Thu May 12, 2022 6:32 am
2009 Piaggio MP3 250
Thu May 12, 2022 6:32 am linkquote
I recently started having issues commonly seen with a weak battery - flickering display backlight, struggling to start, etc, and figured it was just because it got so cold overnight. However when I started it in the driveway after charging all night, all power was lost and then it came back on a minute later with the display acting as though I had disconnected the battery. Temp switched back from F to C, and odometer from Miles to KM. By accident I discovered moving the positive cable and tightening it down in a new position made the problems go away.
Has anyone ever had to replace battery cables, and is it something only a mechanic should tackle? I did search to see if this topic had been covered before, so I'm sorry if I missed it.
Thu May 12, 2022 10:48 am
Thu May 12, 2022 10:48 am linkquote
replace ignition switch most likely the problem
Thu May 12, 2022 11:02 am
Thu May 12, 2022 11:02 am linkquote
battery terminal corrosion . clean and grease just like you do for a car battery.
Thu May 12, 2022 2:59 pm
Thu May 12, 2022 2:59 pm linkquote
As above - you don't need to replace the cable, just clean the connections.
Fri May 13, 2022 6:15 am
Fri May 13, 2022 6:15 am linkquote
Thanks everyone.
[ Time: 0.0295s ][ Queries: 5 (0.0101s) ][ Debug on ][ 211 ][ Thing One ]
