Tue May 10, 2022 7:40 am
Posts: 504 Location: Planet Earth |
So I've got a new dr102 kit and told to head to motorparts.it for instructions of which I found but there's nothing in there about ignition timings etc. anybody fitted one on a smallie or have some documentation laying about they could post on here or by PM which is a bit more informative ? Thanks guys
Tue May 10, 2022 9:12 am
![]() VSX, Stella 177, Stella 150, VNX1T, V9A1T, V9B1T
Posts: 3909 Location: Staten Island, NY |
108 wrote: 17deg? Attached some info, should be it… Looking at small frame info myself… that egig 170 isn't too badly priced when you compare to others… I am tempted. |
ferriswolf wrote: Thank you so much , that's bloody brilliant mate. What a good little chart. I salute you sir 👍 swiss1939 wrote: Until you add the crankshaft needed, and the clutch and if you need 4 speed conversion. It gets pricey regardless of the affordability of the cylinder kit itself. I am tempted. Anything above 112cc you start to need the crank and the exhausts… |
![]() Yellow GTS 300 Super, Black GTS 300 Super Sport, Polaris Grey Rally 200, Blue Marine Primavera ET3, Coral Red 50 Special
Posts: 203 Location: London |
108 wrote: 17deg? Attached some info, should be it… Looking at small frame info myself… that egig 170 isn't too badly priced when you compare to others… |
