Fri May 13, 2022 3:44 pm
Mp3 350 sport 2019
Mp3 350 sport 2019
Fri May 13, 2022 3:44 pm linkquote
On the 2019 mp3 350.
When I want to park my scooter for a short time, I always lock the steering wheel using the ignition key so that the seat button will become inactive.
It's very inconvenient with the tilt lock on and all, yet I don't want anyone opening my seat while I'm gone.
Is there any other way do disable the button?
Am I missing something?
Is it a proximity thing?
Fri May 13, 2022 9:54 pm
Fri May 13, 2022 9:54 pm linkquote
Unplug the connector at the dashboard seems like the easiest and quickest solution.
But be aware then you only have the key as the sole way to open the seat so if the seat latch cable breaks or seizes . . . Houston, we have a problem.
Sun May 15, 2022 2:03 pm
Sun May 15, 2022 2:03 pm linkquote
The proximity of the key allows the seat button to work, even without the key being inserted or turned on
Once to walk away the seat button doesn't work
Sun May 15, 2022 2:38 pm
Sun May 15, 2022 2:38 pm linkquote
So you want to disable the seat lock button, but leave the bike itself unlocked?
"Does not compute" (tm)
Fri May 20, 2022 9:13 pm
50cc Beo, BigBeo 2003
Fri May 20, 2022 9:13 pm linkquote
Not so "uncomputed". Just the same way works any of the older models without those buttons, for example, such was mine 250'2006. Its seat opened only from a wireless key button, so I could leave it parked on a centerstand without anything locked. And it worked
Sat May 21, 2022 11:52 pm
Sat May 21, 2022 11:52 pm linkquote
A 350 doesn't have a key fob
try the red button and stearing lock
Fri Jun 03, 2022 3:47 pm
MP3
MP3
Fri Jun 03, 2022 3:47 pm linkquote
Maybe install a Relay that only allow the seat button to work if the key is in the On position? That is what I'm thinking to do in mine.
[ Time: 0.0282s ][ Queries: 5 (0.0093s) ][ Debug on ][ 211 ][ Thing One ]
