So I've got a new dr102 kit and told to head to motorparts.it for instructions of which I found but there's nothing in there about ignition timings etc. anybody fitted one on a smallie or have some documentation laying about they could post on here or by PM which is a bit more informative ? Thanks guys
that egig 170 isn't too badly priced when you compare to others…
Until you add the crankshaft needed, and the clutch and if you need 4 speed conversion. It gets pricey regardless of the affordability of the cylinder kit itself.
Thank you so much , that's bloody brilliant mate. What a good little chart. I salute you sir 👍
No worries!
I am tempted.
It's still cheaper than a quatrinni
Anything above 112cc you start to need the crank and the exhausts…
Modern Vespa is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com All Content Copyright 2005-2023 by Modern Vespa. All Rights Reserved.
[ Time: 0.0264s ][ Queries: 6 (0.0028s) ][ Debug on ][ 277 ][ Thing Two ]
