Hi guys,
My KS is lower, my guess is it slipped 1 tooth, hard to say. Its on top, return spring is fine.
Any suggestion for a quality replacement? Vespa 125 GTR 1977, tuned BGM 177
TIA
![]() 125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
Posts: 194 Location: Madeira Island |
![]() Tue May 10, 2022 5:20 am
Posts: 912 Location: Philadelphia |
![]() 1958 Allstate 177VMC, 2005 70cc Yamaha Vino
Posts: 3002 Location: Veria, Greece |
![]() 73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 Elite 80,90 V5N 50, 01 ET2, 2015 HD Road Glide Special, 2011 Ural Tourist
Posts: 4374 Location: Oceanside, CA |
If you ever ruin a brand new kickstart lever fairly quickly, your kickstart quadrant is the culprit. I had a bad quadrant ruin 2 kickstart levers. Everything was torqued to spec, all new etc etc. At $50 a pop, I wasnt happy two were ruined that quick. Showed my vendor the damage and they gave me some credit towards new parts.
MJRally wrote: If you ever ruin a brand new kickstart lever fairly quickly, your kickstart quadrant is the culprit. I had a bad quadrant ruin 2 kickstart levers. Everything was torqued to spec, all new etc etc. At $50 a pop, I wasnt happy two were ruined that quick. Showed my vendor the damage and they gave me some credit towards new parts. |
![]() Scattered remnants of (two!) 1974 Rallys
Posts: 1416 Location: San Francisco, CA |
SaFiS wrote: Is it the short one or the longer one found on Rallys?? If it's the short one, get one for a Rally 200. It's longer so gives a bigger leverage. I would avoid FA they're made of cheese… The FA Italia ones are the ones I see that are the same shape as the original. Looks like the GTR and Rally are the same. ![]() ![]() Looks close. ![]() Looks much different. |
hjo wrote: Oh no! I was just going to buy one of those. The FA Italia ones are the ones I see that are the same shape as the original. Looks like the GTR and Rally are the same. FAs are OKish but tend to wear fast... ![]() |
I ended up going to the SIP "standard", the one which resembles the original shape
There were apparently 3 options compatible with the GTR/Sprint: the "Standard", the "VBB Style" and the "Rally Style", which, AFAIK these last two would only be adequate for a PX engine on an old frame (as the "exercise" bellow shows they would stand too low). Safis, I guess you were referring to the Rally 200 version (the real one), ok, that would look fine, but I have strong legs and went for the version more alike the original ![]() Thanks ![]() |
Yo guys, picture above is so obvious now ...
Just discovering things on the go Any tips that help changing the kick start lever easy? It looks as I need to remove the flywheel cover? Also, if the actual lever is stuck on shaft, is it safe to tap it out from behind? Thanks! |
Just remove the bolt. It holds it in place.
The lever will come off easy. Maybe check the torque setting putting it back on. 16 to 19 foot pounds. More and it will break, less and it can slip. Take photos of the quadrant. It's probably fine, but there could be an issue that's visible. |
hjo wrote: Just remove the bolt. It holds it in place. The lever will come off easy. Maybe check the torque setting putting it back on. 16 to 19 foot pounds. More and it will break, less and it can slip. Take photos of the quadrant. It's probably fine, but there could be an issue that's visible. Maybe pulling out the spark plug and rotating the kick start lever by hand I can remove the bold without taking off the flywheel cover? the same for installing the new one... I'll take photos from the quadrant shaft for reference, I hope its fine |
![]() Wed May 18, 2022 9:02 am
PSMA wrote: Yo guys, picture above is so obvious now ... Just discovering things on the go Any tips that help changing the kick start lever easy? It looks as I need to remove the flywheel cover? Also, if the actual lever is stuck on shaft, is it safe to tap it out from behind? Thanks! |
![]() Wed May 18, 2022 9:11 am
Posts: 140 Location: San Francisco Bay Area |
![]() 1979 P200, 1960 Lambretta s2, 1975 Rally 200
FridayMatinee wrote: Flywheel cover does need to come off. The bolt won't come out otherwise. |
