Fri May 06, 2022 4:12 pm
Vespa 300 piaggio bv250
Fri May 06, 2022 4:12 pm linkquote
I have a used bike I pick up a few months ago
2006 bv 250
The cvt seems to vibrate a lot more than any scooter I have had before . I have a had lot of them.
Is this normal? The whole bike at idle vibates the top case make nose?
I took it to a bike shop they do all brands.
They thought it was normal?
When I change the belt it seems to have a lot of play left to right is this normal?
I am at least the 3rd owner
I don't have much history on this machine
My 06 vespa gt was never like this?
HELP please
Fri May 06, 2022 5:28 pm
2020 BV350
2020 BV350
Fri May 06, 2022 5:28 pm linkquote
My top case rattles like craze on my BV 350 with 260 miles on it. I took it off & made sure it was installed correctly; It was. I'd think as soon as you give it a little gas, everything would smooth out.
Fri May 06, 2022 8:49 pm
2019 Supertech (EURO3/APAC)
Fri May 06, 2022 8:49 pm linkquote
a few rattles in different parts of the bike when idling is normal. most will go away when moving. if they don't then check them.
Fri May 06, 2022 9:25 pm
Fri May 06, 2022 9:25 pm linkquote
Any vibrations are exaggerated with a top case fitted. If your belt wasn't seated correctly, you'd soon know about it when riding. What you describe sounds completely normal.
Fri May 06, 2022 11:48 pm
Fri May 06, 2022 11:48 pm linkquote
Thanks so much
Thu May 12, 2022 1:45 pm
Thu May 12, 2022 1:45 pm linkquote
It really vibates at city speeds is this normal?
The side mount was changed.
Could it be a engine mount
It's been like this since I got it
I never had a cvt vibates like this one does.
Fri May 13, 2022 1:48 am
Fri May 13, 2022 1:48 am linkquote
Bump
[ Time: 0.0412s ][ Queries: 5 (0.0208s) ][ Debug on ][ 211 ][ Thing One ]
