Wed May 11, 2022 3:02 pm
Wed May 11, 2022 3:02 pm linkquote
Hello. I'm trying to clean the bendix of a 2007 LXV 150 with 650 miles but I cannot get the outer half of the pulley to come off. It's as if it's bonded to the inner half or spindle. Has anyone ever come across this issue? If so, what was done to get it to break free? Thanks for any help!
Wed May 11, 2022 4:07 pm
S150 '09, Beo 500ie '08
Wed May 11, 2022 4:07 pm linkquote
You need a cheap "gear puller" which has a central threaded stem that presses down on the center shaft, while two or three arms grab the outer area of the pulley. Cranking down on the stem pries the pulley off of the splined shaft.
About $10 at Harbor Freight. Maybe $20 for a set of three different sizes? Or borrow one.
Wed May 11, 2022 4:57 pm
GT 2.4
GT 2.4
Wed May 11, 2022 4:57 pm linkquote
sometimes you can gently tap it downward on each side and it will break loose, or wiggle it with your hands.
Thu May 12, 2022 7:05 am
Thu May 12, 2022 7:05 am linkquote
Judicious use of a rubber hammer around the circumference will help it come off - together with some penetrating oil.
Fri May 13, 2022 12:04 pm
Fri May 13, 2022 12:04 pm linkquote
Thanks everyone! With a quite a bit more elbow grease I was able to break it free. The two tutorial videos I saw showed the pulley coming off with ease so initially I didn't want to be too rough with it.
[ Time: 0.0664s ][ Queries: 7 (0.0332s) ][ Debug on ][ 211 ][ Thing One ]
