Thu May 12, 2022 4:35 pm
bv350
bv350
Thu May 12, 2022 4:35 pm linkquote
i see the 2016 and beyond bv350 saddle complete show different pns than 2015 prior. is that asthetic or will a 2015 fit on a 2016+? thanks
Fri May 13, 2022 9:27 am
Vespa GTS300ie
Vespa GTS300ie
Fri May 13, 2022 9:27 am linkquote
I fitted a newer type 2015 seat to my 2013 , I believe the seat base is the same upto at least the 2020 bv350 .
See my thread about this .
https://modernvespa.com/forum/post2052875?highlight=#2052875
Fri May 13, 2022 9:37 am
bv350
bv350
Fri May 13, 2022 9:37 am linkquote
thanks for the reply. i saw the 2015 had same pn series as 2013 in one listing. i think 2016 is where the pns change at.
2013 2015 1b000209xxxxxxx
2016 + 1b003744xxxxxxx
1b00020900c4
1b00020900c5
1B003744000d1
1B003744000c2
Fri May 13, 2022 8:19 pm
bv350
bv350
Fri May 13, 2022 8:19 pm linkquote
i have found digrams showing pet carrier assembly (helmet) of 673958 for both 2015 and 2017 models. tbis would imply as you said 2012-2020 compatibilty. i saw a lot of other pet carrier assembly pns based on beverly or bv, and 2017 showed two numbers without explaination.
1b003740 2017
1b004276 2017
1b001126 2014
673958 2015 2017
Sun May 15, 2022 7:19 pm
2016 BV350 White
2016 BV350 White
Sun May 15, 2022 7:19 pm linkquote
The old model BV350 seats have that stupid peice in the middle that separated the front and back seat positions that most people removed. I think that a 2016 and newer seat would work on a 2013-2015 BV350. If you look at the parts schematic on the AF1 Racing site and find that the other parts that hold the seat in place are the same that you can verify that yourself that they are interchangeable.
[ Time: 0.0289s ][ Queries: 5 (0.0102s) ][ Debug on ][ 211 ][ Thing One ]
