Fri, 13 May 2022 20:55:10 +0000
2019 MP3 500 Sport
2019 MP3 500 Sport
Fri, 13 May 2022 20:55:10 +0000 quote
Has anyone tried these? Would these fit into the limited space in a 2019 Piaggio MP3 500 US edition?
https://www.amazon.com/dp/B08JGKMVNK?ref_=cm_sw_r_cp_ud_dp_13EW734RSYKG6PV5KJ5F
I looked at the bulb in there and it is a very small orange "Osram 5009". Oddly enough Amazon recommends replacement LEDs that don't fit in there...
Fri, 13 May 2022 21:08:15 +0000
Fri, 13 May 2022 21:08:15 +0000 quote
I tried aftermarket LEDs for the blinkers including OSRAM and nothing works/fits. In addition, the stock Piaggio relay is not LED compatible and causes hyperflash.
However, you can order the 4 Piaggio LED blinkers including the stalks and the relay from the Euro spec MP3 2018 and newer and swap those out and everything is plug and play.
The only thing you have to swap over is the pigtail from the old lights onto the new LED units.
Check my previous posts on this mod.
Turn signal relay
And here is the link for the Piaggio LED relay from the 2018 and up Euro spec MP3s.
https://www.easyparts.nl/Blinker-Device-With-Hazard-p33684637
Sat, 14 May 2022 01:05:16 +0000
2019 MP3 500 Sport
2019 MP3 500 Sport
Sat, 14 May 2022 01:05:16 +0000 quote
Thank you as always Sbaert, you rock.
I ordered the bulbs and will report. My bike is an odd mishmash of ie and HPE parts, it has the LED rear and braking lights and the LED daylight strip at front (the manual they shipped with the bike doesn't mention that 🤣), so maybe it has the new LED compatible controller in it... and if not, hey, an Amazon return is just 5min away around the corner around here... 😜
As I try to be more do-it-myself, the fact my bike is an odd generational mongrel is... vexing. 🤣 Damn you Piaggio USA 😜
Sat, 14 May 2022 05:47:58 +0000
Sat, 14 May 2022 05:47:58 +0000 quote
PabloLie wrote:
...My bike is an odd mishmash of ie and HPE parts, it has the LED rear and braking lights and the LED daylight strip at front (the manual they shipped with the bike doesn't mention that 🤣), so maybe it has the new LED compatible controller in it... ..
It is not. That is the way ALL MP3s came until 2018 when the Euro spec got LED turn signal stalks. The US spec only got the LED signal stalks for model year 2022 thanks to Washington.
P.S. You must and you will need to change the relay to the updated Piaggio relay if you want to run any type of LED blinker (stock Piaggio LED blinker or aftermarket LED bulbs or stalks).
There are no aftermarket compatible relays
Sat, 14 May 2022 15:02:25 +0000
2019 MP3 500 Sport
2019 MP3 500 Sport
Sat, 14 May 2022 15:02:25 +0000 quote
FYI my manual doesn't show the front LED daylight strip, it was kind of a surprise when I converted the front bulb to LED...
Thanks for the info, sounds like another project I can handle.
Sat, 14 May 2022 17:06:06 +0000
Sat, 14 May 2022 17:06:06 +0000 quote
The tiny little LED DRL strip was eliminated a few years ago.
It was probably either cost cutting or as replacement when the Euro spec MP3 got the bigger and much better integrated 2 stage DRL light built into the main headlight.
Or it was a combo of the 2, since that dumb little DRL strip costs outrageously as a spare part for something that adds practically nothing.
Sun, 15 May 2022 21:59:51 +0000
Sun, 15 May 2022 21:59:51 +0000 quote
I like these corn cob lights, very bright
I left the covers off & put the screws in
These have the resistors built in & blink as they should
I don't ride in the rain, even if I did these kinds of bulb work fine when wet
& bright, very bright
https://www.amazon.com/gp/product/B082YW963W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Mon, 16 May 2022 19:19:50 +0000
2019 MP3 500 Sport
2019 MP3 500 Sport
Mon, 16 May 2022 19:19:50 +0000 quote
The ones I linked to in my original message...
fit and work great in my 2019 500ie (US model) with no other modifications - just replace the existing ones. Also very nicely bright...
No hyperflash, just normal operation. Guess I did get lucky in the parts lottery some of the US MP3 500s are and my controller was LED compatible...
Guess the high beam and the courtesy light under the seat (which has actually burned out) are the last incandescent strongholds on my bike
PS: I have no clue what kind of bulb the "courtesy light" under the seat it... mentioned nowhere in the useless user guide.... grrr
Tue, 17 May 2022 23:53:21 +0000
2016 Mp3 500ie Sport
Tue, 17 May 2022 23:53:21 +0000 quote
Hello Folks
Based on PabloLie's suggestion and endorsement I installed the same LED bulbs from Amazon.
Since the comparison of LED vs regular bulbs and the modifications comes up fairly often I put together a video comparison of the two types. LED is much brighter. Like PabloLie, I did not experience hyper flash either because I already had the Euro Spec relay or it just wasn't an issue to start with. Regardless, I bought 2 packs of 2 bulbs and am happy with the results.
Youtube video with descriptive text comparing the two with pictures and product links.
Amazon URL for VehiCode PY21W LED
Piaggio Parts URL for Piaggio Turn Signal Bulb - Amber
https://scooterpartsco.com/piaggio/piaggio-mp3-500/turn-signal-bulb-amber
If you switch to the LED bulbs and experience hyper-flash you'll need to install the Euro spec "Piaggio Blinker device with hazard" from EasyParts.
Link for installing the Euro spec relay
https://modernvespa.com/forum/post2455781#2455781
The "courtesy light bulb" is weird. No idea why its so weird when easier solutions could have been done but such is the weird Piaggio Mp3.
https://www.easyparts.nl/Bulb-p33569310
On the Parts Piaggio webpage its described as "Torpedo shapped lamp 12V-5W" or Part number 18 (071633) if anyone ever needs a replacement storage compartment bulb.
https://www.parts-piaggio.com/piaggio-scooters/500-PIAGGIO-SCOOTER/MP3/2016/MP3-500-Business-ABS-E3-E4/Frame--Plastic-parts--Coachwork/Helmet-huosing--Undersaddle/1218/30/10042/2722
Wed, 18 May 2022 00:10:23 +0000
2019 MP3 500 Sport
2019 MP3 500 Sport
Wed, 18 May 2022 00:10:23 +0000 quote
Thank you so much!!! I wonder why the previous owner removed it in my bike. Is there a known battery drain issue perhaps?
Wed, 18 May 2022 00:12:34 +0000
Wed, 18 May 2022 00:12:34 +0000 quote
No battery drain that I'm aware of beyond it always being on if the seat is open. If I ever have the seat open for extended periods I just put something on the pressure switch to turn off. The switch is located near the seat hinge on the left side.
Wed, 18 May 2022 03:58:30 +0000
Wed, 18 May 2022 03:58:30 +0000 quote
There is nothing unusual about the underseat torpedo style bulb, at least if you're familiar with European cars.
I replaced that one with a OSRAM LED torpedo style bulb as well a very long time ago.
Be aware that the torpedo style bulbs come in different lengths so be sure to measure yours first. I don't remember exactly what length mine is.
https://www.osram.com/ecat/LEDriving%20SL%20C5W-LED%20interior%20lamps-Car%20lighting-Automotive/com/en/GPS01_3381092/
Thu, 26 May 2022 14:57:59 +0000
2016 MP3 500cc Sport ABS
Thu, 26 May 2022 14:57:59 +0000 quote
I got the same bulbs for my 2016 Mp3 500 sport (US model). They fit perfectly and are super bright. But i have the fast flashing now. I'm trying to buy the new relay from easyparts (still waiting for them to get back to me about the shipping price).
Thu, 02 Jun 2022 21:25:52 +0000
Thu, 02 Jun 2022 21:25:52 +0000 quote
New relay is installed and I have now very bright signals. Love it
Sat, 04 Jun 2022 09:10:11 +0000
Sat, 04 Jun 2022 09:10:11 +0000 quote
I installed these: iBrightstar Newest 9-30V Super Bright Low Power 7507 PY21W BAU15S 2641A LED Bulbs with Projector Replacement for Turn Signal Lights, Amber Yellow
https://tinyurl.com/2azuok4k
They just fit and are very bright.
They also flash fast. I've decided I like this. It looks more urgent and I'm sure it attracts more attention, which is always good.
Mon, 06 Jun 2022 20:50:10 +0000
ET2 MP3
ET2 MP3
Mon, 06 Jun 2022 20:50:10 +0000 quote
Just upgraded and love them! Thanks for the tip!
[ Time: 0.0305s ][ Queries: 6 (0.0080s) ][ Debug on ][ 286 ][ Thing Two ]
