Fri, 13 May 2022 07:10:22 +0000
Fri, 13 May 2022 07:10:22 +0000 linkquote
My 180SS motor is back together and looking great. My difficulty in getting it to sit down fooled the shop for a little while until they realised the cam was still on the crankshaft and was too big to come out the (smaller) hole where the bearing and seal are on the flywheel side.
I was in the shop today and we decided we should replace the short loom from the stator to the junction box. What I want to know is, what is the correct wire size for those wires. Obviously it important electrically, but it also affects whether the loom will come through the engine case. I will also be trying to source the correct little connectors, I suspect a hobbyist type electronics place like Jaycar in NZ will be my best chance there.
Fri, 13 May 2022 12:12:12 +0000
VNB VSC o9c VMA vbc VSX
Fri, 13 May 2022 12:12:12 +0000 linkquote
18 I believe
Sat, 14 May 2022 07:21:39 +0000
Sat, 14 May 2022 07:21:39 +0000 linkquote
Birdsnest wrote:
18 I believe
Thanks, now I will have to translate into something our people understand here in NZ.
Sat, 14 May 2022 08:38:52 +0000
Sat, 14 May 2022 08:38:52 +0000 linkquote
https://www.powerstream.com/Wire_Size.htm
Sun, 15 May 2022 03:07:59 +0000
Sun, 15 May 2022 03:07:59 +0000 linkquote
Thanks for that.
[ Time: 0.0237s ][ Queries: 4 (0.0046s) ][ Debug on ][ 240 ][ Thing Two ]
