GeekLion wrote:
agreed beat to leave the cables alone if possible. How is the wear n tear on the reat of the motor? If you're doing a crank/cyl swap, and splitting cases; worth while checking the cruciform and gear stack shimming. and might as well inspect the clutch plates and bearings while you're in there. New seals too.
Few mor things to remove and inspect, better now while you're already in there.
Everyone has there own way to work, I find it easier to work on an engine out of the frame(especially smallies); even though it means unhooking cables and wires. But like VooDoo said, he prefers to lay the bike over - both ways work!
Don't know much about the bike when it was in Japan… seems well looked after. Minimal rust
The PO had the engine resealed, but with a pk gearbox and Malossi clutch and plates and the 112c polini kit. So new seals and bearings
It hasn't been on the road much. The sip gaskets poking out of the rear hub and crankcase are squeaky clean.
But I had to rejet the phbl carb for smaller jets, the spark plug was black and oily. And reset the ignition… was in the region of 26-27 deg at 1000rpm
I'm actually not 100% certain of what crank is in there… it might be a 20/20 but I'm looking at a longer stroke now
