Hi guys,
My KS is lower, my guess is it slipped 1 tooth, hard to say. Its on top, return spring is fine.
Any suggestion for a quality replacement? Vespa 125 GTR 1977, tuned BGM 177
TIA
![]() 125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
Posts: 277 Location: Madeira Island |
Tue, 10 May 2022 13:05:33 +0000
quote
Hi guys,
My KS is lower, my guess is it slipped 1 tooth, hard to say. Its on top, return spring is fine. Any suggestion for a quality replacement? Vespa 125 GTR 1977, tuned BGM 177 TIA |
Tue, 10 May 2022 13:20:23 +0000
Posts: 1420 Location: Philadelphia |
Tue, 10 May 2022 13:23:30 +0000
quote
FridayMatinee wrote: What engine is it for? |
![]() 1979 P150X, 1983 P200E, 1987 PK125XL Elestart, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 3590 Location: Veria, Greece |
Tue, 10 May 2022 13:28:04 +0000
quote
Is it the short one or the longer one found on Rallys?? If it's the short one, get one for a Rally 200. It's longer so gives a bigger leverage. I would avoid FA they're made of cheese…
Tue, 10 May 2022 13:57:47 +0000
quote
SaFiS wrote: Is it the short one or the longer one found on Rallys?? If it's the short one, get one for a Rally 200. It's longer so gives a bigger leverage. I would avoid FA they're made of cheese… I tried a close-up shot, it skipped one tooth, right? ![]() |
Tue, 10 May 2022 20:47:00 +0000
quote
SIP brand kickstarter levers seems ok.
I know they act as a fuse and are made to break, should I order half a dozen? |
![]() 73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 90 V5N 50, 01 ET2, 2015 HD Road Glide Special
Posts: 4676 Location: Oceanside, CA |
Tue, 10 May 2022 20:49:51 +0000
quote
If you ever ruin a brand new kickstart lever fairly quickly, your kickstart quadrant is the culprit. I had a bad quadrant ruin 2 kickstart levers. Everything was torqued to spec, all new etc etc. At $50 a pop, I wasnt happy two were ruined that quick. Showed my vendor the damage and they gave me some credit towards new parts.
Tue, 10 May 2022 21:23:29 +0000
quote
MJRally wrote: If you ever ruin a brand new kickstart lever fairly quickly, your kickstart quadrant is the culprit. I had a bad quadrant ruin 2 kickstart levers. Everything was torqued to spec, all new etc etc. At $50 a pop, I wasnt happy two were ruined that quick. Showed my vendor the damage and they gave me some credit towards new parts. |
![]() Scattered remnants of (two!) 1974 Rallys
Posts: 1845 Location: San Francisco, CA |
Tue, 10 May 2022 22:28:44 +0000
quote
SaFiS wrote: Is it the short one or the longer one found on Rallys?? If it's the short one, get one for a Rally 200. It's longer so gives a bigger leverage. I would avoid FA they're made of cheese… The FA Italia ones are the ones I see that are the same shape as the original. Looks like the GTR and Rally are the same. ![]() ![]() Looks close. ![]() Looks much different. |
Tue, 10 May 2022 22:43:31 +0000
quote
hjo wrote: Oh no! I was just going to buy one of those. The FA Italia ones are the ones I see that are the same shape as the original. Looks like the GTR and Rally are the same. FAs are OKish but tend to wear fast... ![]() |
Tue, 10 May 2022 23:08:42 +0000
quote
It is shorter!
It's a shame. The original ones had that Piaggio shield badge. But mine is totally scraped away and worn at the end. ![]() ![]() |
Wed, 11 May 2022 08:41:24 +0000
quote
I ended up going to the SIP "standard", the one which resembles the original shape
There were apparently 3 options compatible with the GTR/Sprint: the "Standard", the "VBB Style" and the "Rally Style", which, AFAIK these last two would only be adequate for a PX engine on an old frame (as the "exercise" bellow shows they would stand too low). Safis, I guess you were referring to the Rally 200 version (the real one), ok, that would look fine, but I have strong legs and went for the version more alike the original ![]() Thanks ![]() |
Wed, 18 May 2022 07:59:34 +0000
quote
Yo guys, picture above is so obvious now ...
Just discovering things on the go Any tips that help changing the kick start lever easy? It looks as I need to remove the flywheel cover? Also, if the actual lever is stuck on shaft, is it safe to tap it out from behind? Thanks! |
Wed, 18 May 2022 09:35:51 +0000
quote
Just remove the bolt. It holds it in place.
The lever will come off easy. Maybe check the torque setting putting it back on. 16 to 19 foot pounds. More and it will break, less and it can slip. Take photos of the quadrant. It's probably fine, but there could be an issue that's visible. |
Wed, 18 May 2022 13:39:39 +0000
quote
hjo wrote: Just remove the bolt. It holds it in place. The lever will come off easy. Maybe check the torque setting putting it back on. 16 to 19 foot pounds. More and it will break, less and it can slip. Take photos of the quadrant. It's probably fine, but there could be an issue that's visible. Maybe pulling out the spark plug and rotating the kick start lever by hand I can remove the bold without taking off the flywheel cover? the same for installing the new one... I'll take photos from the quadrant shaft for reference, I hope its fine |
Wed, 18 May 2022 17:02:42 +0000
quote
PSMA wrote: Yo guys, picture above is so obvious now ... Just discovering things on the go Any tips that help changing the kick start lever easy? It looks as I need to remove the flywheel cover? Also, if the actual lever is stuck on shaft, is it safe to tap it out from behind? Thanks! |
![]() Wed, 18 May 2022 17:11:22 +0000
1975 Rally 215, 1960 Lambretta 195 s2
Posts: 416 Location: San Francisco Bay Area |
![]() 1975 Rally 215, 1960 Lambretta 195 s2
quote
This helped me when I replaced my ss 180's ks quadrant. It wasn't too hard
Sat, 21 May 2022 13:24:21 +0000
quote
Hi, opinions on the quadrant shaft condition please?
Doesn't look bad to me. Yet to receive the new kick start lever, meanwhile removed the old one, completely destroyed ![]() ![]() |
Mon, 23 May 2022 21:12:26 +0000
quote
FridayMatinee wrote: Flywheel cover does need to come off. The bolt won't come out otherwise. |
