 am linkquote
Pretty sure it has seat sensor bypass...so could the resistor have blown ..would this cause tilt lock problem? Or / and check wheel sensors?
Sun May 08, 2022 9:47 am
Sun May 08, 2022 9:47 am linkquote
Just 'pretty sure'? Check it! The 3kohm resistor (which is what it should be as a bypass for the seat sensor) won't blow. However, you should check neither end of it has shorted to the frame, which might upset the tilt-lock logic.
The most likely thing is that the connection to the resistor (or to the seat sensor if that's still in play) has come undone. Happens all the time when the seat's taken off and put back on again, which is necessary for many maintenance tasks.
Mon May 09, 2022 7:47 pm
Mon May 09, 2022 7:47 pm linkquote
You don't have to bypass seat sensor to unlock tilt lock.
On my 2009 Piaggio MP3 Sport 500 (Gilera Fuoco), I can double right-click the tilt lock, to unlock. Then the bike can rev over 2000 (no red tilt lock light).
Tue May 10, 2022 4:00 am
Tue May 10, 2022 4:00 am linkquote
exactly
Tue May 10, 2022 7:50 am
Tue May 10, 2022 7:50 am linkquote
IIRC if either of the seat sensor wires touches the frame, then even the switch won't work - stand ready to be corrected! If there is a bypass of some sort, and its connections are funky, this may be the problem.
Mon May 23, 2022 7:47 am
gilera fuoco 500ie
gilera fuoco 500ie
Mon May 23, 2022 7:47 am linkquote
Took seat off and had poke around still a short somewhere and taken off plastic around tank..guess next to take off around handbrake..check parking ECU
Mon May 30, 2022 7:53 am
gilera fuoco 500ie
gilera fuoco 500ie
Mon May 30, 2022 7:53 am linkquote
Tried with 3k ohm resistor still same
Tue Jun 07, 2022 5:57 am
Tue Jun 07, 2022 5:57 am linkquote
One tip, you can check short with the help of the fuse, to roughly narrow down the group of components.
[ Time: 0.0490s ][ Queries: 7 (0.0250s) ][ Debug on ][ 211 ][ Thing One ]
